65 XKE FHC Rea Hatch Door
Menderandy
Restoring a 65 FHC. The rear hatch door had the paint and primer removed by being dipped in a chemical solution. I do not know what the solution was. I cleaned the exterior of the door using PPG DX 579 Metal cleaner. I thoroughly rinsed with water. Then used SX 520 Metal conditioner and again thoroughly rinsed with water. Allowed it to dry and sprayed it with two coats of PPG epoxy primer. I noted the interior section between the door hatch skin and the door hatch frame is bare metal. Unless I address this it will rust from the inside out. I was thinking of taping the holes up and swishing the metal cleaner around and flush with water. The same with the metal conditioner. After allowing to dry take the epoxy primer thin it a little with acetone and swish it around to cover both interior sides between the door skin and door frame. Other than being really messy I don't see too many issues. Any thoughts, ideas, recommendations or suggestions ?
Mender Andy
LarryK
I would spray Eastwood"s incapsulator inside the frame before I would do anything to induce water to clean. The encapsulator merges with the rust (if any) and prevents it from growing and is paintable. It will repel moisture and if needed the hoses furnished can be used on a spray can to coat the inner frame. What I would do to prevent cutting door apart and cleaning and rewelding and still have to spray.
M
Menderandy
Larry K,
Many thanks for the feed back on Eastwood's incapsulator. I will go on their website and check it out. This sound like it could save me a lot of work and consternation. Many thanks once again Larry.
Andy
P XKE series 1 FHC windshield installation ?? Jaguar 4
Deanrobert Xke series lll cooling issues Jaguar 5
C Wanted 1970 XKE power steering pump. Or substitute? Jaguar Classifieds 1
CJRams For Sale 1969 Jaguar XKE Jaguar Classifieds 0
O XKE series 2 thermo fan switch bung stud repair. Jaguar 9
BritBite XKE BRAKES Jaguar 1
B For Sale 1968 XKE Roadster 1.5, 4.2 Jaguar Classifieds 0
wangdango '67 XKE Mallory dulal point to Pertronix Jaguar 0
M XKE Coupe series 1 Tub versus series 1.5 Jaguar 1
M XKE Bonnet Restoration Jaguar 5
C Garage find '65 XKE Jaguar 12
wangdango '67 XKE rear diff? Jaguar 2
B For Sale 1969 Jaguar XKE 4.2L Series II Coupe - Indiana Jaguar Classifieds 0
wangdango XKE clutch flex line/firewall? Jaguar 1
C Brake issue on my 1969 XKE - what to check first? Jaguar 14
C Mounting ignition switch to XKE series 2 steering column? Jaguar 4
Paulus Thermovacuum switch for a 1973 V12 XKE Jaguar 4
T Need some coaching on is a XKE project Jaguar 6
E Jag xke chassis number 885616 Jaguar 1
F XKE SIII Drivers Door Mirror Knob Jaguar 1
B Looking for some XKE series 2 parts Jaguar 0
Marvin Gruber Eagle XKE Jaguar 2
T Sourcing a correct engine for a '71 XKE Jaguar 14
AH67 1E120049 1966 Jaguar XKE Roadster Jaguar 1
K TR2/3/3A Putting an XKE engine in a TR3? Triumph 10
tlthorne anyone with a 69' XKE convertible in pcs??? Jaguar 2
tlthorne Looking for a source for the fasteners for a XKE Jaguar 7
K Problems with Bleeding the Brakes onan XKE? Jaguar 2
HealeyDave '64 XKE Series 1 on Craigs Jaguar 5
aeronca65t XKE racer Jaguar 1
H 1969 Jaguar XKE - Oil Jaguar 7
HCE Waking up and XKE Jaguar 16
J XKE series II S/Z carbs hot start woes Jaguar 1
B 74 xke front bumpers Jaguar 1
DrEntropy A nekkid XKE!!! Jaguar 6
HCE What is a fair price for a ’69 XKE? Jaguar 19
Marvin Gruber 1962 OTS XKE Jaguar 11
S XKE Accelerator Ppedal Position Jaguar 2
A XKE Series II Stromberg Carb Upgrade Jaguar 4
H What to look for in a restored Series 1 XKE coupe Jaguar 9
G XKE rear wheel bearing replacment Jaguar 4
A '63 xke suspension Jaguar 6
Gray_Cat 71 XKE V 12 & 70's Spitfire Spotted 0
S xke sugar scoops Jaguar 4
wangdango XKE series 1 lower radiator pipe size? Jaguar 1
V IRS selling a '73 XKE V12 Roadster Jaguar 0
D XKE and TR3 Spotted 0
T XKE S2 OTS Driveline Whine Jaguar 2
T XKE S2 - Brake Reservoirs Jaguar 3
T XKE S2 - Cigar Lighter Mounting Jaguar 3
