TR4/4A Fitting New Dash--Problem with Dash Pads
KVH
Are the dash pads offered by the usual sources top quality--still? I'm having a terrible time fitting my dash after installing new lower dash pads, and one of them seems problematic. It fits too far inward. Granted only about 3/16 of an inch but that's enough. I'm wondering: a) can the mounting studs be bent a little for adjustment; and b) should I "slot" out the dash mounting holes to allow more flexibility in the adjustment? Any ideas or thoughts? Thanks all.
PS The more I play with my TR, even in some frustration, the better I feel.
charleyf
I have used two sets over the last several years on two different car.s Both sets were from TRF and did not have such a problem. But now that you have a set and are trying to get them to fit. Sometimes you just need to do what you need to do to make what you have fit. The finished product is what counts, not how you got it to fit. I would likely slot out the hole to allow the adjustment.
ghawk16
I can't remember where I bought my lower dash pads, but I know that my drivers side pad is about 1/2" too short where it meets the top near the door. There is a big gap, but I decided to just leave it as I'm done trying to make the car "perfect" especially after the paint debacle and other things I nicked or scratched or dented. But if I was you I would just notch the holes a little bit to slide it over. Can't see the holes once the pads are on.
Gliderman8
I had a similar problem when I installed the lower dash pads on my TR6. I ended up removing the stud in the dash pad and moving it to a new location to lineup with the hole in the dash. I used epoxy to anchor the stud. It was an inconvenience (and something that shouldn’t be required) but after moving the stud the pad lined up perfectly.
TulsaFred bugeye windscreen washer pump dash fitting Spridgets 10
chicken Help fitting and covering a dash top assembly Austin Healey 7
Lin dash cone fitting Spridgets 4
J TR4/4A Strange Problem Fitting Inner Fender Triumph 18
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
K TR2/3/3A Does this fitting need a Whitworth wrench? Triumph 10
SherpaPilot TR6 Unidentified fitting on TR6 Engine Triumph 3
S TR2/3/3A brass fitting from a steel brake line Triumph 2
Writer2022 GT6 Overheating after fitting air filters Triumph 4
Writer2022 GT6 K+N Filter Fitting Triumph 2
KVH General Tech Fitting the Hood (Bonnet) Triumph 7
KVH General Tech Fitting the Pistons and Sleeves Triumph 2
A Making an A-series engine stand adaptor fitting Spridgets 2
D TR2/3/3A Windshield frame fitting. Triumph 2
B Fitting the Boot Lid Seal Austin Healey 8
M TR2/3/3A Fuel Line Fitting at the Tank. Triumph 5
Got_All_4 TR6 drill and tap for a grease fitting tr6 rear hub assembly Triumph 4
edkap2002 TR6 lower radiator hose fitting Triumph 2
DerekJ Fitting a 100-Six grille. Austin Healey 10
Jim_Stevens TR2/3/3A Door fitting- graduate level Triumph 25
R TR2/3/3A Fitting windshield Triumph 3
CharlesBN1 need some advice fitting the bonnet on a 54 BN1 Austin Healey 4
D TR2/3/3A front Apron fitting Triumph 5
D TR2/3/3A Fitting the hood. Soft top. Triumph 6
ckeithjordan TR2/3/3A Oil Fiter Fitting Frustrations Triumph 13
M Fitting a modern radio Austin Healey 9
TulsaFred Convertible Top Fitting problems Spridgets 29
M TR2/3/3A Oil Pressure Gauge Line Fitting Triumph 8
G TR2/3/3A Fitting the Control Head - Telescoping [Adjustable] Wheel Triumph 20
TulsaFred Carpet fitting in the Bugeye Spridgets 3
PeterK TR4/4A Fitting TWM manifolds for DCOEs Triumph 2
Patrick67BJ8 Poor Fitting New BJ8 Glass Austin Healey 9
M TR2/3/3A Fitting Modern Steel Wheels Triumph 4
I Bugeye fuel fitting Spridgets 3
P Healey 100M Cold Air Box Hose Fitting Austin Healey 20
Jim_Gruber Suspension Reinstall / Fitting Steerig Arm to Tie Rod End Spridgets 15
M TR2/3/3A Fitting on Moss Brake/Clutch Masters Triumph 16
M TR2/3/3A Fuel Pump Fitting Thread Triumph 6
wkilleffer MGB Fitting a new top to a 74 MGB- how tight is too tight? MG 23
H TR2/3/3A Sway bar fitting Triumph 7
F Fitting anti-squeal kit to front calipers on BT7? Austin Healey 7
Got_All_4 TR2/3/3A Fitting the original tr3 transmission cover over a tr6 overdrive Triumph 9
Got_All_4 TR2/3/3A Fitting the trunk floor pad & fuel tank cover Triumph 2
PatGalvin TR2/3/3A Vacuum Hose Fitting Install, Any Suggestions? Triumph 6
P Good fitting car cover recommendation? Austin Healey 9
2 TR2/3/3A Fitting mirror against new windscreen Triumph 5
Dave Richards Rear Brake Cylinders not Fitting Hand Brake Lever Austin Healey 2
Michael Oritt Temperature sender fitting at radiator on BN1 Austin Healey 3
jfarris TR2/3/3A SU H6 Vacuum Advance Fitting Thread Size Triumph 2
