MGB Diving in: time to pull the parts car engine
drooartz
Found some motivation today -- after a nice drive with my local car club, the folks who sold me the parts car swung by to pull a few things off the car that they needed. When I bought it, I let them know that they could have whatever they needed (if I didn't need it). I don't want to store a bunch of extra stuff, I'm only interested in the parts I can use on my B... and of course the engine and transmission (why I bought the car in the first place). Good running engine and an OD transmission to drop into my car to get it back on the road while I rebuild the original engine.
This visit got me motivated, and I started pulling parts I wanted. Main was the aluminum bonnet (my car does have one as well), a nice spare to have on hand. Otherwise I'm just pulling a few bits and pieces that might prove useful down the road.
I've not pulled an MGB engine before. Anything I need to be thinking of, dealing with?
Side note -- this car was known as Rustyass by the previous owner. As we worked on it, little piles of rust dust appeared beneath the car. We all had a good laugh. :D
Mickey Richaud
Pretty straightforward - pull engine and transmission together after removing the radiator, both manifolds, starter, alternator, and distributor. Oh, and the shift lever as well. The nuts on the motor mounts can be a little tricky to access, but otherwise it's not a big deal. There's plenty of clearance to yank the whole assembly.
Have fun!
Rut
Drew,
I use an HF engine hoist and it can be difficult to get close enough to the front of the car to fully reach the center of the engine and the tires can get in the way as well. I ended up with the car on jackstands with the front ones as far back as I could get them without upsetting the balance and the a$$ end of the car elevated. Other than that it’s just disconnect all the lines, mounts, shift lever, etc. and jack that sucker up and out. Make sure the lift is on a smooth surface or it can be difficult to roll once loaded.
Good luck, Rut
Mickey Richaud
Oh yeah, as Rut said, put the rear end higher for an easier exit angle. Kinda sounds counter-productive, but it does help.
drooartz
drooartz
It is an OD. What's missing (I know I need to make sure I've pulled the wires)?
Grantura_MKI
Speedo angle drive and the rear crossmember will be in the way of the tail shaft flange. I us a bottle jack sideways so as the OD clears it falls over. Best to pull out the tunnel top cover to see better.
drooartz
drooartz
Got everything pulled today. Thanks for all the tips, they helped. In the end the only thing that held me up was forgetting to pull the shift lever out before I started to try and pull the engine. Was wondering what could possibly be holding things up... :grin::crazy:
So the plan now is to separate the engine and transmission and throw in a new clutch. I know my old trans (also OD) is good I will likely reuse mine for now. This one will get rebuilt at some point for a spare. Will probably reuse my carbs and distributor as well, as they've both been rebuilt in the last few years.
I grabbed a few things off the car that I could use as spares for mine, including the aluminum bonnet, wiper motor and boxes, heater box, and a few other random bits. The shell now goes to a friend who will strip the rest of the car down for what he wants for spares. I'm trying to only grab what I can use on my car, as I don't need to be a packrat with things that don't fit my stuff -- I've got enough junk as it is.
Mickey Richaud
Good job!
LarryK
Now, with luck, the motivation will continue. Mine stopped with house issues, but, finally getting going again. Only 3 yrs behind.
Grantura_MKI
Best to start these jobs in the cabin while you are still clean.
Would resurface the flywheel, replace the rear seal and check the throw out fork bushings, etc.
AngliaGT
Drew,
Now that you're an expert on engine removal,why don't
you come by,& show me how it's done?
drooartz
drooartz
If we lived closer together I'd be right over.
Of course engine removal is pretty simple. Functional engine installation is an entirely different thing. :smile:
drooartz
drooartz
I'm excited -- this gets my MGB back on the road so I can enjoy it while I do the real rebuild on the original engine. Also gives me a spare OD trans to keep on the shelf just in case.
LarryK
:highly_amused:
AngliaGT
Is there a checklist somewhere on what all to do to
remove/replace the engine on a '67 B/GT?
blueosprey90
I can't say whether there is any checklist. But if you've never pulled an engine, drain the oil and the radiator. Then get your digital camera and take lots of photos, especially of the wiring connections. Label all wires. Get the assortment of freezer bags with the labels you can write on. Label and bag all parts as they come off, trying to keep them in some semblance of order as you box them up. Start with one side and progress as far as you can (I often start at the front with the radiator). Then move to a second side and progress as far as you can. Then move to the third side and progress as far as you can. Then repeat as necessary. I have an MGA and pull the engine and transmission separately. Get a floor jack under the car to support the engine or transmission as necessary.
