TR2/3/3A Penrite semi fluid steering box lube?
Brinkerhoff
Invert the plastic bottle and squeeze the contents into the steering box . Run the steering box through its travel so the lube settles and add more .
K
karls59tr
Bronze
Not that simple. The Penrite bottle opening is about 1&1/4" wide....the steering box fill hole is about 3/4" wide so that would necessitate using a funnel. The fluid is so thick it would just stay in the funnel and take forever to drain in. I thought someone mentioned a Marine "grease gun" that pumped heavy fluids?
Geo Hahn
Yes, everyone I have seen has a tube in the top.
To fill the system you want the top off the box. To top it up I can usually coax some in thru the hole with the rubber plug (using a funnel). It helps to have the front end off the ground so you can twiddle the steering wheel side-to-side to get the stuff in there.
I usually do this on a day when it is 109° (like earlier this week).
Redoakboo
No clear tube dispenser in the bottle I bought. Guess I'll have to improvise one.:chargrined:
I am restoring my 1954 TR-2. I have removed all the wiring, including the harness running through the steering column. The fluid has now begun to leak out. I put paper under the box, and it is still leaking out. How much does the box hold? What has kept the fluid from leaking out before I removed the wiring bundle?
From this article I assume I refill it, after the restoration is complete; with Penrite lube?
Dick V.
Brinkerhoff
My TR3 box was dry or nearly at 91,000 mi. when I chipped the hardened grease etc. from the filler cap on the top. After filling it with Penrite its been holding for 3 months now.
Geo Hahn
I use Penrite a nd finds it works well - but in the interest of full disclosure: not everyone agrees this is the best choice or course of action.
It is heavier than what the manual calls for (that is why it leak more slowly) some even resort to grease rather than oil (okay they're all grease but I mean something like wheel grease.
The best practice is a rebuild of the steering box for easier steering and no leaks.
Dick - did you disturb the nut on the bottom end of the stator tube when you worked with the wiring?
K
karls59tr
Bronze
Heat it in boiling water. Then it will pour more like a fluid.
That did the trick. I pored it into a small pump oil can and pumped it into the fill hole on the box. Any idea how much oil the box is supposed to hold? I filled it to wht looked like the top but it might take more once it settles?
sp53
If you have the top off the box, I would suggest not moving the steering wheel because the shaft can pop up and off the worm gear.
M TR2/3/3A TR3 Steering: Penrite v. Snythetic Triumph 4
T TR2/3/3A Penrite into TR3b steering box - dump and go? Triumph 4
H General MG MGYB--Semi-- restoration MG 2
tr3guy TR2/3/3A Miscellaneous bracket and component paint -- gloss or semi-gloss Triumph 5
R ceramic or semi-metallic brake pad? Spridgets 3
Boggsy64 MGB Semi metallic disk brake - break in MG 10
6 rear semi eliptic spring plate - old school mechanic Spridgets 1
DrEntropy Semi-car tool related. Restoration & Tools 18
T OT - your semi-random BAT Latest Triumph 2
Michael Oritt Semi-sealed bearings Racing 7
jerrybny Classic Gold Semi-Metallic Brake Pad Set Triumph 2
A wiring question semi-OD related MG 1
A TR6 TR6 semi-Scam on Ebay Triumph 13
aeronca65t MGB Semi-trick MGB MG 7
jaybird Mike's Midget - or Midget versus semi MG 4
6 Brake Fluid Spridgets 4
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
B TR2/3/3A TR3A Gearbox fluid capacity question Triumph 7
E General MG Transmission Fluid Level MG 2
SherpaPilot TR6 Brake Fluid in Servo? Triumph 0
prb51 Girling Brake Fluid Reservoir Cap Austin Healey 6
KVH General Tech Brake Fluid Triumph 5
Lin Brake/Clutch Fluid Austin Healey 11
AUSMHLY Castrol DOT4 Brake Fluid Austin Healey 6
craigshealey3000 Castrol Girling Amber Brake Fluid vs. Silicone Austin Healey 14
M Wedge TR7 break fluid Triumph 7
P TR6 Brake fluid leak? Triumph 6
F Girling Brake Fluid Reservoirs Leaking Austin Healey 12
D TR2/3/3A Why it is important to change brake fluid Triumph 4
D TR2/3/3A Brake fluid identification by colour. Triumph 4
R TR2/3/3A DOT 5 Brake Fluid Triumph 5
P Subaru fluid leak Other Cars 9
Martinld123 Brake Fluid Austin Healey 49
Bayless Brake fluid recommendations Restoration & Tools 6
fpstude TR4/4A Brake / Clutch Fluid for TR-4A Triumph 8
C MGA Shock fluid MG 14
C DOT 5 Silicone-Based Brake Fluid Austin Healey 10
KVH General TR Dot 4 Brake Fluid Triumph 7
longbridgehealey Clutch fluid Spridgets 7
K TR2/3/3A Steering box fluid again.... Triumph 2
NutmegCT Brake fluid - flush and replace. Why? Restoration & Tools 8
tahoe healey Brake Fluid Austin Healey 6
Rut Latest fluid recommendations Spridgets 5
D Wanted TR3A Girling fluid reservoir cap. Triumph Classifieds 0
2 TR2/3/3A DOT5 brake fluid Triumph 3
Got_All_4 General TR Someone asked where to get DOT5 silicon brake fluid a while back Triumph 4
D General TR Fluid Film Rust and Corrosion Inhibitor Triumph 8
RAC68 Another Discussion of Trans/OD Fluid Austin Healey 14
M Brake fluid on tire - cylinder need replaced? Spridgets 19
Zitch TR4/4A Diff Fluid - GL4 Triumph 7
