The Journey Begins - BJ8 restoration
Westcoast M5
Hi Everyone,
I did a new member intro a little while back and now plan to share the journey of restoring my 1967 BJ8. Thank you to every poster who has filled this forum with fantastic information. You know once you are re-reading threads for the third time it is time to get away from the computer and out into the shop....
I began taking the car apart on June 1st and am now ready to begin building. My Jule frame will arrive in about a week!
Cheers
Healey Nut
Ok Im going to ask a really dumb question .
It looks like those pretty parts in the garage are all painted and ready to install .
Were they test fitted to the new frame/superstructure assembly ?
Healey Nut
The frame doesnt look that bad to me , way better than both my Healeys after the sandblaster had revealed what the tin worm had done .
Cant help but notice the damaged front outrigger drivers side , guess someone crashed her at somepoint ?
edit closer inspection its jut the cut out for the exhaust that makes it look bent .
Healey Nut
Frame rails can be fixed .
Westcoast M5
Westcoast M5
This is what the car looked like before the tear down:
Shiny on the outside....rotten on inside
Healey Nut
Ah ok , I just was having visions of you taking parts off one car and trying to fit them to basically another car after doing paintwork and them not fitting .
So basically the car was all lipstick and fancy hair but the foundation was crumbling .
Westcoast M5
Westcoast M5
It had a rear end accident at some point, but i think the front outriggers were just rusted. It had been "restored" previously and the frame had patches welded over patches...covered by about 50 lbs of undercoating. It was also rusting from the inside out, very thin in many areas.
Here is a full set of pics that shows the extent of the frame damage: https://www.flickr.com/gp/53598796@N02/k45QC9
Healey Nut
yep been there done that ... I could be looking at pictures of my 64 they look remarkably similar .
So you are getting the full Jule superstructure not just the frame .
I have a full Jule superstructure waiting in the wings for my 62 Tri carb project .
Westcoast M5
Westcoast M5
Unfortunately, Martin at Jule Enterprises is not doing the superstructures anymore (due to health reasons), so is only selling frames. He was able to supply me a lot of the sheet metal, but I will be redoing the superstructure myself. 90% of the inner panels will be new. I also decided to go with the steering rack they sell. I'm going to keep it "original looking", but will do the steering rack, upgraded brakes, tremac 5spd, and a fast-road engine. Someone could return it to stock if they wished in the future (except for the Jule chassis obviously)
I assume Martin did the full superstructure for your 62 at his shop?
Healey Nut
Yes .
I delivered the original to him but once sanblasted there was very little worth slavaging . The cowl top panel and the curved end brackets for the dash and a few other minor parts , the rest went to the dump and he delivered me a new complete superstucture a couple of months later . He did use the original parts that were salvaged .
I have his upgraded rear springs as well for the car when I do it .
Rob Glasgow
I love the look of all the body panels hanging on the wall. Almost worth just keeping them as an art work....but you've got a great project there and I'm sure you will total enjoy the entire process of bringing it back to life. I did my BT7 two years ago and it was one of the most satisfying things I've done in a wonderful life of 72 years of learning. I know it will be spectacular when you're done.
Westcoast M5
Westcoast M5
That is the way to go. You will have a solid, tight car when you are finished. I am doing exactly the same thing, except it will be me, not Martin supplying the labour.
FYI, Martin has done a video (4 hrs) of how to transfer/rebuild the superstructure since he is not doing it anymore. Excellent guideance on exactly how to do it. You need to be comfortable welding and fabricating, but it gives you all the measurements and things to watch for so you can do it right the first time.
Westcoast M5
Westcoast M5
Thank you Rob. I couldn't agree more. It's about the journey and "the doing" that I am enjoying!
I could have easily sold it and bought a perfect car, but that's not the point
Healey Nut
Havent check Martys website in ages .
Just took a look and if you go under projects and look at the BT7 Ontario . Thats my 62 so you can see how bad it was .
Totally shot frame . Main reason I bought the project was because it had the original factory hardtop and the tricarb set up was still together unmolested . When I had the car history searched turned out it was a full matching numbers car and was sold with the hardtop (correct serial number) so I decided to keep it and restore it instead of parting it out and selling it .
Westcoast M5
Westcoast M5
You're right, lots of fresh metal required. When are you planning to complete it? I'll look forward to seeing the finished product.
bugedd The journey begins....maybe Spridgets 9
JPSmit MGA - on a journey Spotted 9
D TR2/3/3A My Reassembly journey Triumph 220
D TR2/3/3A My Trim journey. Triumph 16
D TR2/3/3A Starting my Bodywork journey. Triumph 166
sd80mac7204 Spitfire Photo journey: Spitfire rebuild Triumph 6
S Epic Journey Spridgets 7
JPSmit Amazing Journey in a Midget Spridgets 2
J The journey to save a family treasure! Spridgets 8
hondo402000 TR6 TR6 Painting Journey almost over Triumph 9
B 2000 mile journey ahead MG 5
JPSmit Today's journey great start - home on a flatbed Spridgets 39
AUSMHLY The Journey here is great! Austin Healey 2
Bret What’s in your scabbard – A sentimental journey. Restoration & Tools 17
Baz 2012 Mini CEL - Now it begins........ British Motor Corp 0
longbridgehealey And so it begins....... Spridgets 6
Bayless Progress finally begins Spridgets 5
Jim_Gruber Decopnstruction of Rear End over, Reconstruction Begins Spridgets 4
S And so it begins again Spridgets 48
R TR2/3/3A And so begins the body work... Triumph 10
Jim_Gruber And so it begins - Bugsy II - Floorpan Replacement Spridgets 1
drooartz Penny's bodywork begins Spridgets 131
drooartz The teardown begins, follow along at home! Spridgets 51
simon1966 The BN1 resurrection begins today. Austin Healey 7
Jeepster Now the fun begins! Austin Healey 30
60Bugeye Bodywork Odyssey Begins Spridgets 3
Basil The Tank Saga begins Jaguar 9
O And so it begins...again Triumph 16
PAUL161 Restoration Slowly Begins MG 16
MadRiver And so it begins MG 1
J And so it begins! Triumph 20
hondo402000 The Painting begins Triumph 44
G MGB 1971 MGB...The Project begins! MG 24
drooartz The week of Tunebuggery begins! Spridgets 3
B Voting begins for Midget 50th National Venue!! MG 1
B Voting begins for Midget 50th National Venue!! Spridgets 26
JPSmit Wiper Motor - the saga begins Spridgets 5
S My Jaguar Adventure Begins Jaguar 22
Monark192 MGA MGA Restoration Begins MG 3
Dadandson Now the Fun Begins Spridgets 16
T The Battle Begins Triumph 104
Brosky Powder coating begins next week Triumph 2
tosoutherncars Front-End Rebuild Begins!! ['78 1500] Spridgets 8
Brosky Bumper rechroming project begins... Triumph 23
B The rebuild begins! Austin Healey 6
sideache My Barn Find Resto begins Spridgets 27
A And so it begins!! Spridgets 3
B painting begins on the BE! Spridgets 11
Brosky New Overdrive adventure begins tomorrow Triumph 15
siberian TR6 New TR6 owner, the adventure begins! Triumph 8
