TR2/3/3A Dipper switch position
DavidApp
I have installed the dipper switch as it seems it should go but I feel the wires are exposed to damage. Should the bracket be flipped over so the switch is mounted on the flat surface?
The tag was my way od identifying the parts of the loome
David
TR3driver
Great Pumpkin - R.I.P
Yes, I believe the bracket goes the other way.
It should have a hole, so the body of the switch goes inside and just the button sticks out.
But, there were several different types of switches and several different brackets. So its possible yours doesn't have the hole for the switch to stick through.
TomMull
Here's mine:
Dr_Mike
I have exactly the same problem! TS 60014. The later switch can only mount as shown, due to fixed bolts on the body, and the wires are very exposed. Earlier switches, like Tom's, seem much smarter, and are also available whereas the later switches and mount do not seem to be on the market. Is there a solution to this?
My photos are not so good so I will not post them. Help!!!!
6TTR3A
I think the switch,bracket and installation are correct for a post 60K car.
If you route the wires as shown in my photo, it is impossible to step on them.
The switch itself doesn't compress enough and the slanted top & bottom
edges of the bracket complete the "shield' of the wires.
Dipper.jpgFrank
DavidApp
The changes in the mounting bracket must have been cost saving ideas. No hole less work.
Frank
Thank you.
I think that will work. I may try to tie the wires back to the switch mounting screw with a tie-wrap.
David
CJD
My car, 60723 still had the hole. I cannot find a pic of the switch installed (black on black doesn’t take pics well), but I seem to remember fiddling around with it for some time before I got it correct. David, does yours not have a large hole at all?
DavidApp
Hello John
No large hole just 2 small mounting holes for the switch.
Looking at TRF website drawings there seem to be at least 3 types of switch and the same number of brackets.
David
sp53
I second Frank’s picture that is the way the later ones are as odd as it seems. There is a kinda interesting deal/story about the early ones like in Tom’s picture. The rivet is in the center and that is where my foot would rub and because the rivet sits high and the canister is spring loaded if the rivet head wears down the last click will let all guts shoot out and shut the lights off-- maybe that is why they changed. Just a guess.
LionelJrudd
SP53. My first car was a Morris Minor which used basically the same switch. I recall taking my younger sister for a drive one night and joking with her how the headlights could be on high beam or low beam...high beam, low beam... high beam, low beam. Suddenly the whole thing went sproing past our respective ears, ending up in the back seat somewhere. Gave me some pleasure to find the same switch in my TR when I got it.
CJD
In between all those choices is always the "no beam", which always gets you sucking seat cushion!?!
TRMark T-Series Horn/Dipper Switch MG 4
CJD TR2/3/3A TR3 Dipper Switch Triumph 17
mjobrien High Beam Switch Mounting [Dipper] Austin Healey 7
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
R Bugeye ignition switch Spridgets 2
K TR2/3/3A Old school battery shut off switch....... Triumph 3
T TR2/3/3A Replacement Turn Signal Switch Triumph 4
F Wanted Dipping switch cap Triumph Classifieds 1
L What does this column switch do? Spridgets 4
G Brake Light Switch Failure Austin Healey 24
R Wanted Bugeye ignition switch Spridgets Classified 2
B Headlight Dip Switch Austin Healey 4
M Which wires fit which terminals on my Rover V8 ignition switch? Rover / Land Rover 6
R Electrical Experts - Vixen 2500 - Ignition Switch Observation? TVR 10
S Overdrive Throttle Switch Austin Healey 4
SherpaPilot TR6 Ignition Switch Question Triumph 13
Popeye General TR Connecting to Lucas switch grub screws? Triumph 5
C MGB-GT Reproduction light switch MG 13
timsgolf Center Dash Switch Plate Painting Austin Healey 5
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
R Bugeye Starter Switch Spridgets 7
B General MG Remote Starter Switch MG 6
P TR2/3/3A ignition switch smoking Triumph 12
O XKE series 2 thermo fan switch bung stud repair. Jaguar 9
6 E-Type brake light pressure switch location Jaguar 5
C TR6 Ignition Switch for 1972 TR6 Triumph 1
Bocaray TR2/3/3A Headlight Dimmer conversion to dash switch Triumph 6
K TR2/3/3A The two wires that go to the brake light stop switch junction......... Triumph 1
algot1901 1950 Prefect Ign Switch Other British Cars 1
S TR2/3/3A What temperature of electric fan switch do you use in your radiator? Triumph 3
J TR2/3/3A Early Lucas Ignition Switch Triumph 4
69MGC T-Series Never thought I'd switch MG 5
jlaird MGB ignition switch MG 2
F Wanted Foot Dipping switch Triumph Classifieds 0
K TR2/3/3A Dimmer switch.....any electricians out there? Triumph 5
M TR6 Mystery Switch Triumph 0
H MGB 1980 mgb no power from ignition switch MG 23
Gliderman8 TR6 Handbrake warning lamp switch build Triumph 14
old sub sailor Ignition switch / steering lock replacement in a '78 midget Spridgets 5
A Early 1967 AH Sprite - installing steering column and new directional switch? Spridgets 0
S Indicator / Horn Switch Austin Healey 10
nichola TR6 Rebuilder or replace wiper switch? Triumph 7
longbridgehealey Bugeye combination switch Spridgets 2
gbtr6 Wanted: '96 LHD Drivers side master window switch panel. Jaguar Classifieds 0
Hamish Racing TR2/3/3A Remote brake light switch Triumph 5
longbridgehealey Bugeye ignition switch Spridgets 4
T Bug Eye Heater Switch Help Spridgets 2
A BN1 Mechanical Brake Switch Austin Healey 23
P TR6 identifying switch Triumph 3
