MGA Possible purchase
Rut
Good morning all...I’m looking at an MGA that’s for sale locally and although I know nothing about them, I’ve always liked them. I’ve got a few pictures from the seller and the engine runs, but it is obviously not drivable in its current state. This car looks like it has about the same amount of rust that I normally deal with, but I could reall use your expertise. Thoughts?
Thanks, Rut
JPSmit
seems complete and looks like surface rust - you certainly have the ability. I feel like this one comes down to price vs. ambition to do it vs how badly you want it.
Mickey Richaud
Don't know about the expertise part, but here's my take: Looks like you'll have your work cut out for you, but the pictures appear to show a worthy candidate.
Frame condition? Wood floors may have to be replaced, but they're not too expensive. Hopefully, that's only surface rust on the dash. Doors and bonnet are aluminum - make sure those are sound. Original seats present?
Let us know what you find!
Mickey
Rut
Rut
He’s asking $2500 and he’s only about an hour away, but I’m in Maine until Saturday. I might get a friend who’s somewhat local to take a look, but he’s not a car guy.
Thanks, Rut
Mickey Richaud
$2500 sounds like a deal to me...
blueosprey90
Get the car up on jackstands and inspect the frame. Rockers, sills and rear fender doglegs are the first to rust out. And I doubt that that engine runs. If the seller can't start it up, knock him down $500.
It looks like a 1600 by the tail light plinths, but MGAs came in 1500, 1600 and 1622 engine varieties, but many people drop in a 1800 3 main as well.
Grantura_MKI
Geez. Are expecting a great car at 2500? If done nicely it will bring 30k plus. Work the numbers....if not by one at auction and expect to spend another 3-5k to make it right.
blueosprey90
No, but the seller is apparently claiming that the engine runs. That seems a bit of seller's hyperbole. And to see the true extent of the rust, you need to be looking under the car. Just sayin' :smile:
NutmegCT
If that MGA has been stored outside under a tarp (like the photos show) - there's going to be more than surface rust.
And I agree, I very much doubt that engine actually "runs" - unless he means what you see when you add oil, coolant, and fuel.
They all run right out.
But if you have your own shop, spend lots of time and money - it may eventually be worth $30K.
Tom M.
Rut
Rut
Thanks for the replies and I back in AL. I let this one pass since I have too many projects to say grace over now.
Rut
N TR2/3/3A Looking for expert appraisal advice re possible TR3-B purchase Triumph 3
smaceng TR6 Possible Purchase of a TR6 Triumph 21
R Possible Midget purchase - advice needed Spridgets 11
bash GT6 Possible GT6 purchase - repairability? Triumph 16
F Spitfire possible 76 Spitfire purchase-advice? Triumph 5
JM1NA TR2/3/3A Possible TR3 purchase, some advice, please.... Triumph 13
T 100 BN2 Possible Ignition Issue Austin Healey 7
B TR2/3/3A Possible differential problem Triumph 3
K Spitfire 1978 Spitfire possible Vapor Lock? Triumph 16
steveg TR6 Unshrinking tonneau - is it possible? Triumph 12
steveg TR6 Installing stock trailing arm bushings on the car - is it possible? Triumph 2
D Possible Mini Gauges? British Motor Corp 6
K TR2/3/3A Isit possible to buy a single left hand thread tie rod end? Triumph 5
M TR2/3/3A Brake Problems - Possible Solution Triumph 5
T TR2/3/3A Is it possible to buy stronger springs for turn signal lever in control head? Triumph 14
angelfj1 TR2/3/3A Possible UK Source for Authentic looking Clutch/Brake MC Triumph 5
RAC68 Non-Healey Cruising Rear Possible? Austin Healey 37
T Wanted wanted-- 1275 ribcase shifter and shifter seat cover if possible Spridgets Classified 0
glemon TR5/TR250 Is this even Theoretically Possible? [Brake Question] Triumph 3
H Bugeye seat pan rust and possible repair Spridgets 2
B TR4/4A Possible to put TR6 seats in a TR4A Triumph 3
DNK Wedge Possible new toys Triumph 21
B Stator Tube Question - Is it possible to make one out of tubing? Austin Healey 16
A TR2/3/3A Possible problems replacing a Lockheed rear axle with a girling unit Triumph 6
tomshobby Can't be possible can it? Spridgets 6
aeronca65t Possible racer-Spridget for sale-Atlanta Racing 0
R TR6 Cruciform [T shirt] and possible trailing arm mount replacement Triumph 8
TRMark What could possible go wrong? Restoration & Tools 4
dcoplan Possible to adapt K&N 1-1/4" air filters to 1-1/8" carbs? Spridgets 14
F Is it possible to retro fit overdrive to a BT7? Austin Healey 2
T TR2/3/3A Is it possible to drill vacuum advance port in SU H6 carb? Triumph 14
Bob Claffie Wedge Possible TR8 Triumph 9
T Possible bearing problem Austin Healey 6
S Question about possible oil pressure problem???? Triumph 4
hondo402000 TR6 Possible cam Plug leak on my New TR6 Engine Triumph 7
G Possible TR find Triumph 10
G TR6 Possible TR6 Project ? ? Triumph 1
bighealeysource Possible side effect with Petronix ignition Austin Healey 38
Lon_S Possible leaking rear axle seal Spridgets 7
G I'm wondering if its possible... Spridgets 20
t_bush Possible replacement seats from Walmart? Triumph 16
newmexTR3 TR2/3/3A TR3 hard cornering vibration- possible causes? Triumph 13
AH_3000 How is it possible... Austin Healey 20
A help me on a possible 59 bugeye 20 years in a barn Austin Healey 1
jclay Possible Fraudulent Seller Triumph 1
RickB Witnessed possible WOT accident this morning Spridgets 88
G TR6 Possible TR6 project? Triumph 2
G Possible new Triumph...input sought ! Triumph 9
G Electrical Question and Possible Dilemma Triumph 24
GBRandy TR2/3/3A Possible TR3 Triumph 17
