TR2/3/3A Front Oil Seal
DaveC
Advice please.
I'm at the end of a rebuild of my engine and everything has gone well, except for the front oil seal. To cut a long story short, I can't get a new seal (Moss 520-000) into the timing cover. I've tried heating the cover, and have got a perfectly sized ring to help drift the seal in. However, it just won't go in without distorting. This is the second seal (the first went in eventually but must have been distorted).
So, is there a trick I'm missing, or is there a different supplier that offers a seal that is a better fit?
thanks
dave
TR3driver
Great Pumpkin - R.I.P
Are you absolutely certain that all of the old seal is out of the cover? A lot of times, they have an outer metal ring that looks like it is part of the cover, but isn't (and tends to stay behind in the cover). I believe the pocket should be about 2.5" (same as the outside diameter of the seal).
CJD
Unlike most cars, it inserts from the inside...so perspectivly it goes in backwards from the way most seals install. Are you certain you are not installing it backwards?
DaveC
Absolutely sure. I have the timing cover off, the old seal is out in one piece, and I'm installing it the correct way around, ie with the spring and lips facing inwards.
dave
TR4nut
Any burrs or suspicious potentially out of round areas? It is a tight fit but with a proper sized drift (I use a large socket) I’ve been able to always seat them. Not a great idea but you might try a different vendor to see if a different seal can work.
malbaby
You could take your old seal to your local "bearing" type shop where they can measure your old one accurately and supply new.
CJD
Alas...another example of the shoddy vender parts we are forced to deal with! Order one from TRF.
sp53
Second the call to TRF, they specialize in tr3; the owner drives one and as a result often the parts are more original.
DaveC
Well I got another seal from a different supplier. This was more of a rubber housing and it slid into the timing cover with just the right amount of effort. I had called Moss and they said they'd never heard oimf a problem but the measurements are so far out there is something amiss.
Anyway I hope this seal does the trick. I got it from Victoria British, ordered before the TRF recommendations. Fingers crossed
Dave
CJD
I could have paid for my restoration if I had a dollar for every time I was told I was the “first to have a problem with that part”! There is a chronic problem with shoddy repro parts for our cars.
TR3driver
I'm still mad over the time a vendor told me that; when I knew that _I_ had not only complained, but returned the part in question, not once but twice!
I had actually gone there the third time with the intention of showing them what the problem was (their catalog was simply wrong about what cars the part in question would fit), but they weren't interested in what I had to say, or the parts I brought for "show and tell".
CJD
I have no doubt the reps are trained to respond that way...infuriating when you know they are not telling the truth!
K TR2/3/3A Front hub oil seal Felt? Triumph 1
D TR4/4A Trans replacement front oil seal not same size as original Triumph 2
M_Pied_Lourd TR2/3/3A 59 TR3A Front Hub Oil Seal Triumph 2
AHS TR2/3/3A Which way does the TR3 front crankshaft oil seal face? Triumph 8
V TR2/3/3A TR3A Front Oil Seal Triumph 3
Gliderman8 Front oil seal HELP with..... Triumph 28
Gliderman8 Drip, drip, drip... NEED HELP WITH FRONT OIL SEAL Triumph 21
B TR6 TR6 Front Oil Seal Sleeve Triumph 3
healeynut Front Oil Seal - BN1 box - worth it? Austin Healey 4
toysrrus TR2/3/3A Re: TR3 "Front" Main Oil Seal: Triumph 3
bthompson 1500 front tranny oil seal?? Spridgets 14
J Gearbox front oil seal Spridgets 8
tahoe healey front oil seal Austin Healey 11
G Changing front oil seal on transmission. Triumph 14
R6MGS T-Series MGTC Front Crankshaft Oil Seal MG 5
svtmikey Front Hub oil seal question Triumph 7
K TR2/3/3A Oil leaks at two front cylinder head studs? Triumph 3
S TR2/3/3A Oil Leak Dripping from Front and Rear of Left Side Oil Pan---Only While Running Triumph 14
bugedd Front suspension and oil pan Spridgets 17
TulsaFred Front engine oil leak Spridgets 33
L Oil under left front shock Austin Healey 7
PatGalvin TR2/3/3A TR3 Engine Front Sealing Block, Oil Pan Screw Size and Thread Pitch? Triumph 11
Tim Tucker Front Engine Oil Galley Plug Triumph 10
19_again GT6 GT6 front boots grease or oil? Triumph 9
davidk Stripped threads in oil pan front saddle block Triumph 12
2wrench Re: Screw at engine front stopping oil loss Triumph 8
AUSMHLY Oil/water gauge - anyone taked the front off? Austin Healey 1
mbrooks 100 oil leak from front of engine Austin Healey 3
RobT Best way to fix the oil leak at front of block? Triumph 15
G TR5/TR250 Oil leak at front of TR250 motor Triumph 4
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
1 TR2/3/3A Rimmer Brothers Replacement Front Wing Quality? Triumph 8
Carlbanan56 MGB Front hub MG 4
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
scottkilpatrick TR4/4A Front Brakes - Basics for Pads Triumph 11
C MGB-GT MGB-GT Front Ride Height MG 0
C MGB-GT Front Ride Height MG 0
J For Sale Bilstein Front Shocks for Jaguar E-Type 727-498-6493 Jaguar Classifieds 0
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
E Wanted 1963 Healey 300 mark 2 front grille wanted Austin Healey Classifieds 0
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
AUSMHLY Front Wheel Spin Drag Austin Healey 6
mctriumph TR2/3/3A Front Suspension upgrades for the 59 Triumph 10
K TR2/3/3A Rear tire pressure when there is an anti roll bar at the front of the car? Triumph 1
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