Barney has some MGA advice that will probably give you some ideas. start here and scroll through the next few pages. https://mgaguru.com/mgtech/engine/be105.htm
drooartz
drooartz
I didn't use any sort of checklist pulling this engine, as I have another to pull from my car so I'll pay more attention then. :smile:
When I did the engine in my Morris, I was careful to write down each thing I did in order (and took pics where necessary). That engine was out almost a year. Following that list of items backwards to reinstall was trivial to do. I'll do similar with the B - write down *every* thing I do, and take pics (or make drawings) where there's any question at all.
Freezer bags are a great tip - bags and some sharpies to keep the parts together and labeled.
Lastly, a big lesson from my previous exploits is to move slowly and think out the next move. Disassembly is addictive and you can get deep in with out much thought. Taking time between each step to make notes and take pics makes the reassembly as simple as "the reverse of disassembly." :grin:
LarryK
My order: Unhook battery, carbs and fuel line, engine wiring, radiator and fan, exhaust, clutch lines, driveshaft. Inside: seats, tunnel, shifter. Hoist, clamp on engine and tranny mounts and out.
T Well, diving in to the last major project. Triumph 11
drooartz Diving into the dash Spridgets 10
T Datsun 210 at Pull-N-Save Mesa, Arizona Spridgets 3
T 1981 Datsun 210 Orlando U Pull & Pay Spridgets 18
C MGA Change a pull starter to a push button system MG 6
Popeye General TR FS2758 alternate - Door Pull Assembly Triumph 2
T 1979 Datsun 210 at U-Pull in West Palm Beach, FLA Spridgets 1
T For Sale MGB Pull Handle Tub Body Shell for sale MG Classifieds 0
J Wanted Re: WANTED TO BUY: TRIUMPH TR3 ASH TRAY PULL KNOB Triumph Classifieds 1
P TR6 Looser steering & brake pull Triumph 6
Rut Bugeye pull starter Spridgets 10
tahoe healey cool air pull knob nut Austin Healey 15
TRMark T-Series Lever ignition light switch / pull starter switch MG 8
D TR2/3/3A Block coolant passages plugged - pull the head? Triumph 46
B TR2/3/3A Tr3a brakes pull to left on hard braking Triumph 9
Lukens TR2/3/3A Anyone ever see a push/pull throttle mounted on the dash? Triumph 4
C Brakes pull to left - especially when cold. Where to start??? Austin Healey 11
TulsaFred Starter Pull Spridgets 10
bugedd Starter pull Spridgets 9
catfood About to pull the engine, some advice please Austin Healey 4
maxwedge5281 63 bj7 fresh air pull Austin Healey 1
Got_All_4 TR2/3/3A Tr3 engine trany pull Triumph 6
maxwedge5281 bj7 hood latch pull Austin Healey 6
J TR2/3/3A Need a longer choke cable, IE: all the way to the pull knob Triumph 1
Jim_Gruber Looking for BE Pull Starter Switch Spridgets 18
M TR6 Tr6 Brake Pull Triumph 6
JFS TR2/3/3A TR3 Brakes pull to side Triumph 6
Mychael Location for pull starter solenoid. Spridgets 11
H Anyone near the U Pull It in Grand Praire TX? Other Cars 0
K TR2/3/3A Anyone have a TR3 original choke pull knob? Triumph 3
britndablood WTB original Pull Headlight Switch and Choke cable Austin Healey 5
B MGB and rotary Pickup in pull a part Spotted 8
F TR2/3/3A TR3 interior mystery question- door pull handles Triumph 9
Donalvin removal of push-pull dash control buttons Triumph 5
angelfj1 Vent Pull Frustration Triumph 9
Gundy Should I pull the trigger? British Motorbikes 58
Darrell_Walker I think I need to pull my heads Triumph 12
BugeyeNJ58 Push or Pull - Electric Fan Spridgets 3
6 elect. fan..push or pull Triumph 16
justin_mercier Source for a push/pull DPDT switch? Triumph 13
bugedd Original Starter Pull Wanted Spridgets 4
G Ready to pull my hair out... Spridgets 13
H TR2/3/3A TR3 -- Pull the head "while I'm in there . . ." Triumph 9
T Internet access to Pick'n Pull inventory Spridgets 3
S MkI headed to the scrap yard....what bits to pull? Jaguar 4
RichBall XJS/12 In lynnwood Wa Pull-A-Part Jaguar 1
NardisCNC How fast can you pull your Midget engine / trans?? Spridgets 17
jvandyke pull starter set up Spridgets 23
Got_All_4 TR2/3/3A WHY IS MY TR3 CHOKE CABLE SO HARD TO PULL Triumph 10
R Don't tell me I have to pull the *&%!#engine again Spridgets 13
