TR2/3/3A Clutch for gearbox swap
Konrod
I'm working through my TR3A, and next in the list is to swap the 3 synchro 4 speed for a 4 synchro OD box, and having read up the only issue seems to be the length of the studs/bolts at the bellhouisng flange (possibly, depending on the donor box) and slotting the gearbox mount.
One thing I can't find a definitiev anmswer to is the clutch. Can I still use the TR3 clutch/plate or do I need the concentric spring TR4 items? Hope not as I guess that means changes to the flywheel, at which point I feel a slippery slope coming wallet wise.............
Thanks
John
TR3driver
Great Pumpkin - R.I.P
Yes, the TR3 clutch will work fine. You may need to make some changes at the slave cylinder, though (which would be true for either clutch).
In my case, I made up a shorter pushrod, and a little tab to keep the return spring the same length. But I think that pounding the edge of the clutch cover flat, and switching to the TR6 style slave mounting would work without having to change the pushrod.
K
Konrod
Great, thanks for the reply. I can make any mods as I need to, it's just whether I need to plan bigger changes, as I want to get this done over a weekend.
Regards
John
TR3driver
Take a look at where the speedo cable goes through the side of the gearbox tunnel. The 4 synchro box moves the connection point just a little.
On my 3A, I just added a piece of old fuel line to protect the outer cable from rubbing on the edge. But on my current TR3, I had to trim away a bit of the opening to give it room.
Geo Hahn
You do not mention what commission number your TR3A has. If prior to TS50000 the bulge on the TR4 bellhousing may be bigger than what you have now and require some massaging of the tunnel cover.
Edit - never mind, found an old post where you mention it is a 1960.
Graham H
If you are going to use a TR6 box and OD and you havent fitted the front pannel yet, slotting the front engine mounts to move the engine forward about a 1/4 inch will make the fit a lot more comfortable . The bell housing flange on the 6 box is a lot thicker than the 3 or 4 box and to get it all to fit will take the slots on the gearbox mount almost to the limit
Graham
TR3driver
I'm not sure I follow you, Graham. I had plenty of room to slot the holes in the rear crossmember (after bending down the tab). And moving the engine forward is likely to cause clearance problems with the radiator. Don't forget that the engine rocks forwards on it's mounts during a hard stop.
Also, it's not the flange thickness that causes the mount to be farther back. The same difference exists with the TR4 gearbox, which still has the thin flange. It was the addition of synchomesh on 1st gear that made the main gearbox get slightly longer.
Graham H
Thank you Randall for clarifying that for me, its amazing how you can look at something a thousand times and not see the obvious. Just because the flange is thicker doesn't make the box longer,the extra metal is behind the face not in front of it.
Graham
K
Konrod
Thought I'd give you an update. I have done the gearbox swap - twice! The original came out sweet as a nut, getting the new box in was a pig, but once we had everything lined up it slid in and we could bolt it all up. I found a very useful garage tool in the process, a slim 21 year old son who can slide under the car and wiggle the bellhousing :smile:
Once everything was in place and I'd wired up the overdrive it was time to test it. First depression of the clutch caused an almighty grinding, clearly the release bearing. So, it all had to be disassembled again. the release bearing was rubbish - found out since there was a faulty batch, my supplier has 10 on the shelf, all with the same manufacturing fault, and no, it wasn't a cheap Chinese job.
So, all put back together, cursing the gearbox to exhaust mount and my fat fingers for a second time. This time it all worked. The first swap took three evenings, the second time about 4 hours!
In the process, removing the starter motor, we broke one of the tangs from the brake light switch:rolleye: As I'm up against time (and accessing it means taking the exhaust off again....) I offer you bodge of the week, which is actually very solid and may remain for some time........
Cheers
J
Graham H
That slim 21 year old is the right accessory to fit a TR gearbox, a job you only want to do once?
Graham
Geo Hahn
...we broke one of the tangs from the brake light switch:rolleye: As I'm up against time (and accessing it means taking the exhaust off again....
A mechanical brake lamp switch is a reasonable alternative for reliability but... I have always been able to easily access the pressure switch by removing the right front road wheel - then it is right there in front of you. But perhaps RHD cars differ in this regard.
DavidApp
Like the bodge. May have to do something similar if my pressure switch does not work.
Are Overdrive gearboxes easy to come by in the UK?
