Missing grease cap in front hub
warwick-steve
Hi
in the process of preparing to bleed the clutch ( another thread), and on removing the wheel I noticed there was no grease cap in the front hub. I bought a new one but no way was it going to fit into the hub.
Obviously it would be good to have the grease cap in situ but is it absolutely necessary? I can't see how the bearing could be contaminated as the wheel is sealed with grease onto the hub.
I will see if the supplier has a cap with a slightly smaller diameter but if not I will leave "as is"
Thanks
Steve
kozelding
I had the same experience, but only on the left side. I haven't looked to see if the difference between sides is the hubs or the caps....
In any case, I've been meaning to grind down the new cap I have to make it fit, but I haven't yet, and 10k miles later, all seems fine :welcoming: And I agree, unless something is loose that shouldn't be, I can't see how dirt can get behind the knock-offs.
pan
G’day Steve,
the cap is meant to be a tight fit. In the workshop manual it shows a special “grease cap remover” being used which gives an idea how tight a fit they are. When I bought my car in 1968 it did not have any caps and I did not bother to fit any until my 2002-02 restoration. My theory is that if the manufacturer felt they were necessary then they should be used.
Cheers,
Alwyn
I just replaced the wheel bearings on my BJ8 after, maybe, 60K miles of neglect (they showed some pitting). The inside of the hubs were clean, even though I drive my BJ8--but not the 100M--in severe weather (like serious rain and dust storms). Still, I'd want to have the caps in there. My original--AFAIK--caps are still a tight fit (and have the hammer marks to prove it).
warwick-steve
warwick-steve
Thank everyone for that, all good to know,
I guess I will do as you indicated Bob H,i.e. just file down slightly to still get a tight fit. Currently they are definitely oversized.
Bob S, noting you have replaced your bearings after "60K miles of neglect", how many miles would you typically drive before repacking and/or adjusting?
cheers
Steve
Steve, the 60K number was just a SWAG (Scientific Wild-Assed Guess), but it had been at least ten years since I went into the hubs to fix a spun outer washer and I put about 6K miles a year on my BJ8. I think going any more than 50K miles without a repack is risky. Also, the bearing grease was largely gone or dried-up, so this time I'm trying Redline synthetic. NFI, but I've had good luck with Redline products in the gearbox/OD and differential.
Keoke
My understanding of the grease cap is-it is to be packed with grease after the bearing and race so the grease in the bearing if it tends to squeeze out ha no place to go ???
I used to think you should stuff all the cavities in the hub with grease for that reason, but have been disabused of that notion.
T Missing grease nipple on clutch mechanism? Triumph 16
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
P TR2/3/3A 1958 TR3A missing on cyls 2 & 3 Triumph 8
K Missing spring clutch release lever Other British Classifieds 1
Rob Glasgow Missing Graphite Electrode Austin Healey 16
Bayless Missing important part Spridgets 0
bighealeysource Wanted Looking for missing BN2 door and cockpit moldings Austin Healey Classifieds 0
Jim_Gruber Missing Bugsy IV / Transporting a BE on a U-Haul Car Carrier Spridgets 18
TAS525 TR2/3/3A Missing zerk from inner tie rod end Triumph 7
P TR2/3/3A Convertible Top Frame Missing Hood stick advice needed. Triumph 4
T TR2/3/3A Missing bush Triumph 4
G Brake fluid missing Austin Healey 6
R brake master missing seal Austin Healey 11
P TR2/3/3A Missing rear seat back rest/bulkhead. Triumph 7
KVH TR4/4A I Can't Stop Burning Oil; Engine Missing at Take Off Triumph 5
Simmo MGA Missing under load MG 3
B Valve Cover Plate Rivets: Useless junk or am I missing something? Austin Healey 10
S TR4/4A Exhaust manifold missing stud Triumph 8
P Is my shifter bushing missing? Austin Healey 25
J Help with 61 AH Sprite missing parts. Spridgets 3
GTP1960 TR2/3/3A hesitation and missing between 2000 & 3000 rpm Triumph 3
tomshobby Shift knob insert is missing Spridgets 12
KVH TR4/4A Still Learning: I'm Missing, But Only Slightly Triumph 4
richie TR4/4A Missing since rebuild with Pertronix Triumph 9
B Installing New Leaf Springs on 100-6 - Am I missing something obvious? Austin Healey 19
bighealeysource Why is it missing now ? Austin Healey 4
RedTR3 TR2/3/3A Periods of Intermittent Missing Triumph 34
6TTR3A TR2/3/3A MIssing Zerk fitting? Triumph 7
bighealeysource Can't figure out why engine is missing on BN2 Austin Healey 6
J MGB MGB missing and perhaps knocking under load MG 10
angelfj1 TR2/3/3A HELP! Need quick fix for missing bonnet hinge pin. Triumph 5
Boggsy64 MGB King Pins appear fine am I missing something? MG 3
PHerder Door Parts missing :[ Need to beg, buy or steal... Spridgets 0
PAUL161 MGB Strange Reminder of a Missing Friend. MG 4
Parker MGB Headlights won't work after full repaint/restoration... what am I missing? MG 6
S MGB Radiator cap missing MG 1
P New tires, missing spoke Triumph 4
bighealeysource BN2 still missing, think it's carbs not ignition ? Austin Healey 8
mgbmedic Wire Wheel Conversion - What am I Missing? Triumph 11
S TR2/3/3A missing problem with this tr3 Triumph 10
bighealeysource BN2 missing on acceleration Austin Healey 11
H Missing Oil Filter Spring Plate Austin Healey 2
M Missing zerks Triumph 10
judow Is a Registry missing??? Austin Healey 12
jsfbond Missing Plate Triumph 1
E How to identify Healey carbs, Tag missing Austin Healey 1
P Missing grille bar Triumph 3
M Missing at the Olympics Triumph 3
RAC68 The Missing Brake Fluid Mystery Depends Austin Healey 11
F Missing and hesitation, only after a hot start Austin Healey 6
