FBI issues warning about routers
https://www.bizpacreview.com/2018/0...eboot-your-internet-router-immediately-638607
Almost certainly not, if you just push the button and release. That article claims that in some cases it can be done by holding the button down; but all of the routers I've owned had a separate button, usually hidden where it's hard to get to. For example, my current router just has a small hole in the case, where you can push a paper clip in to contact the factory reset button.My router has a button on the back to shut it off and then reboot it, with it off for aporx. 45 seconds, it takes about 10 minutes for the process. Not sure if it goes back to factory settings though. PJ
