Randomly replacing parts isn't a good way to fix electrical problems. Better to troubleshoot it methodically.
Start by measuring the voltages at the powered side (i.e., not the distributor side) of the coil with the ignition on. If you don't see battery voltage, work back toward the switch and find where you are losing the voltage. That will tell you where the bad part or connection is.
If that's OK, disconnect the wire from the coil to the distributor and put an ohmmeter on the distributor connection and ground. Turn the engine over, and you should see the resistance vary from a short to an open circuit as you crank. A powered test lamp works OK for this, too. If this doesn't check out, the points are shorted somehow, probably installed wrong or a conductor is touching something it shouldn't.
Use the ohmmeter to check the coil for an open circuit. You should see a few ohms, at least.
If all these check out, the primary circuit is OK. The only remaining possibility is a bad capacitor--new ones are garbage--and that's hard to test.
To check the secondary circuit, hold the high-voltage cable from the coil center terminal to ground and see if you get a good spark while cranking. If not, and the primary checked out OK, probably a bad coil or wire. If so, do the same with individual plug wires. If nothing at that point, probably something is bad in the cap or rotor.
High-voltage problems can be as simple as a wire that isn't pushed all the way into the cap or coil connection. Don't discount simple causes.
