hydraulic line material
JimLaney
Going to make all new lines for clutch and brakes. I remember hearing about some material that was better than the steel pipe that is original. What do you use? Do you recommend it? Any problems working with it? will old fittings work with it?
Rut
The stuff Rut has linked to is called Cunifer, or cupro-nickle, or some variation of that. It bends easier than steel, will not rust, and is more expensive than stainless.
I prefer it over the coated steel lines and even stainless.
It flares easily and can work with your existing fittings if they are in good condition.
Grantura_MKI
Buy new fitting, ends. Moss stocks them. If you are old, they will show a larger than normal flare or cracks at the cylinder end.
Iwould buy the kit as suggested if I was you.
Keith_M
I would agree with what's been said; the pre-made copper-nickel stuff is the way to go. I re-plumbed my bugeye with it. It's easy to bend (with a tubing bender of course), and it doesn't rust.
Keith
JimLaney
JimLaney
Thanks to all who replied. I ordered an Automec kit of copper-nickel including new fittings.
nomad
I've used the cupronickle lines and prefer them as well. Personally prefer Fedhill for a source and use their tools and fittings. They claim their lines are thicker than the common ones.
Kurt
R TR6 Clutch Master Cylinder Hydraulic Line (Thread / Flare Type) Triumph 4
Jim_Stevens TR2/3/3A Clutch slave hydraulic line Triumph 1
M 948 clutch hydraulic line Spridgets 7
DornTRoriginal TR2/3/3A Hydraulic Brake Line Clips Installation Triumph 2
M TR2/3/3A TR3 clutch hydraulic line routing Triumph 2
Ohiobugeye Another Clutch Hydraulic Line Question Spridgets 2
T Spitfire Clutch fork and hydraulic cylinders Triumph 3
TomMull hydraulic fittings "O ring face" Restoration & Tools 6
G TR2/3/3A Hydraulic supply lines from reservoir..replace with flexible Triumph 19
J Hydraulic Brake Switch Internals Austin Healey 19
I General TR Hydraulic lift opinions/info needed Triumph 34
C Bleeding the hydraulic clutch Spridgets 6
Lukens TR2/3/3A My theory about my clutch hydraulic problems Triumph 11
Lukens TR2/3/3A Clutch hydraulic problems Triumph 12
W Hydraulic Tank Austin Healey 8
catfood Hydraulic cylinder repair. Restoration & Tools 2
texbears3 TR4/4A Hydraulic Fluid Contamination Triumph 10
M TR2/3/3A TR3A clutch hydraulic problem Triumph 9
GBRandy Wedge TR8 Hydraulic lifters - Replace? Triumph 1
Lin 4-post lift hydraulic fluid Austin Healey 5
stretchit2 Hydraulic Shock Fluid - Bilstein Shock Conversion Austin Healey 6
TulsaFred Hydraulic system disassembly-reassembly Spridgets 10
M TR2/3/3A TR3A Hydraulic system problem Triumph 4
Moseso Weird Hydraulic Failure Triumph 8
J TR2/3/3A tr3 hydraulic brake light switch Triumph 13
M Hydraulic Problems Spridgets 5
I Bugeye hydraulic problems Spridgets 9
JohnnyMead Another Hydraulic Fluid Reservoir Question Triumph 10
angelfj1 Paint Quality - Hydraulic Fluid Reservoirs Triumph 14
R BE Hydraulic Question Spridgets 15
ekamm New hydraulic resevior Triumph 5
Ohiobugeye Got Engine Running, But have Hydraulic Leak Spridgets 2
Ohiobugeye Hydraulic Bleeding Sequence Spridgets 7
F Dirty Hydraulic Fluid Austin Healey 7
bluemiata90 CLUTCH HYDRAULIC HELP Triumph 9
bluemiata90 TR6 TR6 CLUTCH PIN OR HYDRAULIC TROUBLE Triumph 6
S Hydraulic Brake Switch Austin Healey 5
knad2208 Hydraulic Clutch Fluid Spridgets 1
F Hydraulic clutch adjust Triumph 9
Tinkerman Brake and Hydraulic lines Triumph 4
S hydraulic lines to seal Triumph 4
philman hydraulic lifters Restoration & Tools 5
M Hydraulic brake light switches Jaguar 2
Shinsen774 T-Series Hydraulic Brake Switch-Early MGB-Still a problem? MG 9
Baz Teflon tape on hydraulic lines? MG 7
mrsprite Clutch hydraulic woes Spridgets 32
G Bleeding the hydraulic clutch Spridgets 36
martx-5 Clutch Hydraulic Pipe Routing Triumph 5
regularman British brake hydraulic fittings? Spridgets 9
71tr clutch - hydraulic throw out bearing Triumph 13
