TR6 TR series transmission compatibility
Ottibee
I apologize if this is not the right protocol - 1st time asking a question. I was wondering if anyone had definitive information on transmission compatibility. In particular, does anyone know for certain if a TR4A non-overdrive transmission will fit a TR6 without any modification? (I’ve had my fill of challenges this summer and am not looking for another.). Thank you.
glemon
The bellhousing and input shaft stayed the same throughout I think. The insides changed over the years, oh you may need to mess with clutch and pressure plate as well the rear transmission mount, location changed over the years and between overdrive and non-overdrive
O
Ottibee
Thank you. You’ve said the magic phrase to scare me away; “mess with the clutch and pressure plate.” I already have enough problems with the clutch ...... I don’t want to add another variable. Thank you again.
TR3driver
Great Pumpkin - R.I.P
TR4A should fit, but is not as strong as TR6. Probably work fine if you drive modestly, but I wouldn't try it if you like to drive hard (as I do).
The 4A used the same clutch as TR6, so no worries there. If you did get a TR4 (instead of 4A), the only clutch change necessary is to trim a bit off the input cover (and use the TR6 clutch components, TOB, carrier sleeve, etc).
BTW, I think your "protocol" is fine. Maybe could be just a bit more descriptive on the title line, like "TR4A trans in a TR6?" but what you have is good too. It can also help if you put your commission number in your signature; for example late TR6 uses an adapter at the rear motor mount for a non-overdrive gearbox; which might be missing if you don't have the old gearbox.
PS, Welcome to the asylum!
I Manual transmission in XJ series 2? Jaguar 1
Deanrobert Xke series lll cooling issues Jaguar 5
zoohow TR2/3/3A lights in series Triumph 2
LD-Ordie Series II gear lube question Rover / Land Rover 3
PAUL161 T-Series T Series Starters MG 0
PAUL161 T-Series T series tierod ends MG 2
O XKE series 2 thermo fan switch bung stud repair. Jaguar 9
M Front caliper rebuild 1970 Series 2 E-Type Jaguar 0
A Making an A-series engine stand adaptor fitting Spridgets 2
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
L BMC A-series: Oil in coolant British Motor Corp 6
6 SOLD!! For sale 1966 Series 1 FHC $85,000.00 Jaguar Classifieds 3
ROARRR Series 2 XJ6 with cert for chev eng for parts or refurb Jaguar Classifieds 4
N Wanted Spats - XK Series? Jaguar Classifieds 4
S Series 1/2 Wiper Motor Needed Rover / Land Rover 0
steveg HS vs HD series carbs Austin Healey 2
W XJ6 Series I bumper swap to Series II Jaguar 0
S For Sale Mg t-series crankshaft tb tc td tf 1250 1500 MG Classifieds 0
D Source for XJ6c Series ll Ignition key blanks & remote Jaguar 1
Lin Fairly new YouTube series on AH100 restoration Austin Healey 0
H Lotus Super 7 series 2 Race car for sale Lotus 0
T For Sale Gear reduction starter fits jaguar 3.8 340 mark series 3.8l 3.4l - $100 Jaguar Classifieds 0
steveg HD series Jet Centering - a Caution Austin Healey 19
M E-type series 1 plastic dash vents Jaguar 1
M XKE Coupe series 1 Tub versus series 1.5 Jaguar 1
O Wanted Vauxhall Victor F series parts Other British Classifieds 2
B For Sale 1969 Jaguar XKE 4.2L Series II Coupe - Indiana Jaguar Classifieds 0
Basil About to re-install my fuel tank Series I E-Type Jaguar 6
Healey Nut "Father Brown" British television series Austin Healey 9
Basil Series 1 EType Spotted 2
J Wanted tri-SU carbs, manifold and linkage for '69 series 2 4.2 Jaguar Classifieds 3
Nunyas Salvaged Lotus Evora rebuild video series Lotus 8
D Series II E-Type tire size Jaguar 9
M Photos Needed of Series III E-Type Engine Oil Filter Clearance at Exhaust Manifold Jaguar 1
S M Series Bonnet Striker Pin failures TVR 4
C Mounting ignition switch to XKE series 2 steering column? Jaguar 4
G original radio 1961 e series jaguar Jaguar 3
Y M Series indicator lens TVR 3
Q Series 1 E Type Clutch Jaguar 2
F 1965 Humber Super Snipe Series Va Other British Cars 5
T 1971 Series I XJ6 parked for 12 years - fuel pump problem Jaguar 4
G '70 Series II engine bay wiring harness -- Jaguar 7
G '70 Series II engine bay wiring harness -- Jaguar 3
David Townsend T-Series MG Midget TC Series Limited Edition Illustrations MG 1
J TR4/4A TR4 Series Vehicle numbers Triumph 1
N GT6 GT6 I II III Series rear vent window sizes Triumph 4
P XKE series 1 FHC windshield installation ?? Jaguar 4
E Series 1 jaguar boot latch problem Jaguar 2
N A series expert's needed?? Spridgets 2
