Results 1 to 6 of 6
Thread: Aluminum trim ring band removal
  1. #1
    Join Date
    Dec 2005
    Location
    Washington State, USA
    Posts
    2,008
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    I gave up trying to find NOS aluminum trim rings. To get the ones I have anodized again, I need to remove the metal ring on the inside that holds the ring to the wheel. Anyone know how to do this?
    Kevin
  2. #2
    Yoda Gliderman8's Avatar
    Join Date
    Jun 2008
    Location
    PA
    Posts
    7,850
    Thanks Thanks Given
    8
    21
    Thanked in
    Re: Aluminum trim ring band removal
    The trim ring is just held in place by some "spring fingers" around the circumference of the ring. You should be able to carefully lever it out with a rage between the ring and the wheel and use a pointed tip to start it coming up.
    Elliot
    Central PA
    1976 TR6 White/Biscuit interior SOLD
    1973 TR6 Damson Plum / Biscuit interior, HVDA 5-speed, Good Parts Hubs
    Nostalgia isn't what it used to be.
  3. #3
    Join Date
    Aug 2003
    Location
    Sunny So California
    Posts
    18,790
    Thanks Thanks Given
    3
    55
    Thanked in
    I think he means how to get the "springy fingers" away from the trim ring. The spring part is steel and the anodizing process will attack (ruin) it.
    Randall
  4. #4
    Join Date
    Dec 2005
    Location
    Posts
    2,008
    Thanks Thanks Given
    Thanked in
    Yes, I was talking about the spring fingers. The process would eat the metal spring fingers, so unless I can figure out a way to remove them, prepping and reanodizing the trim rings is not an option. I am pretty sure I am out of luck at this point as it looks like the spring fingers are held in place by the aluminum being pressed in place over it. I thought someone might have a way to get these out or suggest someone who could.
  5. #5
    Join Date
    Jun 2008
    Location
    PA
    Posts
    7,850
    Thanks Thanks Given
    8
    21
    Thanked in
    Quote Originally Posted by ichthos View Post
    Sorry, I misunderstood the original post.
    Elliot
    Central PA
  6. #6
    Join Date
    Dec 2005
    Location
    Posts
    2,008
    Thanks Thanks Given
    Thanked in
    I probably should have included a picture. I always appreciate a response either way.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
