BT7 furflex/rubber door seals
Lin
When I restored my car about 10 years ago (cannot believe that it has been that long!) everyone was complaining about the quality of the door seals. MacGregor in Canada started manufacturing and selling a superior product that I used on my car. I was quite pleased with the quality. However, after 10 years the rubber is beginning to crack in a few places and I would like to replace them. Do I recall correctly that Moss or another U.S. vendor now sells the MacGregor product? Thanks for any helpful advice.
Lin
Healey Nut
Autofarm in Canada stocks the Macgregor door seals .
Keoke
Years ago I too went through the door seal fiasco, if you want correct door seals go to Macgregor.
I worked sometime introducing his product to our local Healey enthusiasts.
andrea
Hi Lin
Rubber can be easy saved ( if don't seriously damaged) with a gentle touch of Vaseline application
Cheers 14-15102017Esposizione_Piazza_Unita (11).jpg("new" car on works)
gonzo
Here's a basic question about cutting furflex: what is the best way to cut these to size and keeping clean cuts. I ordered a set of Britflex / Furflex from MMs only to find them too short with the end sections frayed and splayed. In a word, unserviceable.
This time I'm buying from another supplier. Any suggestions are welcomed. GONZO
Michael Oritt
As I recall the advantage to Martin's product when he introduced it was that it would stay clamped on whereas the metal in the seals that Moss and others sold was too flexible and eventually fell off, etc. Is that still the case?
Editor_Reid
Platinum
BCF policy is that you address vendor problems with the vendor. Doesn't sound like you've gone back to Martin to let him know that the two lengths of his product, Bristleflex, were cut too short.
If the pieces you received were too short, as you state, then why would you come here to ask how to cut them cleanly? No matter how many times or how cleanly you cut them, they'll still be too short. Therefore your question looks like nothing more than a premise to vendor-bash.
Let's get this back on track. Deal with the vendor to resolve the matter. If you're determined to use a different product and looking for a recommendation for one, there's no need to recount your frustration with the previous vendor. Thanks.
maxwedge5281
i started to install macgregor bristleflex in my bn6 today. each side is about 8 inches longer than necessary. i dont know how i will cut it! a superior product in my estimation.
Michael Oritt
I'd appreciate someone answering my question: Is Martin MacGregor's product superior in the manner that it grasps and holds onto the sheet metal as was once the case or are the products from the various vendors pretty much the same?
maxwedge5281
i have used it on the last three healeys that i owned. i have no experience with other vendors but it has never come loose once installed. limited experience but really grips well. he makes his own product and I believe that he does sell to other vendors.
Healey Nut
The Macgregor product is far superior in the way it grips and stays gripped to the standing seam .
It also seals better as it has a larger sealing bulb section that squishes when you close the door .
I wouldn’t use anything else .
The only issue I have with it is the rubber end caps dont exactly match the profile of the seal . This may have been corrected since I last bought some ???
As for cutting it I found sheet metal cutters worked the best . Cut it slightly long by 1/4” then snip away till you reach the correct length . Make sure your cutters are really sharp .
steveg
MacGregor's product is called Bristleflex. I installed it >10 years ago when it first came out and was very happy with the results. The metal component is steel; the Furflex was aluminum and wouldn't stay attached to the metal edges.
Addendum: According to the Moss catalog, Furflex now has a steel structure.
The bulb on my driver's side door has split and I will also be replacing.
Addendum: when MacGregor introduced Bristleflex, there were two types of trim available: 1) steel structure but the bulb was too big; 2) weak aluminum structure with correct bulb diameter. Bristleflex had steel with the correct smaller bulb diameter.
Novamonte
Hi Lin
CheersView attachment 54793("new" car on works)
I have not tried Vaseline to revive rubber seals, but a 50/50 mix of white spirit and glycerine works very well on tired rubber seals. If you want to go more advanced, start with a mix of 80 white spirit/20 glycerine and rub it in well, continue with gradually more glycerine/less white spirit and do it over a period of several days.
gonzo
I'll try practice cuts before committing to final cuts to avoid splayed and frayed ends.
