TR2/3/3A Question: front inner wings
Frank Canale
Started repairing the front inner wings and noticed the driver side(LHD) has slots at the front 5 outer wing mounting points. The passenger side has only holes to mount the outer wing. Is this correct or do the slots need to be filled with a patch and drilled for holes to match the passenger side. I know it is not seen but I am more interested in it being correct even if it means a little more work. Thanks in advance, Frank
CJD
The early wings had round holes. Later, the wings used elongated holes for mounting, so it very much depends. If you give a bit of information...like the TS number, we can make a more educated assessment. It would be even better if you could post a pic or two, so we can tell if it is PO damage or factory slots!
F
Frank Canale
My car is a 1960 TR3A ts61324. I have looked thru current pictures and do not have any. I will try and get some next week.
TomMull
I don't think it's all that rare to have both styles on the same car. Mine, TS73117, has the elongated holes on the left and the round ones on the right. I found another on line, Ben's TR3, that is just like mine https://bens-tr3.blogspot.com/ (the picture is toward the end). At any rate, nothing that you need to correct, at least in my opinion.
You'll have to trust me since I couldn't get far enough back to get both wings in one picture.
Tom
DavidApp
Seems to be a pattern.
Holes on the Right and slots on the right. Looking at my slots you can see the remains of the hole. Do not think it is PO work as it is too regular.
May be to help with body alignment.
David
F
Frank Canale
Thank you for confirming what I believe to be true. I took on this project not realizing how much bad repair work can be done in a 58 year period. My first thought was someone had done it to make some other problem work. It is refreshing to find a group that has vast hands on experience that can be tapped into by a novice restorer. Thank you for the help!
CJD
My TR3 had holes right and slots left. I still tend to think the slots were a later development to aid with alignment. But it’s just a guess on my part.
TomMull
David
I agree that the elongated holes probably aided alignment but why only one side? I wonder if the elongated holes were always on the drivers side? Perhaps the home market RHD cars are reversed.
It would also seem that your inner wing was punched twice and slightly out of alignment at that. Seems unlikely that they were drilled at a later date but possible, I suppose.
Tom
mgedit
Took a while but I finally found a picture of my 56 during restoration as a point of comparison. Fairly early car, and holes on both sides are round. Cheers, Mike
TomMull
Confirms John's statement earlier. I'm guessing the longer holes were introduce to speed up production. Still curious about why only one side.
Nice looking body. Is that powder blue?
Tom
T TR6 Question on TR6 lower front inner wishbone bracket Triumph 1
T TR2/3/3A Question on TR3A front body mounting Triumph 6
nichola TR6 Transmission front seal replacement question Triumph 8
bighealeysource Question on 100M front brake cylinder Austin Healey 4
Tybalt Spitfire Spitfire vs GT6 Front Hub Question Triumph 0
warwick-steve Front suspension rubber trunnion bearing question Austin Healey 4
G TR4/4A Front Parking Lamps Wiring Question Triumph 5
D Front suspension question Austin Healey 0
RickPA Front grille/cowl fitment question Austin Healey 5
R Question-Mounting front shoud Austin Healey 5
K TR2/3/3A Front end Question.... Triumph 4
C TR2/3/3A Question on assembly of front suspension Triumph 3
T TR4/4A Who is running Good Parts front springs on their TR4a? I have a ride height question. Triumph 1
2billydavies TR2/3/3A Question about front turning blinker wires Triumph 12
Jim_Gruber Steering Rack Question / Removing a stubborn Front Shock Bolt - Progress on Bugsy II Spridgets 11
R BJ7 front hub shim question Austin Healey 18
Tinkerman TR2/3/3A Front turn signal wiring question on my post 60000 TR3A Triumph 8
Tinkerman TR2/3/3A Front wing question Triumph 3
drooartz MGB-GT Question - removing front bearings MG 2
T TR2/3/3A Question on shape of lower back of front fender Triumph 7
sim Rebuilding Front Suspension 58 sprite spring question Spridgets 6
Tinkerman TR2/3/3A 1960 tr3 a petrol tank front millboard question Triumph 6
T TR4/4A Question on mounting front flasher lights Triumph 6
doughairfield TR4/4A TR4 Front sway bar install question Triumph 9
cmc140 Austin-Healey 100 front splash pan / splash shield question. Austin Healey 8
TR4v8 TR4/4A tr4 front suspension question Triumph 2
C question on the front brake lines for BJ8 Austin Healey 2
T Question on removing drivers front lower wishbone Triumph 7
BillD Bug Eye front drum brake question Spridgets 12
nevets front brake hose question-BN6 Austin Healey 18
JFeher TR2/3/3A TR3A Front Suspension question Triumph 3
S Spitfire Question on front calipers 1973 spitfire part Triumph 9
S Spitfire Question front shocks and springs for 73 spitfire Triumph 5
S Spitfire Question on front Hub for a triumph Spitfire. Triumph 4
H English front tag install question MG 13
M_Pied_Lourd TR2/3/3A 3A Front Apron Question Triumph 17
rkep01 Question about front cover on smooth case trans Spridgets 5
MY66AH Front end question Spridgets 9
Willie_P TR 3/4 Front Hub Install - question Triumph 15
M Front Suspension Question with Pic Triumph 4
ekamm Tr 3 front suspension parts question Triumph 7
T Question on front floor section Spridgets 14
R TR6 Front TR6 Suspension Question... Triumph 7
DWeeB Front Springs Question? Spridgets 6
Tabcon Front Brake Question Triumph 2
Tim Tucker Front Shock question Triumph 3
T Wobble in front wheel - and related question Spridgets 9
G Front Suspension Bushings Question MG 3
tomshobby front wheel bearing question. Spridgets 9
JPSmit Question one front end puddles Spridgets 3
