Results 1 to 9 of 9
Thread: Fusion Frustration
The Pub is: Forum to generally shoot the breeze. It is NOT: a debate forum (NO Politics, religion, or controversial topics.) Keep it clean, fun and lite!
  1. #1
    Yoda AngliaGT's Avatar
    Join Date
    Sep 2005
    Location
    Roanoke,Virginia
    Posts
    8,406
    Thanks Thanks Given
    Thanks Thanks Received
    1
    Thanked in
    1 Post
    Fusion Frustration
    When we were living in an apartment,my Wife had her oil changed
    by a local shop.That was last December,& a notice came up in the dash,
    advising that it needed to be changed again,so I finally got to it,or so I thought.
    It went something like this:
    - Get oil & filter out
    - Jack up car & support the subframe
    - Remove plastic cover for drain plug
    - Crawl under car with ratchet & sockets
    - Put on 1/2" socket - doesn't fit (or loosen plug)
    - Crawl back out from under car,get a 13mm socket
    - Socket won't budge drain plug - even with a breaker bar
    - Socket slips,rounding off the head of the plug
    - Frustrated,I get a pair of Vise Grips (I know I know-
    - you should never do that),Vise Grips keep slipping
    - At this point,I admit defeat (it's also 95 degrees in the garage)
    - Decide to was Wife's car & the F150 - all goes well
    - a few hours later,we have a torrential down pour of rain
    The thing that really got me,is my Wife called the shop,& asked if they'd
    get the drain plug loose for me.Their reply - "We can get to it in three weeks".
    Needless to say,we won't be dealing with that shop again.
    Just Remember.......
    NOBODY ever says "COOL PRIUS!"
  2. #2
    Great Pumpkin JPSmit's Avatar
    Join Date
    Nov 2004
    Location
    Toronto, ON
    Posts
    17,660
    Thanks Thanks Given
    19
    Thanked in
    Re: Fusion Frustration
    which is why I don't work on my drivers. My mechanic can do this all.
    John-Peter Smit
    1976 MG Midget
    1969 Vauxhall Viva GT
    1958 Fiat Multipla (Barn art)
  3. #3
    Join Date
    Sep 2005
    Location
    Roanoke,Virginia
    Posts
    8,406
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    I can't afford it anymore.
    And now I find out that I need to replace the fuel pump assembly
    in the rear tank of the F150.
  4. #4
    Jedi Hopeful Alfred E. Neuman's Avatar
    Join Date
    Dec 2016
    Location
    Decatur, GA
    Posts
    181
    Thanks Thanks Given
    3
    12
    Thanked in
    Are the drain plug and oil pan both metal? If so, I routinely have to resort to a hammer and chisel to get drain plugs out of oil pans. You'd be shocked at how tight some techs at jiffy lube type places will put on a drain plug. I'm convinced they use an impact gun for speed whenever they can.
    Another biggie for us is tire shops that use the Torque Monster 9000 to put lug bolts on these cars. Literally have to bounce on a breaker bar with long extender pipe to break some of them loose.
    Torque wrenches are our friends.
  5. #5
    Great Pumpkin DrEntropy's Avatar
    Join Date
    Sep 2005
    Location
    Elsinore, DK
    Posts
    32,270
    Thanks Thanks Given
    6
    17
    Thanked in
    Quote Originally Posted by Alfred E.
    Amen! And the "Quick lube in rear" outfits are the enemy! Once had a client bring his 308 in due to an odd noise coming from the trans... he'd taken it to a quickie lube for an oil change. Whoever did the work didn't translate the "OLIO MOTORE" well and drained the transmissione instead. Then proceeded putting an excess 10 litres of oil into the crankcase. Gearbox was TRASH by the time we saw it.
    '64 MGB, '67 Lotus Elan S-3 DHC,'69 Lotus Elan +2
    '78 Alfa Romeo Spider-undergoing surgery: O=\*/=O
    '84 300D Turbo-"Diesela"-Now my Daily: Oo|≣|oO
    '02 Toyota Camry- SWMBO's 'new-to-her' Daily. <sigh>
    Chaos & Mayhem PTY, LTD..C.I.O. & Floor Sweepervisor
  6. #6
    Yoda PAUL161's Avatar
    Join Date
    Jan 2005
    Location
    Locust Grove, Oklahoma
    Posts
    8,971
    Thanks Thanks Given
    10
    Thanked in
    Here's a tool that has got me out of a situation like yours a couple times. Not the greatest invention in tools, but if it works, it works. I've used a stud grabber on rounded off square head plugs also. PJsmart-wrenches3.jpg
    Remember, Never Forget
    We Live In The Land of The Free
    Because of The Brave
  7. #7
    Luke Skywalker 3798j's Avatar
    Join Date
    Apr 2005
    Location
    Susquehanna Valley
    Posts
    1,772
    Thanks Thanks Given
    7
    4
    Thanked in
    Irwin Bolt-Grips work wonders on removing even badly rounded bolt heads. https://www.lowes.com/pd/IRWIN-BOLT-...saAqqqEALw_wcB
    '66 TR4A '68 GT6
  8. #8
    Join Date
    Sep 2005
    Location
    Roanoke,Virginia
    Posts
    8,406
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    SUCCESS!! - Bought the IRWIN kit (Made in the USA!),
    & finally got it off.
  9. #9
    Join Date
    May 2013
    Location
    southwest Ohio
    Posts
    987
    Thanks Thanks Given
    2
    Thanked in
    Oil change, reminds me of this guy I knew who was a grad student when I was an undergrad many years ago. Took his car to a dealer to get the oil changed, got a call from them that there had been a slight accident. Seems the guy doing the work hadn't gotten it properly positioned on the lift and the tugging on the drain up from had caused it to fall off the lift and well, the car was upside down on the floor. Ended up getting a somewhat newer car with the dealer kicking in a few hundred bucks.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