I can't explain why I'm so O.C about this particular trim piece and wanting it perfect. Perhaps its the fact that BJ-7s and 8s don't have aluminum / chrome finishing pieces like the earlier models and as a result, look fussy and "unfinished". Thanks for all the suggestions, GONZO.
HealeyRick
There is a small chrome clip that fits at the end of the furflex behind the doors: https://mossmotors.com/clip-door-seal-end?assoc=8277
G Crane XR700 Electronic Ignition / BT7 Austin Healey 6
J Wanted Hood (Bonnet) for a 1960 BT7 Austin Healey Classifieds 0
J BT7 Hardtop Crosspiece Wanted Austin Healey 5
M Wanted WANTED: Hardtop (Factory) for BT7 Austin Healey Classifieds 6
kodpkd 1961 BT7 engine oil Austin Healey 31
H Lucas Starter Model for 3000 Mark II, BT7 Austin Healey 3
D Healey 3000 BT7 rear panels Austin Healey 0
D Gearbox Dipstick (BT7) Austin Healey 3
D BT7 Air Vent Control Cable Routing Austin Healey 0
D Rear Seat Side Panels, BT7 Austin Healey 3
F BT7 Stalling Austin Healey 9
apbos BT7 Hardtop For Sale Austin Healey 0
D BT7 Grille Attachment Austin Healey 11
D BT7 Choke Assembly Austin Healey 18
D BT7 Rear Side Panels Austin Healey 0
D For Sale BT7 interior door cards - new ! Austin Healey Classifieds 0
57 Healey For Sale Original top (hood) frame for BT7 Austin Healey Classifieds 8
Healey Nut BT7 Windscreen Pillars Austin Healey 4
Fanch00 My 1960 BT7 History Search Austin Healey 1
Healey Nut BT7 Parts Identification Austin Healey 3
MadRiver BT7 Wiring Diagram Austin Healey 4
Healey Nut BT7 Panhard Rod Austin Healey 28
Healey Nut BT7 Rear Suspension Austin Healey 15
J Attaching BT7 Dash Facia Panel Austin Healey 2
S Grill cowl top piece for AH 3000, BT7, $65 Austin Healey Classifieds 0
R 3-point seat belts on late production BT7 MKII Austin Healey 7
T BT7 throttle relay levers short and long Austin Healey 2
C 1960 BT7 Thoughts Austin Healey 14
CLB62 1962 BT7 Tri-Carb for sale on BaT Austin Healey 2
Lin Tach drive housing for BT7 Austin Healey 4
S For Sale Austin Healey 3000 and 3000 MK II Factory Parts Manual - BN7 & BT7 on CD/ROM Austin Healey Classifieds 0
T BT7 Hardtop Restoration Austin Healey 6
dougie BT7 Video Austin Healey 8
F Exhaust Fumes in the Cockpit - BT7 Austin Healey 10
B For Sale Brand New Black Tonneau Cover for BN4 and BT7 - for Right Hand Drive Car Austin Healey Classifieds 0
Michael Oritt Lube points on BN/BT7 front end Austin Healey 4
B BT7 Door Seal Installation Austin Healey 13
S For Sale RARE FIND BN2-BT7 and? Trans Parts for Sale Austin Healey Classifieds 2
AUSMHLY 1962 3000 Mk II BT7 speedometer Austin Healey 2
B BT7 Grille surround Austin Healey 9
F Dynamo not charging [BT7] - replace brushes or buy new? Austin Healey 24
M engine stutter of rebuild BT7 engine [tri-carb] above 2500 rpm Austin Healey 27
R BT7 Carb floats Austin Healey 1
F Three worn hubs and wire wheel centers - What to do next? 1960 BT7 Austin Healey 6
Healey Nut For Sale BJ8 and BT7 parts for sale Austin Healey Classifieds 62
CLB62 1962 Austin Healey BT7 Mk II Austin Healey 15
F Heater pipe and air duct routing BT7 Austin Healey 3
BoyRacer Tips on gluing new fabric to dash on my BT7 Austin Healey 10
F Help need reinstating my heater - BT7 Austin Healey 7
