TR6 tight suspension
pdplot
When I get together with other TR6 owners, I grab the bumpers and push down and up. Other 6's move up and down about at least 2 inches. Not mine. I have about 1/2 inch of suspension travel, front and rear, if that. Rides like an old Morgan. Dead springs? What else could it be?
TR3driver
Great Pumpkin - R.I.P
My first thought is that someone has "upgraded" the springs. Lots of folks object to the relatively soft stock ride of a TR6, and install stiffer "competition" springs.
Could be binding pivots or a very unusual failure of the shocks, but I would look at springs first. Also check the bump and rebound stops while you're under there. Should be roughly equal clearance with the weight of the car on the suspension, but ill-considered changes (or sagging springs) may have changed that.
P
pdplot
Only thing I know is that one PO bought a front spring from TRF in 1986. Invoice says "stock grade". Price - $32.50.Why only one? Who knows. I have a rear tube shock conversion but it was tight even before that. I believe the other 3 springs are original to the car, as are the front lever shocks. How can I tell if the springs are shot? Is there a test?
TR3driver
Only ways I've ever seen a coil spring fail are by sagging, or breaking. Either way, your ride height would be low.
malbaby
I agree with "TR3Driver"..most likely PO has fitted competition springs.
I do not believe springs can die.
What does your ride height look like.
PatGalvin Front Suspension Too Tight? Triumph 26
MikeAH100M BN2 Tight Steering Austin Healey 4
M TR6 76 TR6 Brakes too tight Triumph 10
P TR6 Tight window crank Triumph 9
B Excessively Tight Steering Austin Healey 19
Phil73 TR6 VERY tight Tie Rod ends Triumph 1
S TR2/3/3A OMG problem—the doors are too tight Triumph 12
T TR5/TR250 Wiper wheel box knurled end not tight on arm Triumph 9
maxwedge5281 steering tight in center position of steering wheel Austin Healey 2
Got_All_4 TR6 TR6 engine rebuild. Too tight? Triumph 23
L Tight spot on steering box is way off Austin Healey 18
TomMull TR2/3/3A New Top Too Tight Triumph 14
Martinld123 Grease Retaining Cup Not Tight Fit Austin Healey 2
wkilleffer MGB Fitting a new top to a 74 MGB- how tight is too tight? MG 23
A rear brake drum too tight after rebuild Austin Healey 3
M General Tech Knockoffs way to tight Triumph 16
Joe Reed General Tech Starting a screw in a tight location... MG 9
KVH General Tech Transmission Drain Plug Too Tight? Triumph 5
S TR2/3/3A paint tight spots Triumph 7
M Tight steering. Austin Healey 5
S Eared knock-offs - how tight? Austin Healey 19
DornTRoriginal Is the sprocket on the camshaft supose to fit so bloody tight? Triumph 4
H top trunnion too tight Austin Healey 3
H hood-tight fit-advice please Austin Healey 4
Tinkerman TR 3 Valve Cover nuts - how tight Triumph 13
T TR2/3/3A TR3A tight steering/silent blocks Triumph 8
M Exhaust Clamps a Tight Fit [pics] Triumph 7
G OD of inner spring is tight to ID of outer spring Triumph 3
R Stromberg adjustment screw tight 175CD Triumph 10
F Tight Crankshaft [engine reassembly] Spridgets 45
D How tight should the steering wheel nut be? Triumph 20
S TR2/3/3A tr3 door too tight Triumph 1
Morris Not at all water tight... Spridgets 12
RJS Wire Wheel Knock Offs - How Tight? Triumph 15
I TR6 TR6 trunion help - how tight, correct lubricant? Triumph 24
1 tonneau too tight Spridgets 19
Atrus Drum brakes too tight? Spridgets 7
SpannerMan Importance of tight dashboard fastenings Triumph 1
john_j Lever for making tight turns? Austin Healey 12
sultanoswing T-Series Removing Rear Hatch - tight screws!! MG 1
L how tight for roll bars? MG 2
M Wire wheels - how tight? MG 3
Patton How tight should the fan belt be? Austin Healey 8
M TR2/3/3A Rebuilding suspension Triumph 29
K TR6 Rule of thumb for frt suspension shims Triumph 6
mctriumph TR2/3/3A Front Suspension upgrades for the 59 Triumph 10
drooartz MGB Front suspension rebuild is next MG 57
Joel Lester TR2/3/3A What final front suspension torque settings needed? Triumph 7
Racer-X- Special Suspension tools 18G95 and 18G78 British Motor Corp 1
