TR6 Heater Control Valve
edkap2002
Hello, It is now time for me to replace all hoses and the heater control valve....all, if not most, have been in place for 47 years.
Looks like all the hose clamps will have to be cut off with a Dremel tool as the rust has taken over the screw heads. I put an adjustable wrench on the stem fitting on the heater control valve and it did not budge! I'm afraid to put too much pressure on it for fear of breaking/cracking it or the block. I really felt solid. Any advise???...thank you as always....Ed
TR3driver
Great Pumpkin - R.I.P
I would probably start by dosing the joint with PB Blaster every few days for a couple of weeks. Then at some point, I'd probably go ahead and break it off. Then either drill & retap the street ell, or buy another one. The ell should come out of the head more easily (tho ISTR you have to remove the rocker cover).
When you reassemble, use some teflon pipe dope on the threads, so they will come apart easily next time.
TR3driver
PS, you won't find them at the usual parts stores, but places like McMaster Carr do carry hose clamps that are entirely stainless steel rather than just the band. I got annoyed at the screws rusting, so I've been slowly converting.
Eg, https://www.mcmaster.com/#54155k21/=1e4h7pw
Alfred E. Neuman
In addition to the PB Blaster, I'm a big fan of shocking threads with (slight) impact to get them to cooperate. Sneaking up on maximum torque will break threaded connections and tools much more easily than applying a "snap" load to the fitting, so long as you're not applying 1/2" pneumatic impact wrench level forces to it. A quick tug on the wrench, or smacking the wrench with a hammer is about as high as I would go, force wise.
One thing I did to get some extremely stubborn head studs out of a TR3 engine was build a little dam out of modeling clay around the stud. FILLED that thing with PB Blaster and let it sit. Tapped the top of the stud with a hammer to shock it every day or so. After less than a week the thing came right out.
edkap2002
edkap2002
Thanks for the advise.....I am going to look for PB Blaster tomorrow...stay tuned...hopefully I wont end up crying out loud
KVH
After all the lube, be sure your spanner fits snugly to the heater valve and that you're rotating with force square to the fitting. I've had that scare, but never a problem. On occasion I've had that the little pipe fitting come out with the valve. In fact, I think I preferred it that way once.
smaceng
I little heat from a propane torch is one of my last resorts before I break something off. Also, don't just try to turn it c'clockwise. Go clockwise first, then c'clockwise. One direction then the other. Baby steps, is how I do it.
Gliderman8
Ed, you might want to replace the original valve with this.
https://www.amazon.com/Four-Seasons...&ie=UTF8&qid=1534103552&sr=1-1&keywords=74648
https://tr6.danielsonfamily.org/HeaterValve.htm
No need for hose adapter from 1/2" to 5/8" just rub some oil inside the hose and on the barb of the valve.
I have this heater valve on my 6 and it is so much better than the original. Also, I removed the detent ball from the control cable. Now I have infinite control of the valve.
KVH General Tech Heater control valve/cable Triumph 1
H BJ8 Heater Valve/Control Tap Austin Healey 3
Lutz Kramer Heater Control Valve function Austin Healey 2
T TR4/4A Heater control valve - cant completely turn off Triumph 3
G Heater Control Valve AH BJ7 - O-Ring Placement[s] Austin Healey 2
S TR4/4A Replace or rebuild heater control valve? Triumph 5
N Spitfire Fastners for mounting heater control valve and bracket Triumph 12
jharrison77 Broken Heater Control Tap [valve] Austin Healey 9
D '65 Spit heater control valve Restoration & Tools 1
J TR4/4A TR4A Heater Control Valve Question Triumph 4
GBRandy Wedge TR8 Heater Control Valve Triumph 7
eschneider anyone seen this heater control valve? Other Cars 6
Stinger TR4/4A TR4A Heater Control Valve Question Triumph 1
Stinger TR4/4A TR4A Heater Control Valve Help Triumph 10
Magyar Leaking Heater Water Control Valve Spridgets 4
58Custom Heater control valve. Suggestions? Spridgets 39
Steve1970 Heater Control Valve Assembly Triumph 7
BobbyD New Heater Control Valve Triumph 15
2wrench Heater control valve and spigot install Triumph 20
Jim_Gruber Heater Air/Valve Control Cable Spridgets 2
VelodromeRacer Leaking Heater control valve Austin Healey 5
R TR6 Heater control bezels TR6 Triumph 2
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
S Heater and fan control replacement - any advice? Austin Healey 9
B TR6 Removing the ckoke/heater control knobs Triumph 4
KVH TR4/4A Shortening the Steel Wrapped Heater Control Cables Triumph 2
Rut General MG Heater/air control MG 0
Jim_Gruber Heater Knob/Control Switch for BE Spridgets 36
H heater control panel and knobs Austin Healey 1
S Choke & Heater Control Knobs Triumph 2
W Heater Control Tap Spridgets 3
Steve1970 how does the heater control plinth connect? Triumph 4
H Heater control question MG 3
Stewart heater control cable lenth? MG 0
S removing knobs from heater control etc Triumph 4
Shealey How to repair a rusted heater control cable W/Pics Spridgets 0
jhorton3 Heater Control Cable Spridgets 2
Jim_Gruber Heater Control / Knob / Cable needed Spridgets 2
2wrench Is this Heater Control Cable broken? Triumph 6
Dave Richards Stuck heater control lever Austin Healey 4
I TR6 69 TR6 heater control cable Triumph 6
S Heater Control Panel ["Why don't it fit?] Austin Healey 14
Musicman Installing Heater Control Cable Triumph 3
Wana Anyone replaced heater control panel in BJ8? Austin Healey 3
jerrybny TR6 Heater Control Plinth Light for 73 TR6 Triumph 1
Rob Glasgow Heater Control Panel Austin Healey 1
A TR6 TR6 Heater Control Question Triumph 4
B TR6 Heater core Triumph 0
E Heater install Spridgets 2
R 3000 Heater Valve Austin Healey 4
