Soft Top Boot Cover - BJ7
BG 62AH
Guys,
Just bought a new vinyl boot cover for my soft top. This cover has some lining sewn into the inner area, I presume to protect it from tearing.
The issue that I am having is that it seems to be an extremely tight fit...At Best, and almost too small. It doesn't seem to me that this lining can be removed, but it does seem to restrict stretching the material so it can be attached properly.
I was wondering if anyone else has run into this, or has any suggestion on how to get it to fit.
Any suggestions are greatly appreciated.
Thank you
ozhealey
Bill,
I recall when I first fit my boot cover on my BJ7 it was very tight. At first I struggled to even understand how it could fit at all until I figured out how to fold the top down properly. The result had the soft top around an inch lower when folded. I unzip the window and fold it in first, and then carefully “push” each fold down and neatly in as far as possible. Once I did this, the lower top made the job achievable. The fit was still tight but definately much easier. Tight is actually good in my opinion as you dont want any “flapping” when underway.
The horse hair or coarse padding is actually very good and makes for a much higher quality finish. You can get boot covers and tonneau covers without this padding, however they are not as good quality or fit (in my opinion). I am advised this was how the came from the factory. My tonneau also had this coarse layer of padding and a bright steel heavy duty zip and I loved it. Unfortunately when I converted to RHD, I could not find a munfacturer who produced this quality tonneau. My RHD tonneau is very well built, however has no padding and has a thin black plastic zip.
Cheers
Tony
Bob_Spidell
I still have an original hood boot for my BJ8. It fits tight as well, but it helps to expose it to warm sunlight for a few minutes before trying to snap it down. Maybe a hair dryer or heat gun would help if it's overcast, but I haven't tried it.
As an aside, I've noticed that none of the aftermarket boots seem to fit too well; the one the Wheeler Dealer guys fitted to the BJ8 they flipped was atrocious. For that reason, I've made do by having the rips and tears in mine stitched-up many times.
EDIT: Adding that yours looks to be a pretty decent fit and good quality; would you mind sharing the source as mine will likely fly west somewhere down the line? Also, it appears your new boot did not come with snaps fitted; presumably because they were likely fitted somewhat willy-nilly at the factory.
B
BG 62AH
Thank you very much for the suggestions. I took Tony’s advice and really folded the soft top as neatly as possible. Helped a little. I’ve been working on it during commercials at the British Open. Not done yet, but it seems to be working out a little better than I expected.
B
BG 62AH
Btw,I got it from Moss during their upholstery sale. Was not inexpensive, but the quality seems pretty good.
thank you once again for the suggestions.
S TR6 Soft top material Triumph 10
A TR6 TR 6 Soft Top Triumph 4
C Wanted Early MGB soft top and/or tonneaus, condition not very important MG Classifieds 0
Frameman 1949 Soft Top Webbing Austin Healey 2
KVH TR4/4A Closing the Soft Top Triumph 11
J TR2/3/3A TR3 Soft top speed limit? Triumph 9
Donald1107 TR2/3/3A Soft top Triumph 14
nevets BN6 Soft Top Webbing Austin Healey 2
R BUGEYE SOFT TOP FIT Spridgets 2
C 100/6 BN4 Soft Top Frame Austin Healey 16
J TR6 Hardtop/Soft Top Installation Triumph 2
W TR6 Tr6 soft top lnstall Triumph 5
CharlesBN1 BN1 Soft Top installation - need advice! Austin Healey 3
Bayless Need soft top for Morris Minor Other British Cars 5
D TR2/3/3A Fitting the hood. Soft top. Triumph 6
Graham H TR2/3/3A TR3A soft top Triumph 4
D TR6 Soft Top Selection 1976 Triumph TR6 Triumph 5
H Soft Top Straps Spridgets 2
D BT7 soft top front bow seal Austin Healey 0
warwick-steve BT7 soft top frame location Austin Healey 6
I BJ8 soft top frame dimensions Austin Healey 4
C Top frame pinching soft top - BJ8 Austin Healey 6
R BT7 soft top [hood] question Austin Healey 4
Desert Rat Bugeye soft top Spridgets 2
Marla TR4/4A Soft top frame Triumph 13
Marla TR4/4A Soft top success Triumph 1
Lutz Kramer Soft Top Zippered Window Austin Healey 5
N TR6 found a Soft top frame from a 1972 for sale Triumph 2
John Turney Longbridge BN4 Soft Top Austin Healey 9
tomshobby New way to Install gasket between soft top and windscreen frame. Spridgets 2
sundown TR6 soft top Triumph 3
maxwedge5281 soft top installation for 63 bj7 Austin Healey 1
R 100-4 soft top Austin Healey 5
TR6oldtimer TR6 TR6 soft top frame not aligning with windows Triumph 1
D TR6 76 TR6 Soft Top Triumph 2
A Serious help needed !!!! BJ7 Installing a new soft top Austin Healey 9
T TR2/3/3A Can someone tell me height of roll bar that will allow soft top on TR3A? Triumph 3
andrea LONGBRIDGE cars SOFT TOP -MOD safe water seapage Austin Healey 16
Jeepster Folding soft top frame Austin Healey 7
S Healey BN7 Soft Top installation instructions needed Austin Healey 6
T Soft Top Weather proofing on100 4 Austin Healey 12
M Installing soft top Spridgets 7
W TR6 how to lowering 1972 TR6 soft top Triumph 4
P help: trick to snap and unsnap soft top ? Triumph 11
af3683 TR2/3/3A Correct Procedure to Raise TR3 Soft Top Triumph 7
af3683 TR2/3/3A How to Repair Small Holes in TR-3 Soft Top Triumph 6
A Soft Top cover and Tonneau BJ8 Austin Healey 3
T soft top frame Triumph 2
ScottTR6 TR6 Advice for new TR6 Soft Top Triumph 9
B Rear soft top bow on a BJ7 Austin Healey 15
