TR2/3/3A Vent Tip...
HighAltitudeTR3
I thought I would share what I did with my Vent because it had not worked since day one and the design of the whole vent system is not very efficient. The wire from the pull mechanism goes in to the lever that actuates the vent, problem is the wire doesn’t move enough to create a smooth transition from open to close.
The problem is solved easily and FREE! Drill a small hole just slightly larger than the diameter of the wire in the plate above where the vent wire usually attaches, bend the wire in a zigzag pattern in order to keep it from sliding out. Make sure not to make the wire too short or you won’t be able to close the vent.
Hope this helps someone out there!! My vent works with perfection every time!
sp53
On the original design, the barrel were the wirer goes through needs to be free and turn with the linkage to help with a smooth actuation, but yeh those vents have caused a lot gray hair, stomach problems, and divorces.
HighAltitudeTR3
HighAltitudeTR3
It needs to be free?! That would’ve made a huge difference! There’s not a lot of info on that goofy part. We’re doing a great service here.
DavidApp
My TR3A came without the vent mechanism so I bought one on E bay and used it as a model to make a new one. The E bay one was very rusty.
The silver piece in the photo clamps the pull wire and is free to rotate in the lever. Very fiddely to get back in the car.
David
HighAltitudeTR3
HighAltitudeTR3
I think mine has some PO hack job... you can see in the photo where the wire would basically be stuck against the side and offer no movement. Anyone else have this set up?
TR3-Stu
David
David,
My TR3A was missing the mechanism when I bought it. The PO had removed it and hob-jobbed the vent to remain fully open all the time. Do you have a drawing that gives the critical dimensions - from pivot point to the various holes?
DavidApp
Hello Stu
I have the info somewhere and will post it here for you. It may take a few hours to come up with it.
David
TR3-Stu
David,
Thanks for the quick response. When you find drawings/info, it will be very much appreciated.
Stu
ckeithjordan
This thread may help:
DavidApp
Hello Stu
I have yet t find the drawings. In fact I may be thinking of a sketch I found on line that gave a great view on how it works.
I bought a rust one from e bay and used that as my model to make my own one. I could have made a much better clamp piece if I had my lathe at that time. It seems that either TRF or Moss may sell the Scuttle vent.
I can make drawings but it may take a day or so.
David
Frank Canale
Bit late replying, but perhaps these pics will help. Sorry don't recall who posted the diagrams so I can't give them credit. Cheers, Mike
This is a nice drawing I copied from a post on the forum. If you let us know which part you need dimensions for , my assembly is apart and I can do a drawing with dimensions tomorrow. Frank
TR3-Stu
Hello Stu
DavidView attachment 71566View attachment 71567View attachment 71568
David,
Thanks for the pictures and the offer. I don't want you to put a lot of time into making a drawing, but if you can give me the dimensions from the centerline of each of the holes - the pull-wire hole, the pivot hole, and the actuator hole, with that info and your pictures I think I can produce a working drawing to create a usable part. Thanks again for your help and information.
Stu
DavidApp
Here is my crude sketch of the lift mechanism. There is a reinforcing piece under the 10-32 holes. It is a piece of 1/8" material tacked in place. The piece that straddles the .25" hole is brazed in place.
Let me know if you need any more info.
David
Frank Canale
Hi Stu, sorry so long but could not get pictures from the cloud yesterday. Between David's and mine you should be able to get close.
The off set bracket is .055 thick and .500 widened 1.197 long with a 1/4" hole for the pinch bolt part so it can rotate. Hope this helps and good luck, if you need any more information let us know. Frank
TR3-Stu
Here is my crude sketch of the lift mechanism. There is a reinforcing piece under the 10-32 holes. It is a piece of 1/8" material tacked in place. The piece that straddles the .25" hole is brazed in place.View attachment 71582
David
David,
Thanks so much for taking the time to put this together for me. The value of the forum - the sharing of information by British Car enthusiasts.
