Results 1 to 15 of 15
Thread: New Toy
The Pub is: Forum to generally shoot the breeze. It is NOT: a debate forum (NO Politics, religion, or controversial topics.) Keep it clean, fun and lite!
  1. #1
    Join Date
    Jan 2011
    Location
    stamford, CT
    Posts
    1,851
    Thanks Thanks Given
    Thanks Thanks Received
    10
    Thanked in
    New Toy
    It finally happened. After almost 70 years of working on cars, I finally - in my old age - bought a....Creeper from AutoZone. No more twisting my aged body under a car on an old, ratty towel. This will go along with the small air compressor I finally bought about 10 years ago that ended the bicycle pump era. Ever try inflating a car tire with a bicycle pump? Now maybe I can find that clunking noise every time I go over a bump. The last time it was a bent piston rod in the left tube shock, cured by a new shock ($17.00) from Rock Auto. This may be from the right side. I'm beginning to think the tube shock conversion is not such a great idea. At least the diff mounts were strengthened years ago when I bought the car. OTOH, maybe the best answer is a solid axle conversion from a TR4? Is it even possible?
  2. #2
    Administrator Basil's Avatar
    Join Date
    Dec 2000
    Location
    Turn left at Albuquerque
    Posts
    22,609
    Blog Entries
    7
    Thanks Thanks Given
    30
    39
    Thanked in
    Re: New Toy
    Congratulations! I won a creeper a few years ago at a car show raffle but for some reason I almost never use it. Speaking of clunking noise, I had a clunking on the right side of my Hyundai Santa Fe when I went slow over rough surfaces. It turned out to be a sway bar link that wasn't sufficiently tight on one end (was not easy to diagnose as it "felt" tight from trying to move it by hand).
    “The smallest act of kindness is worth more than the grandest intention.” - Oscar Wilde
  3. #3
    Luke Skywalker vette's Avatar
    Join Date
    May 2002
    Location
    Pa.
    Posts
    1,577
    Thanks Thanks Given
    12
    Thanked in
    Re: New Toy
    PD, bring it on over we'll get it up in the air for ya. And ya those tube shock conversions on LBCs ain't what they're cracked up to be. I have them on an MGB and I'm going back to good old, original lever shocks when I restore the car next year.
    About TV Shows-
    "...you really can't restore a car in 10 days. I don't want to watch a race where people have to restore it in a week. It's not going to drive, and those cars never work. In real life, it takes years to get it right. " Jay Leno.
  4. #4
    Great Pumpkin DrEntropy's Avatar
    Join Date
    Sep 2005
    Location
    Elsinore, DK
    Posts
    32,541
    Thanks Thanks Given
    12
    39
    Thanked in
    Re: New Toy
    Quote Originally Posted by vette
    I consider that conversion a solution without a problem.
    '64 MGB, '67 Lotus Elan S-3 DHC,'69 Lotus Elan +2
    '78 Alfa Romeo Spider-undergoing surgery: O=\*/=O
    '84 300D Turbo-"Diesela"-Now my Daily: Oo|≣|oO
    '02 Toyota Camry- SWMBO's 'new-to-her' Daily. <sigh>
    Chaos & Mayhem PTY, LTD..C.I.O. & Floor Sweepervisor
  5. #5
    Join Date
    Jan 2011
    Location
    stamford, CT
    Posts
    1,851
    Thanks Thanks Given
    10
    Thanked in
    Re: New Toy
    I don't know about the MGB conversion on a straight axle, Doc, but there any many cases of frame cracking on TR6's caused by tube shocks. Google TR6 tube shock conversions. Apparently they move straight up and down while the trailing arms move on an arc. The lever shocks with those short control links also follow that arc it is said. That's apparently how my left side one got bent. Now there's clunking from the right side (I think) - maybe the right tube shock, maybe not. So far, no frame cracks. IMO, the TR6 stock rear suspension is a cobbled-up mess and dangerous too if not properly looked after. Ask the owners whose axles pulled out and detached from the car or as mine did some years ago, had the bolts loosen from the trailing arm and cause the right rear wheel to come off and roll into someone's front yard causing me to lose control and wind up across the road on the sidewalk facing the way I came. Luckily, no one was coming the other way, or...a head on for me. I had to replace the trailing arm and torque those bolts very carefully. Too tight and they can strip out of the aluminum trailing arm and then you either go to Heli-coils or get another trailing arm - if you can find one. They're NLS.
  6. #6
    Join Date
    May 2002
    Location
    Pa.
    Posts
    1,577
    Thanks Thanks Given
    12
    Thanked in
    Re: New Toy
    I agree with your opinion about the TR IRS. The funny thing is that I have a Nissan Pathfinder that has a very similar suspension. It's the most unstable vehicle I have ever driven. There are two lower control arms and the leading one is on an angle and has the seat pan for the coil spring. I've changed the springs and the shocks and it still moves all around when just cruising down the highway. Ya feel like your holding on to it all the time.
