Replacing O/D switch with a clock
twas_brillig
We're running the Toyota 5 speed in our MK II BJ7, so the o/d switch is redundant, and I like having a clock on the dash. We removed the o/d switch and zip-tied it up behind the dash and mounted a battery driven analog Oxford clock normally sold for motorcycles etc. (see https://www.oxfordproducts.com/moto...ling/oxford_clock_silver_case_and_white_face/
It's a white face, silver trim, they also have a black face/black trim and a white face/titanium trim version. Two mounting options are provided, but we basically used a stack of washers. There's no need to modify the dash (unless you want to shift the clock over a bit to make it more centred). We've had one in our dune buggy for over a year (same battery) and have been very satisfied with it.
T
twas_brillig
Dang! I thought I'd done everything correctly to post a photo of the dash mit clock, but no success. I used the attachment facility; browsed; selected my file; hit upload; etc. I didn't see the photo as part of the preview prior to posting but it appeared in the managing the uploads/attachments so assumed it would appear in the finished, loaded, version. Guidance would sure be appreciated. DOug
NutmegCT
Doug - if you hit attach, you won't see the photo appear in the post. It'll just be a clickable link under the post.
If you want the photo in the post itself, click the "picture" icon (third from right) above the text window.
Tom M.
T
twas_brillig
Thanks Tom; Thanks Randy.
Here's what it looks like, installed. Later, Doug
BN6_2197 Replacing gearbox switch of the overdrive system Austin Healey 10
K TR4/4A Replacing a broken 4A turn signal switch indicator? Triumph 2
C Replacing TR 3 Stop Light Switch Triumph 11
S T-Series Replacing the turn signal switch... MG 4
S TR2/3/3A Pinion tail bearing replacing Triumph 12
B Replacing the Handbrake Cable Austin Healey 8
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
TR3Acustodian TR2/3/3A Replacing "H" front badge Triumph 11
K TR2/3/3A Replacing water pump pulley.....memory refresh. Triumph 7
I Replacing Windscreen Wiper Wheel Boxes Austin Healey 0
S MGB 1978, replacing the clutch. MG 3
PAUL161 T-Series Replacing Transmission MG 3
S TR2/3/3A Replacing the cam shaft Triumph 27
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
J TR4/4A Replacing springs Triumph 7
Got_All_4 TR5/TR250 Need guidance for replacing steering column bushings Triumph 11
L Replacing veneer on wood dashboard Restoration & Tools 14
D TR6 Replacing Horn insert in steering column Triumph 11
69MGC MGC Replacing an Outer Wheel Well panel MG 3
maxwedge5281 Replacing Factory Hardtop Rear Window Austin Healey 24
TomMull replacing walnut veneeron the dash Lotus 17
R TR2/3/3A Replacing rear springs Triumph 51
Jer refresh my foggy memory - replacing clutch in my 67 Midget Spridgets 1
RAC68 Clutch Still Slipping after replacing 30W-Non-Det. for Red Line Austin Healey 52
simon1966 Replacing the witches nose in-situ. BN1 Austin Healey 14
KVH TR4/4A Replacing Front Windshield Gasket Triumph 5
Michael Oritt Replacing timing chain tensioner and more Austin Healey 24
Rut Replacing rocker assembly Spridgets 1
T TR4/4A Replacing rear pinion seal - remove driveshaft? Triumph 21
J Replacing BJ7 Dash - Detailed Photos/Schematics Austin Healey 3
M Replacing front shocks, torque setting? Spridgets 2
T TR4/4A Replacing in situ oils sealing gearbox and rear axle Triumph 18
55modified TR2/3/3A warning indicator bulbs need replacing where and what to buy? Triumph 4
Jim_Gruber Replacing Wheel Studs Spridgets 10
P Replacing the crankshaft damper [harmonic balancer] Austin Healey 15
55modified Replacing rear spring eye bushings on a BN1. How difficult? Austin Healey 8
Michael Oritt Replacing Cold Air Box with Velocity Stacks Austin Healey 10
Rhodyspit75 Replacing boot floor need bracing? Spridgets 2
RickB MGB 1980 MGB No rear brakes after replacing MC & booster MG 5
Popeye TR4/4A Steering bushing: replacing rubber with poly, do I snug to 1/8" gap or...? Triumph 3
Jim_Gruber Replacing Spridget Coolant Spridgets 21
TimK Old brake hoses need replacing, if you need proof look here... Austin Healey 1
KVH TR4/4A Replacing the Real Axle Tube Seal Triumph 17
KVH General TR Short Wheel Studs for Wire Wheels--Replacing Triumph 17
GTP1960 TR2/3/3A Question on replacing brake lines & converting to Dot 5 Triumph 9
tomshobby replacing water pump Spridgets 1
D TR2/3/3A Patching, versus replacing floors? Triumph 15
T Replacing the crank pulley/damper Austin Healey 4
M TR4/4A Replacing the hood/bonnet onto the body Triumph 11
