Stainless steel exhaust.
Ian R
Hi all, has anyone in the UK bought one of these stainless steel exhausts from SC Parts (item no. 204892)
Seems very cheap at £246 incl. vat. 1 3/4 inch bore.
It's probably £100 or so cheaper than the usual suspects are asking.
Let me know your thoughts...Ian.
steveg
It may be the Falcon - spotty reputation for loose baffles inside after you hit a bump. Wonder what kind of warranty it has.
A good exhaust becomes a lot more expensive if you buy an unsatisfactory one first.
I
Ian R
Yes, that's why I'm looking for reviews. I spoke to the sales team and they assure me that its good quality, (but they would..! )
It's too far for me to go and view so mail order only....
We have a Falcon SS on our BN2/100M. It sounded a little tinny when new, but mellowed with age. No broken baffles, yet, but it's only got a thousand or so miles on it, and I haven't succeeded at clanging it (yet).
I'm probably the only guy on this/any forum that thinks SS mufflers are overkill--but not necessarily a bad thing--on a Healey, for several reasons: 1) our Healeys usually aren't used as 'grocery getters;' when we fire them up we're usually gonna give them a good run and, because of that, we won't have water condensation in the exhaust, 2) given the token ground clearance on Healeys, you are more-than-likely going to bash a hole in a muffler or pipe, which may or may not be patchable and 3) most of the 'free flow' type are of the 'glasspack' variety; i.e. the mufflers are packed with a fiberglass or steel wool, which often is gone long before the pipes or muffler casing, necessitating replacement (if you don't have sympathetic neighbors).
I bought an Ansa exhaust for my BJ8 many (25+) years ago. The mufflers developed dents and scrapes--how could that have happened :wink-new:--but no holes, but the aforementioned fiberglass packing had vacated the mufflers; the pipes were pristine. I spliced some 'HearthThrob' mufflers from J. C. Whitney in there and the muffler is still functioning at over 120K miles, and the pipes are still solid. It has a louder, sharper 'bark' than stock, and sometimes people think I have a V8 under the bonnet, but it's surprisingly quiet and has a pleasing tone--no drone--at 50MPH or better.
bob hughes
I bought a similar one from them many years ago now, and for a similar price, and it could well be a Falcon, and what is left of the original system is still performing well, some of the welds on mine could have been made a bit better. The down pipes did eventually caused me problems a few years ago at the bellows section - they did start to leak and had to be replaced.
The box on mine was real shiny stainless and still is, ( despite the dents caused by speed bumps etc.) all the pipes were dull and are of a different grade of stainless as they do rust with age, but this can be removed with emery cloth - I leave mine as is except for the tail section which does get a little fettling now and again ( martensitic and austenitic and all that jazz) but the original rears are still serviceable despite my attempts to thin them down as I drive up onto my drive off the road, you do get what you have paid for!. Earlier this year I had one of the brackets re-welded on the rear pipes to hold them together as a weld gave out due to the many removals that have gone on over the years, and the bracket at the front of the box snapped ( poor welding resulted in half the bracket being blown away) and had to be strengthened, all for the princely sum of £20 cash but I can not complain, I think that I have had my monies worth, considering the abuse that I have given the system over the years.
:cheers:
Tim Tucker TR4/4A Phoenix Stainless Steel Sports Full Exhaust System Inc Manifold experience Triumph 3
B Stainless Steel Exhaust System Wanted Austin Healey 5
AngliaGT MGB-GT TT Stainless Steel Exhaust Re-Installtion Suggestions MG 2
DornTRoriginal TR2/3/3A Stainless Steel Exhaust Installation Triumph 4
Rob Glasgow Tourist Torphy Stainless Steel Exhaust Systems Austin Healey 27
Jeepster Mixing stainless and mild steel exhaust Austin Healey 5
60TR3A What's The Recommended Stainless Steel Exhaust for '63 BJ7? Austin Healey 5
C BJ8 Stainless Steel Exhaust - throaty sound ? Austin Healey 4
af3683 TR2/3/3A TR3 Stainless Steel Exhaust Triumph 5
Frank C. Stainless Steel Exhaust Austin Healey 6
R Stainless Steel Exhaust system Austin Healey 14
G stainless steel exhaust Austin Healey 14
S Stainless steel exhaust Austin Healey 30
S BJ8 Stainless Steel Exhaust Austin Healey 7
Carlos TR4/4A Stainless Steel exhaust on a TR4A Triumph 6
S Falcon Stainless Steel exhaust info needed. Triumph 3
Guido36 Stainless Steel Bumpers Austin Healey 5
BoyRacer Best-Sounding Muffler - Stainless Steel or Mild Steel? Austin Healey 9
B Electrochemical cleaning of stainless steel welds Restoration & Tools 7
bighealeysource Installing stainless steel brake hose on BN2 Austin Healey 5
G For Sale Stainless Steel TR6 Bumpers Triumph Classifieds 0
J General Tech Stainless-steel caliper pistons Triumph 8
TulsaFred Polished stainless steel bumpers? Spridgets 13
S TR2/3/3A radiator pipe in stainless steel Triumph 5
bighealeysource Installing new stainless steel beading on BN2 Austin Healey 4
T Stainless Steel Fender Beads Triumph 1
J TR2/3/3A stainless steel rear spring pins for TR3 Triumph 19
RJS Stainless Steel Bumpers Triumph 11
T TR4/4A Stainless steel brake lines for a TR4a Triumph 12
T Regular vs stainless steel pistons for calipers Triumph 13
S Spitfire Stainless Steel Spitfire Bumpers on ebay- Info Triumph 7
T Stainless steel brake hoses - two questions Spridgets 13
T Let's talk about stainless steel brake lines... Triumph 4
bighealeysource Installing front fender stainless steel beading Austin Healey 4
Brosky TR6 Stainless Steel Bumpers for TR6 Triumph 20
Tinkerman Stainless Steel Tenon Plates On Ebay Triumph 1
N Who supplies Stainless Steel lines for clutch? Triumph 12
LuckyLuke Stainless steel battery trays Austin Healey 1
I Stainless Steel Fasteners? Triumph 10
G Braided Stainless Steel Hydraulic Hoses Austin Healey 15
Frazier Stainless Steel Polish Restoration & Tools 1
Y Stainless Steel Brake Lines Austin Healey 4
M XJ8L Stainless steel problem Jaguar 2
7 For Sale Stainless trim for Herald Convertible top. Triumph Classifieds 0
I TR6 How to distinguish between stainless and aluminum Triumph 6
E Moss stainless exhaust offering. Austin Healey 28
Gliderman8 TR6 Stainless oil pressure line install HELP! Triumph 8
T Rattling stainless muffler Austin Healey 10
B Stainless hood / bonnet and trunk / bood support rods Austin Healey 2
drambuie Getting a better deep throaty sound from my Stainless exhaust Austin Healey 5
