TR2/3/3A Timing
RonR
Folks,
Folks,
I had the distributer rebuilt on my TR3 by Advance Distributers.
I have spark at the points and at the plugs but the car will not start.
At times, it will backfire out the carbs.
I assume the timing is off.
I set the static timing by having No1 piston at tdc, the rotor pointing to No. 1 on the distributer cap, and the timing marks at the pulley and marker lined up. Then, using a 12 volt light, I rotated the distributer until the light just came on and tightened the distributer. I turned the adjuster knob on the side of the distributer 1/2 turn to advance 4 degrees. I am pretty sure this is how I have always set the initial timing.
But it will not start.
I pulled the distributer, rotated the crankshaft 180 degrees and reinstalled the distributer. Reset the timing, but it did not make any difference.
While waiting on the distributer to be returned, I replaced the front seal in the timing cover. I suppose I could have put the crankshaft pulley on 180 degrees off, but I thought there was a spline/grove alignment for mating the pulley with the crank so people like me could not get it wrong.
The timing chain and associated gears were not touched.
Any thoughts?
Thanks.
Geo Hahn
...I pulled the distributer, rotated the crankshaft 180 degrees and reinstalled the distributer. Reset the timing, but it did not make any difference...
You were thinking perhaps #1 was really at TDC on the exhaust stroke? That is what I thought too.
But the distributor only goes in one way so rotating the crank 180° does not change anything - unless you managed to jam the dog into place in spite of the offset of the slot.
This is how the drive on mine looks at #1 TDC compression (note that the slot is offset, thus the drive dog on the distributor shaft only fits one way):
This is how the dizzy looks in that same position:
If the slot is off then you remove the shaft and reinsert it into the correct position. It is something of trial and error as the helical gear causes the shaft to turn a bit as it engages so you have to allow for that to end up with the fitted shaft in the exact location.
Here is what the manual says about all this:
CJD
Backfiring out the carbs is, indeed, timing off.
You may have replaced the crank pulley assembly in the wrong orientation. It can go other than just 0 and 180 degrees. With a 6 bolt pattern it can also be off on 60, 120, 240 and 300 degrees.
At this point pull the #1 plug and ensure the piston is fully up at the 0 degree timing mark. Then pop the valve cover and ensure both #1 rockers are loose, also at the 0 degree mark.
sp53
I usually put my thumb over the plug hole when spinning the engine so the compression pushes it off showing that both valves are closed and piston is up, but you will have to fine tune that with the valve cove off to see the valves are both completely closed because it never stops perfect and you probably lost your datum point.
K TR2/3/3A How to tell if the timing chain has slipped...... Triumph 12
Got_All_4 TR5/TR250 Timing chain tensioner completely shot Triumph 11
mt10flyer TR2/3/3A Timing Chain Tensioner - again Triumph 13
M 1275 Timing Cover Vent Spridgets 2
waltesefalcon Miata Water Pump and Timing Belt Other Cars 3
K TR2/3/3A Timing chain rattle on start up? Triumph 2
D Cam Timing question. Spridgets 11
KVH General Tech Valve Timing--No Marks Triumph 20
drooartz MGB Question on timing and vacuum MG 11
E Ignition Timing Austin Healey 14
K TR2/3/3A Ignition timing questions while I'm waiting for Spring Triumph 27
56HealeyDan 100-4 Timing and Vacuum Austin Healey 5
K TR2/3/3A Timing marks on pulley? Triumph 10
LAW75 Timing Chain Cover Gasket Austin Healey 12
Lin Ignition timing question Spridgets 2
Kolecki TR2/3/3A engine assembly cam timing issue Triumph 8
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
A Timing cover access Spridgets 6
BN6_2197 BN6 Static Timing Austin Healey 2
vette Timing Marks! Austin Healey 12
J Crankshaft dog nut and timing chain cover removal advice Austin Healey 30
J TR6 73 TR6 Static Timing Questions Triumph 6
P TR6 1970 TR6 Timing Question Triumph 2
TRclassic3 TR2/3/3A Timing and temperature Triumph 13
B TR4/4A New valve gears/timing Triumph 21
K TR2/3/3A Ignition Timing? Triumph 11
K TR2/3/3A The timing mark on the crank pulley.... Triumph 5
M 100-4 Timing Pointer Austin Healey 5
D TR2/3/3A Timing chain tensioner. Triumph 3
KVH TR4/4A No Marks on Timing Gear Triumph 30
Got_All_4 TR6 Newly purchased poor quality timing gear Triumph 5
vette MGB 74 1/2 Timing Specs. MG 16
B Timing Light question Austin Healey 0
F TR6 Timing adjustment Triumph 13
doc50 Metro 1500 Has Slack Timing Chain? Other British Cars 20
Got_All_4 TR6 Timing chain Triumph 10
Got_All_4 TR6 Double row timing chain in a 69? Triumph 2
D BT7 Timing Advance Austin Healey 17
D BT7 ignition timing Austin Healey 5
F TR2/3/3A Ignition Timing - Again Triumph 11
T Even but low compression on 3.8 - timing slightly off? Jaguar 7
B Engine timing Spridgets 8
tinman58 TR2/3/3A Timing ? Triumph 21
Michael Oritt Replacing timing chain tensioner and more Austin Healey 24
DornTRoriginal TR2/3/3A Checking if Timing Chain is Installed Correctly Triumph 6
F TR2/3/3A Timing with Electronic Ignition Triumph 14
D BT7 Timing chain install Austin Healey 2
M Timing Chain on 948 Rebuild Spridgets 1
T can't find timing marks on 1275 crankshaft pulley/damper Spridgets 8
