Clean Oxidation from cast aluminum
JimLaney
Don't think taking my transmission apart to get it into the blast cabinet is worth it so how can I clean the white crystalline oxidation off of the bell housing?
dklawson
Google for "Aluminum Jelly". If you use it with a combination of Scotchbrite pads and small wire brushes you'll be able to clean a lot of the casting. The only trick/caveat is that you will need to rinse and dry the casting quickly when done to prevent the formation of dark grey patches.
Also, Google for threads on polishing aluminum. I believe the Airstream trailer websites are a good source for that information.
JimLaney
JimLaney
Tried wire wheel on drill motor. Stiff twisted wire wheel was too rough on aluminum casting but fine wire wheel cleaned beautifully. Got some smaller wire wheels that fit my die grinder and I'll try them in tight places next. Thanks for your help!
Grantura_MKI
I would use what commercial trucks use for fuel tanks, etc.
if you put anything in a blasting cabinet, it needs to be hot tank after to remove any contamination.
PAUL161
I use Walnut shells in the blasting cabinet on Aluminum castings and get excellent results, lower air pressure for delicate items. I wash the part with a citrus cleaner, such as Purple Power, if there is any evidence of oil on the surface before putting it in the cabinet, never after. PJ
JimLaney
JimLaney
Cleaned up the transmission case, R&R throw out bearing, lever, slave cylinder and rod.
Not perfect but works for my driver build.
69MGC T-Series Best Technique to Clean a Canvas Top MG 3
tr6nitjulius For Sale TR6 working/clean parts 4sale Triumph Classifieds 0
Basil Easy way to clean fuel injectors (out of car) Other British Cars 2
B How to clean the old gunk out of a Spridget gas tank? Spridgets 21
T How do I clean sand out of a ring & pinion? Spridgets 2
BoyRacer How to clean a cloth wiring harness Austin Healey 14
JimLaney Media blasting engine parts - How to clean? Spridgets 5
D TR2/3/3A Exhaust manifold clean up. Triumph 6
I General TR Mold clean up suggestions Triumph 4
S TR2/3/3A overdrive transmission, cosmetically clean Triumph 12
R General TR Best way to clean unpainted parts Triumph 1
jaegzie Cylinder wall has some build up. Need to clean. Spridgets 4
NutmegCT Cooling system clean/flush Restoration & Tools 11
T TR2/3/3A Is there a way to take apart and clean/repair TR3A headlight dimmer switch? Triumph 8
nevets How to clean a E Z Bleed ? Restoration & Tools 11
C How to clean a Lucas Headlight? Restoration & Tools 5
R did a little clean up today Triumph 5
D Best Way to Clean Corrosion on Fuse Clips. Jaguar 3
Darrell_Walker Fuel tank - just clean, or clean and seal? Triumph 15
bighealeysource How to clean aluminum shut face finishers ? Austin Healey 9
T silcone clean up Triumph 9
Moseso Mini ! Clean! Also, heavily customized ! Spotted 2
bighealeysource How to clean up rear backlight on factory hardtop Austin Healey 11
BugeyeNJ58 Garage Clean Out-1100 Engine and 4-speed Trans. Spridgets 5
K TR2/3/3A Best way to clean TR3 Bakelite horn button? Triumph 8
Rut Transmission clean up Restoration & Tools 5
W Garage clean up Spridgets 0
S Very clean 1970 Morris Minor Woody on eBay Other British Cars 6
J Paint help! [I've got a mess to clean up] Triumph 9
D Wire wheel clean prior to paint MG 1
ekamm Clean looking sedan on Eastcoast Triumph 0
M What's the best way to clean off under-gunk? Spridgets 10
T best way to clean a canvass top? Triumph 4
T Working with clean parts is soooo very nice Triumph 19
SilentUnicorn How not to clean a motorcycle chain British Motorbikes 6
tmc Clean the gas tank or buy a new one? Triumph 8
J what should I use to clean 30yr old vinyl? Triumph 6
T Radius arm clean-up and bushings Spridgets 7
B Time to go racing again - seeking clean Spridget Racing 32
T 30 minutes of clean up and much better Triumph 19
T MGB-GT Clean MGBGT cheap on BMW forum MG 5
T How should I clean my diff now that it is out..... Triumph 9
P Clean behind the Grill on a 100 Austin Healey 3
jjbunn Calipers! How to clean and install? Triumph 7
boeingpilot Brake Rotor Clean Up Restoration & Tools 4
RickB To clean old tarnish off replacement fuse box? Spridgets 10
walshja how do you clean Spridgets 5
tosoutherncars Armstrong lever-arm dampeners - clean & replace Spridgets 6
regularman The clean up Spridgets 0
S Battery bay clean up Spridgets 5