Stu
TR3A TS78330-L
TR3-Stu
Hi Stu, sorry so long but could not get pictures from the cloud yesterday. Between David's and mine you should be able to get close.View attachment 71589
View attachment 71590View attachment 71595
Frank,
Beautiful piece of work, and very helpful information. Thanks for taking the time to pull this together for me. With the combination of Frank's and your information I can put a working mechanism together.
Thanks again,
Stu Boyd
Frank Canale
Hi Stu, my mechanism is original. I am fortunate that it was intact. The vent lid did have some damage that has been repaired. The hinge pin has been replaced and the attachment point for the lifting mechanism has been spot welded to the lid. Frank
tinman58 TR2/3/3A Vent tube Triumph 3
M 1275 Timing Cover Vent Spridgets 2
T TR2/3/3A Vent lid Mechanism Triumph 6
B For Sale BaulyCars - Scuttle Vent Cover Triumph Classifieds 0
Bayless How to repair broken vent window studs? Spridgets 1
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
D BT7 Air Vent Control Cable Routing Austin Healey 0
T Early BJ7 Vent Window Seal Austin Healey 2
volunteer Wanted Need Door Seals, Vent Window Seals and Trunk Seal for Daimler ds420 Limo Jaguar Classifieds 23
B Roof vent position on BN7 hardtop. Austin Healey 15
C TR2/3/3A scuttle vent Triumph 6
A PLATE, handle locking on Vent Window Austin Healey 0
M TR6 Tr6 fresh air vent replacements Triumph 1
T TR6 Air vent rod connection Triumph 1
S TR2/3/3A vent lid rubber Triumph 11
P Rivets on windshield and vent window frame. Austin Healey 1
D Austin Healey side rally vent Austin Healey 10
AUSMHLY Hose, vent pipe to air cleaner, BJ8 Austin Healey 7
P Help With Side Vent Glass Removal Austin Healey 7
Jake For Sale Denis Welch aluminum works shroud scuttle vent scoop - $175 Austin Healey Classifieds 0
M TR2/3/3A TR3 Valve cover vent oil leak Triumph 8
55modified Need photoshop help for side vent options on my BN1 Austin Healey 6
T TR2/3/3A Is this overdrive vent sufficient? Triumph 3
B BJ8 vent window collar fused on Austin Healey 7
N TR2/3/3A TR3 Scuttle Vent Triumph 15
N TR3 scuttle vent FORUM Navigation Questions 1
S TR2/3/3A Smoke coming out of crankcase vent? Triumph 21
Rut TR4/4A Defrost vent finish Triumph 3
T TR2/3/3A Rear Axle Vent Triumph 12
D TR2/3/3A TR3 Scuttle Vent knob removal? Triumph 2
K TR2/3/3A The "air vent"on the lower part of the front apron below the grille.... Triumph 5
K TR3A Air vent under grille on Race Cars? Racing 5
T Post-War Other The Herald front vent windows Triumph 5
T Post-War Other The Herald front vent woindows Triumph 0
J BJ8 Float bowl vent pipes Austin Healey 11
Geo Hahn TR2/3/3A Vent Lid Link Triumph 3
M TR2/3/3A Air Vent Drain Hose Triumph 5
P TR6 Air vent hose clamp Triumph 0
S Question: Works Vent, how to fit Austin Healey 0
P Rocker Cover Vent Spridgets 22
D footwell vent Jaguar 3
T Bugeye Sprite defrost vent installation question Spridgets 18
D TR2/3/3A Demisterr vent routing Triumph 6
O TR2/3/3A Fuel tank vent Triumph 1
C Driver's side defroster vent FORUM Navigation Questions 1
D TR2/3/3A Vent lid link length Triumph 8
N GT6 GT6 I II III Series rear vent window sizes Triumph 4
B TR2/3/3A Vent cowl lid mounting points Triumph 3
M TR4/4A Vent lid fit......is this acceptable? Triumph 11
M TR4/4A Vent lid rod...help please Triumph 3
