Results 1 to 9 of 9
Thread: Missing grease cap in front hub
  1. #1
    Jedi Hopeful warwick-steve's Avatar
    Join Date
    May 2016
    Location
    Warwick UK
    Posts
    120
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    Hi
    in the process of preparing to bleed the clutch ( another thread), and on removing the wheel I noticed there was no grease cap in the front hub. I bought a new one but no way was it going to fit into the hub.
    Obviously it would be good to have the grease cap in situ but is it absolutely necessary? I can't see how the bearing could be contaminated as the wheel is sealed with grease onto the hub.
    I will see if the supplier has a cap with a slightly smaller diameter but if not I will leave "as is"
    Thanks
    Steve
  2. #2
    Join Date
    Jun 2010
    Location
    VT
    Posts
    33
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    Re: Missing grease cap in front hub
    I had the same experience, but only on the left side. I haven't looked to see if the difference between sides is the hubs or the caps....
    In any case, I've been meaning to grind down the new cap I have to make it fit, but I haven't yet, and 10k miles later, all seems fine And I agree, unless something is loose that shouldn't be, I can't see how dirt can get behind the knock-offs.
  3. #3
    Jedi Warrior pan's Avatar
    Join Date
    Nov 2005
    Location
    Ipswich, Australia
    Posts
    625
    Thanks Thanks Given
    3
    1
    Thanked in
    1 Post
    G’day Steve,
    the cap is meant to be a tight fit. In the workshop manual it shows a special “grease cap remover” being used which gives an idea how tight a fit they are. When I bought my car in 1968 it did not have any caps and I did not bother to fit any until my 2002-02 restoration. My theory is that if the manufacturer felt they were necessary then they should be used.
    Cheers,
    Alwyn
    Fifty years in one 100, still going strong!
  4. #4
    Join Date
    Mar 2003
    Location
    Hampshire in the UK
    Posts
    1,713
    Thanks Thanks Given
    7
    Thanked in
    Mmmm
    I had the same problem with a new cap I just filed it down a tad.
  5. #5
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    3,627
    Thanks Thanks Given
    1
    32
    Thanked in
    I just replaced the wheel bearings on my BJ8 after, maybe, 60K miles of neglect (they showed some pitting). The inside of the hubs were clean, even though I drive my BJ8--but not the 100M--in severe weather (like serious rain and dust storms). Still, I'd want to have the caps in there. My original--AFAIK--caps are still a tight fit (and have the hammer marks to prove it).
  6. #6
    Join Date
    May 2016
    Location
    Warwick UK
    Posts
    120
    Thanks Thanks Given
    Thanked in
    Thank everyone for that, all good to know,
    I guess I will do as you indicated Bob H,i.e. just file down slightly to still get a tight fit. Currently they are definitely oversized.
    Bob S, noting you have replaced your bearings after "60K miles of neglect", how many miles would you typically drive before repacking and/or adjusting?
    cheers
    Steve
  7. #7
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    3,627
    Thanks Thanks Given
    1
    32
    Thanked in
    Steve, the 60K number was just a SWAG (Scientific Wild-Assed Guess), but it had been at least ten years since I went into the hubs to fix a spun outer washer and I put about 6K miles a year on my BJ8. I think going any more than 50K miles without a repack is risky. Also, the bearing grease was largely gone or dried-up, so this time I'm trying Redline synthetic. NFI, but I've had good luck with Redline products in the gearbox/OD and differential.
  8. #8
    Great Pumpkin Keoke's Avatar
    Join Date
    Apr 2004
    Location
    LosAngeles Calif.
    Posts
    12,475
    Thanks Thanks Given
    6
    Thanked in
    My understanding of the grease cap is-it is to be packed with grease after the bearing and race so the grease in the bearing if it tends to squeeze out ha no place to go ???
    1966 Daimler V8 Saloon; Safely Fast, Built to Last & and; Smooth as Glass.
    1966 BJ8 [ 2 ] Lil Red & Miss bLU
    1985 XJ6 Saloon
    1948 & 70 Lincoln continentals
    1973 Volvo P1800ES
  9. #9
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    3,627
    Thanks Thanks Given
    1
    32
    Thanked in
    Quote Originally Posted by Keoke View Post
    I used to think you should stuff all the cavities in the hub with grease for that reason, but have been disabused of that notion.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