    About the 'B's tube shocks. They were on the car when I bought it as a project car about a year ago. They are loose and bent. I believe they are too long for the application and also mounted so they can't travel with the arc of the axle. Their just not worth the effort seeing as how the level shocks do a very fine job. These aftermarket "alterations" seem to me to follow a similar concept. The "alteration" might have its merits if you are racing and it is engineered well, but for constant every day driving they are impractical. But what these concepts do is create a Market. They sell. But most we don't need.
    About TV Shows-
  7. #7
    Great Pumpkin NutmegCT's Avatar
    Join Date
    Jul 2004
    Location
    Connecticut USA
    Posts
    10,535
    Blog Entries
    1
    Thanks Thanks Given
    34
    59
    Thanked in
    Re: New Toy
    " But what these concepts do is create a Market. They sell. But most we don't need."
    Ain't that the truth!
    Mac & Phyllis Take a Trip: http://nutmegflyer.com/trip-details-daily-updates/
    History: 1976 MGB, 1959 Triumph TR3A, 1960 Mercedes-Benz 190b, 1958 Rambler American.
    Current: 1953 MG TD27318.
  8. #8
    Join Date
    Sep 2005
    Location
    Elsinore, DK
    Posts
    32,541
    Thanks Thanks Given
    12
    39
    Thanked in
    Re: New Toy
    I hold the same disdain for automatic transmissions and air conditioning.
  9. #9
    Jedi Trainee Alfred E. Neuman's Avatar
    Join Date
    Dec 2016
    Location
    Atlanta, GA
    Posts
    216
    Thanks Thanks Given
    3
    14
    Thanked in
    Re: New Toy
    Quote Originally Posted by DrEntropy View Post
    Not from the south, I take it.
    This tread has gotten me thinking. I'll start a new discussion in the Triumph forum to discuss a TR6 project I've been contemplating.
  10. #10
    Join Date
    Sep 2005
    Location
    Elsinore, DK
    Posts
    32,541
    Thanks Thanks Given
    12
    39
    Thanked in
    Re: New Toy
    Quote Originally Posted by A.E. Neuman
    Tampa, to be accurate. If the State Legislature outlawed both, it wouldn't bother me. And I'd have a lot more Lebensraum. The place would clear out as if someone shouted "FIRE!"
  11. The Following User Says Thank You to DrEntropy For This Useful Post:
    Gliderman8  (08-21-2018)
  12. #11
    Join Date
    Jan 2011
    Location
    stamford, CT
    Posts
    1,851
    Thanks Thanks Given
    10
    Thanked in
    Re: New Toy
    Florida used to be the last stronghold of the big car. Big Cadillacs and Buicks with small turtlehead drivers. That and parts of the Midwest. My dad's dream car was a Mercury Marquis. His last car was one of those big Fords - forgot the name. My brother inherited it and blew the transmission driving it back to his home in Virginia. Before that, he had an Olds 98.
  13. #12
    Great Pumpkin JPSmit's Avatar
    Join Date
    Nov 2004
    Location
    Toronto, ON
    Posts
    17,906
    Thanks Thanks Given
    34
    Thanked in
    Re: New Toy
    Quote Originally Posted by pdplot View Post
    When we lived in Florida we used to say "beware of octogenarians driving cadillacs." This was one reason that I didn't enjoy riding a motorcycle in the state - that and every road is straight.
    John-Peter Smit
    1976 MG Midget
    1969 Vauxhall Viva GT
    1958 Fiat Multipla (Barn art)
  14. #13
    Join Date
    Sep 2005
    Location
    Elsinore, DK
    Posts
    32,541
    Thanks Thanks Given
    12
    39
    Thanked in
    Re: New Toy
    Knew an octogenarian in Miami with an old '60's Cadillac. He patched the rusty rocker panels by filling 'em with CONCRETE! One of the first Low Riders! Everyone called him Pappy. I don't think he ever went faster than 40 MPH in it.
  15. #14
    Join Date
    Nov 2004
    Location
    Toronto, ON
    Posts
    17,906
    Thanks Thanks Given
    34
    Thanked in
    Re: New Toy
    with concrete I doubt he could!
    Back in the day there was a 50's Roller parked in the lot next to where I lived (back when it was a used car) went up close one day and all the holes were covered with black electrical tape.
    John-Peter Smit
    1976 MG Midget
  16. #15
    Yoda waltesefalcon's Avatar
    Join Date
    May 2002
    Location
    Fletcher, Oklahoma
    Posts
    5,245
    Thanks Thanks Given
    228
    5
    Thanked in
    Re: New Toy
    PDP, do you mean one of these? My head is fairly large but I do have the car.
    Cheers,
    Walter
    52 International L110
    61 International C112
    68 Cadillac Coupe DeVille
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
