It is driveable! Finally. Morris 8
Jerry
Hey group, just wanted to share some pictures of our work on the Morris 8. A few problems with the fuel pump meant that we had to tow the car back up my driveway on the first two drives. My driveway has about 100 yards of a 40% hill. On the third drive after changing the fuel pump, the car made it up the hill in 2nd gear!
Now to be brave enough to take it out on the road! 1936 Morris 8 , about 27hp
Some work still to finish.
1. Need a top frame. I will probably try to find a MG TD or TF frame and cut and weld it to fit.
2. Install the convertible top
3. Figure out why the speedometer now does not work, (I think it is the cables)
4. Paint touch up
I hope you enjoy the pictures.
Jerry rear seat.jpgside view.jpgfront of car.jpgfront seats.jpgrear of car.jpg
NutmegCT
Congratulations! Really looks excellent.
We'd probably appreciate a few photos of the engine area ... Maybe a video of the engine starting up and running?
Tom M.
waltesefalcon
Lovely little car. You've done a good job on it.
J
Jerry
here is the engine installed, at least most of it. I had to replace the intake and carburetor and exhaust. This project took longer than I expected, we had to make many parts. Over 81 years someone took parts off the car and did not replace them. I got much better at working with metal. Everything behind the front seats, metal and wood was rebuilt new. Making the new wood frame was fun, my dad used to have a cabinet shop so wood working is in my blood. Metal working was not, but I had a friend that got me started and many of the metal parts we made from pictures. The rear valance, (between the rear fenders and below the spare tire) is 8 pieces of metal welded together. I don't have an English Wheel so I had to use my bead roller and shrinker/stretcher. Car still needs adjustments, the brakes pull to the right and they are still mushy. More bleeding needed. By the way, this engine is a 917cc side valve. Same engine as used on the Centurian tank and the first Morris Minor in 1948. engine installed (2).jpg
Roger
Bronze
Was it used as a generator or something on the Centurion? Its prime mover was the Meteor, the unblown Merlin.
J
Jerry
It was the engine that drove the centurion according to the Morris Register. And people have bought up all the left over engines and parts to fix Morris 8s. The military added an oil filter, water pump and few other minor things but it is the same engine. I don't know how this engine moved a tank around.
waltesefalcon
" I don't know how this engine moved a tank around."
Very slowly and laboriously.
aeronca65t Red Rat-now driveable Spridgets 15
ncbugeye MGB-GT Anyone know of an MGBGT - driveable - for sale MG 0
mctriumph TR2/3/3A Finally painted the 63 3b Triumph 14
J TR2/3/3A TR3A Finally on the Road! Triumph 6
AngliaGT Finally - A (Mostly) True craigslist Ad Other Cars 0
Grantura_MKI Pre-War Finally arrived. MG 7
J Finally getting (re) started on the Bugeye Spridgets 27
HealeyPassion Finally, paint on chassis Austin Healey 17
Lou E Finally a Bugeye of my very own Spridgets 41
AngliaGT RB Midget - Finally tracked it Down! Spotted 3
Bayless A Sprite gets some paint finally Spridgets 2
EricJNewman MGB Weird Brake issue finally solved. MG 1
Rob Glasgow Finally Found It (Original License Plate Number) Austin Healey 3
J Shroud Painting ["Finally done with these"] Austin Healey 3
Rhodyspit75 Finally on the road Spridgets 7
AngliaGT MGB FINALLY Got the Engine Out MG 5
Gliderman8 TR6 It finally HAPPENED... Hood cable broke but HAPPY ending. Triumph 44
Tr3aguy TR2/3/3A Tr3 frame work finally Triumph 93
Jim_Stevens TR2/3/3A Finally- the color coat! Triumph 12
Basil I finally joined Jaguar 4
J General TR Finally on the road Triumph 1
Bayless More Sprite progress finally Spridgets 23
SherpaPilot TR6 Stromberg War, Finally Success Triumph 2
Bayless Progress finally begins Spridgets 5
tinman58 General TR Finally almost Triumph 7
J TR2/3/3A Finally getting started Triumph 20
Elva164 Finally did another onboard video! Racing 4
M Finally Joining the Bugeye club! Spridgets 20
simon1966 Rain cleared up so finally got out. Austin Healey 31
tomshobby TR6 Finally finished my custom steering wheel. Triumph 12
B The Prince of Darkness on the dash board finally conquered Austin Healey 10
vickxxx T-Series Finally MG 3
Sarastro TR4/4A My TR4A finally arrived! Triumph 11
B Scuttle shake finally sorted Austin Healey 23
B Finally - BJ7 painted Austin Healey 3
Jer when something doesnt make sense... and you finally figure out why ! Spridgets 4
Basil Back to the EType finally Jaguar 5
Marvin Gruber Three rebuilt BJ8 engine- FINALLY! Austin Healey 17
J TR2/3/3A Finally started 17 year old rebuilt motor! Triumph 3
drooartz Finally found one Spridgets 8
L Are 100's finally eclipsing the 6 cylinder cars Austin Healey 6
trrdster2000 GT6 Finally got a photo of some of our work on the Spit 6 Triumph 2
T TR2/3/3A Finally found and fitted paper carb air filters on my TR3 Triumph 28
Steve P. Finally found a RWA Midget Spridgets 1
CJD TR2/3/3A TR4 Gearbox in the TR3...Finally! Triumph 3
R GT6 Finally Finishing Triumph 19
Sherlock It's driving season finally! Spotted 5
J Finally a fix for the SU pump Austin Healey 5
F MGB Finally got my 78 MGB on the road MG 5
F Spitfire Finally Mobile! Now Grind/Rubbing from Clutch, Gearbox Or? Triumph 5