David
K
Konrod
Hi David, its like getting a Scotsman to part with money - it's gone past the point where cars are being broken up and you can find them in scrapyards. There are a couple of specialists who rebuild them, and they can build new ones (and I mean completely re-manufactured) from parts provided you have an exchange unit, I had to do a three cornered deal to get mine offering a saloon gearbox with a J type overdrive in exchange. Cost me a lot of money, but the cars value goes up more as everyone knows how hard they are to get.
The odd part is the three synchro box I took out has an O/D switch on 3rd/4th with the wires cut off (but no O/D unit), and an OD switch already on the dash. Almost looks like it used to have O/D but it go swapped for some reason
TR3driver
I've done that a few times myself : Buy an entire car to get the OD, rob the OD, sell the car without it.
DavidApp
Much as I thought. Would be nice to get one. Have to keep looking and save my pennies.
Makes me sad to think I sent one to the breakers yard with an OD box. Was rear ended and the car was already rotten to the point the frame outriggers were gone on one side.
David
K TR2/3/3A Gearbox clutch adjustment. Triumph 1
K TR2/3/3A Clutch Slave Cylinder location when TR3 has a TR6 Gearbox? Triumph 16
K TR2/3/3A TR6 Gearbox in a TR3.....Use a TR6 clutch disc and pressure plate or Triumph 7
K TR2/3/3A Clutch and Gearbox Sleeve Differences. Triumph 12
V TR4/4A Triumph TR4 A clutch assembly and gearbox Triumph 6
K TR2/3/3A TR6 gearbox on TR3: re clutch slave adjustment. Triumph 13
F Spitfire Finally Mobile! Now Grind/Rubbing from Clutch, Gearbox Or? Triumph 5
pakiwi Clutch / Gearbox issue Spridgets 6
J Clutch pressure plate very close to gearbox Spridgets 3
ecurie_ecosse Clutch/Gearbox. Spridgets 10
martx-5 Gearbox Clutch Release Fork Triumph 2
71TR6 TR2/3/3A Aftermarket brake and clutch master cylinders - black extension? Triumph 6
Turbozinke TR2/3/3A Varying clutch engagement Triumph 6
K TR2/3/3A Pushing down the clutch pedal when starting the car? Triumph 13
DutchConnection Clutch finger problems on Powetune aftermarket clutch cover Spridgets 0
3 100 Clutch Freeplay Austin Healey 7
K New Clutch Master/Slave Cylinder Austin Healey 1
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
Govtslug TR6 Clutch Problem Triumph 21
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
AUSMHLY Clutch Pedal Freeplay Austin Healey 18
T General Tech Clutch trouble Triumph 12
AUSMHLY Clutch Stalls Engine Austin Healey 16
D Wanted WTB - clutch fork and shifter from Datsun 5 speed #60 Spridgets Classified 0
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
T Spitfire Clutch fork and hydraulic cylinders Triumph 3
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
AUSMHLY BJ8 Clutch Pressure Plate, Old vs New Austin Healey 4
Lin Brake/Clutch Fluid Austin Healey 11
R TR2/3/3A Clutch Petal Adjustment Triumph 2
AUSMHLY BJ8 Clutch Fork Bush Replacement Austin Healey 5
KVH General Tech New Clutch Installation--TR4A Triumph 5
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
D Clutch Fork Pin Removal Austin Healey 4
AUSMHLY BJ8 Clutch Pressure Plate Brand Preferences Austin Healey 3
Michael Oritt Clutch Linkage Austin Healey 19
M 1275 Race Clutch Racing 5
G MGB 1978 MGB clutch is out..! MG 39
M TR2/3/3A HVDA Replacement Clutch Disc Available from Moss Triumph 10
B Spridget with a Tilton Race Clutch Racing 1
AUSMHLY Clutch Pilot Bush: NOS vs Aftermarket Austin Healey 8
T Clutch Pedal Engagement Point Austin Healey 1
TR6Canuck For Sale 72 TR6 clutch and transmission Triumph Classifieds 4
K TR2/3/3A Clutch slave "return spring"? Triumph 3
vintagemechanic Recommended clutch kits Jaguar 3
K TR2/3/3A Mystery Clutch MC? Spitfire....TR4....69-70 TR6??? Triumph 2
K TR2/3/3A Clutch Master Cylinders? Triumph 1
R TR2/3/3A Clutch Engagement Triumph 31
