TR6 horn brush
edkap2002
Changed my original steering wheel out for a mota-lita.....nice wheel....came with a hub kit as well....does anyone know if I need a longer horn brush for this application as I can seem to get the horn to make contact...thanks to all as always....Ed
poolboy
You might have to play around with (bend, twist) the brass contact on the new horn button...making sure it's making contact with 'brush'.
charleyf
I use MotoLita wheels on my two TR4s . I actually had the opposite problem with the horn brush being to long . You might check on the horn brush and see that the spring inside it is free to move and allows the lower contact to extend its full length.
G TR4/4A Horn Brush Question Triumph 7
M Some Tech Advice Needed for Horn Brush on 59 Bugeye Spridgets 10
V Horn "brush" Spridgets 3
M Horn Brush Disintergration Spridgets 1
R TR4/4A Tr4a, new horn brush is too long Triumph 2
I Bugeye horn brush help please Spridgets 8
I Horn brush installment help for Bugeye please Spridgets 7
RickB Sprite horn brush - which way? Spridgets 5
P TR2/3/3A TR2 Horn Mounts Triumph 7
K 68 midget. No horn, headlights, turn signals Spridgets 9
J MGB HELP, my horn does not work! MG 8
olarson TR2/3/3A Horn Replacement Wiring Triumph 7
Sopwith_Camel horn relay wiring Jaguar 3
K TR2/3/3A The horn and turn signal assembly. Triumph 3
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
D TR2/3/3A Traffic at or and horn button not working Triumph 2
P TR2/3/3A 6 volt Oogah horn Triumph 8
K TR2/3/3A Inside the horn and turn signal control head. Triumph 3
jehuie Morris Minor horn mystery British Motor Corp 12
Sixpack TR6 Horn Mystery Triumph 3
J TR4/4A Getting electrical shock from horn button when using the horn. Triumph 9
R Horn relay Spridgets 2
K TR2/3/3A The chrome ring around the bakelite horn button? Triumph 4
T TR2/3/3A TR3A rack & pinion conversion question - solution for horn & directional lever Triumph 2
P TR6 TR6 Horn Relay Problems Triumph 8
S Indicator / Horn Switch Austin Healey 10
nichola TR6 Help me - circuit breaker above horn relay Triumph 5
nichola TR6 What is this, connected to horn relay? Triumph 8
Bayless Wanted: Spridget horn button bracket Spridgets Classified 1
71TR6 TR2/3/3A Control Head horn contact Triumph 7
71TR6 TR2/3/3A Windtone WT618 horn current Triumph 9
D TR2/3/3A Tr3 horn testing and wiring Triumph 8
Kurtis Bugeye Sprite front frame rail horn replacement Spridgets 5
D TR6 Replacing Horn insert in steering column Triumph 11
nevets BN6 horn button Austin Healey 17
C TR2/3/3A Horn Control replacement Triumph 3
Bayless Question on '67 horn button Spridgets 5
K TR2/3/3A Horn Button Removal Triumph 10
S TR2/3/3A Horn not working unless I rotate the control head Triumph 6
TRMark T-Series Horn/Dipper Switch MG 4
R German horn on BJ7 Austin Healey 8
K Is my BJ8 horn switch connected to ground positively or negatively? Austin Healey 3
longbridgehealey Horn question follow up Austin Healey 12
longbridgehealey 100-6 BN4 horn question Austin Healey 2
UmmYeahOk GT6 Steering Wheel Horn Troubles Triumph 11
K Restoring Horn Push Button Austin Healey 12
Jim_Gruber Intermittent Horn Spridgets 2
Joe_Healey TR5/TR250 Bubba Horn Triumph 0
E TR4/4A Wiring the horn when installing a Moto -Lita steering wheel Triumph 4
P TR2/3/3A TR3 turn signal and horn control wiring check Triumph 4
