Anybody seen this Front Shock Conversion Kit before?
Csarneson
I found this front shock conversion kit on ebay a while back and largely forgot about it for a couple years. I got it shockingly cheap so the risk was very low. I'm now researching it a little to verify that it's a good idea. It requires cutting away the bump-stops on the chassis and drilling a large hole in the shock tower mounts. While these are semi-drastic steps on a typical chassis, my chassis has had several modifications made already so these changes aren't very troubling to me but they also aren't reversible. My chassis is still on the rotisserie so the mods are pretty easy at the moment.
The shocks are mounted inside the springs in this kit. I can find no brand-name anywhere but the workmanship is excellent. Does anybody have any experience with this design or information about the kit itself? Who made it?
Chris
red57
Chris,
I have the 'normal' Koni conversion. I have not seen one like yours before but it may well be by Koni. IMO, the tubes work much better than the stock levers. Don't know about yours but I think most Koni shocks are adjustable & that is a nice feature.
Did you get the shocks too or just the mounting kit? If you have the shocks, call Koni North America in Hebron, KY at (859) 586-4100 and ask if they know about the kit & who made it.
I like the looks of your kit, should work well. As you probably know, the 'normal' kit has the shock mounted to the rear of the a-arms and looks very much like an add-on (kinda tacky looking actually, but work well). I like the nature of your kit better and it wouldn't be too hard to reverse since the bump stop is not visible when assembled (keep the pieces you cut off and the stock bottom spring plates).
The reason I have the phone number & address is that I have broken two of mine a few years ago and found that Koni will rebuild/repair their shocks forever, no mater the age or rarity I gather. The last one I had repaired was a rear and involved replacing the main rod and internals and cost me just under $300 in 2009
Dave
Csarneson
Csarneson
I just realized that the first photo was not included in my original post. Yes the kit includes the shocks themselves. The kit tells me they are adjustable. I like knowing that Koni will support them long term. One of my concerns with the kit was that I don't know the specifics of the actual shocks if I ever needed to replace them.
red57
Chris, Now that I see the box and the entire kit, I think it probably is a Koni kit..... If you decide not to use it, I would be happy to buy it from you.
Dave
regularman Has anybody ever put a square sprite front end on Spridgets 11
G D would anybody be able to tell the correct way to static time a essex v6 I have tried and failed cheers garth TVR 14
Csarneson Anybody feeling optimistic? Or drunk? Austin Healey 21
Keoke Anybody heard: Austin Healey 9
Got_All_4 General TR Anybody Hear or Use This Hot Spark System? Triumph 10
Gerard Anybody have...? Spridgets 9
TRMark General Tech Anybody Using Star Tron Triumph 2
J Anybody driving a 2018 Jaguar XJ? Jaguar 3
J anybody tell me why this thread closed? Austin Healey 4
TR3TR6 TR2/3/3A Anybody else having a bad day! Triumph 31
M TR2/3/3A Does anybody use the oils and lubes from the moss motors site? Triumph 3
TomMull Post-War Other Anybody interested in 10s? Triumph 15
2billydavies TR2/3/3A anybody need a spare rear bumper? Triumph 8
Randy Forbes Healarossa; anybody ever seen, or heard of it? Austin Healey 2
catfood Rivnuts anybody Austin Healey 19
H Joan Baex 1961 flat floor--silver exterior--anybody know what IRS sold it for? Jaguar 0
H TR4/4A Triumph 250-K by Pete Brock--anybody recall how much Brock advertised it for? Triumph 1
K Anybody Try Exactline blades? Restoration & Tools 4
B TR2/3/3A Anybody finish their car in laquer? Triumph 18
64Elan Anybody interested in an Italian Spridgit? Spridgets 3
Gerard Is anybody able to ID these racing/sports seats? Spridgets 0
Gerard Anybody have a steering wheel emblem for '68 Sprite stock steering wheel? Spridgets 11
S Anybody tried this Alternator ? Austin Healey 11
W Anybody have one of these surplus? Spridgets 5
krswen TR2/3/3A Anybody own TR3 TS 59719 L? Triumph 0
krswen Anybody own Series 1 E-type coupe 1E 32257? Jaguar 2
TR4nut TR6 TR6 under dash pics? Anybody? Triumph 9
DNK Wedge Anybody have any "good" adhesive? Triumph 2
B anybody know how and where I can get the cable ends for the heater cable? Spridgets 13
AN5Sprite Anybody Have A Bugeye Fuel Gauge Core To Spare? Spridgets 3
J Anybody need a 1500 motor? Spridgets 2
R July 15 Fairfield Ohio meet anybody going? Spridgets 8
Gerard Does anybody have a busted crank? Spridgets 3
regularman Anybody in Arkansas? Spridgets 2
rkep01 Anybody have one of these available? Spridgets 7
regularman Anybody got any cheap used distributor parts Spridgets 8
M TR2/3/3A Anybody ever dye wool carpet? TR3 Triumph 0
T TR2/3/3A Anybody need a TR3 frame and suspension Triumph 5
T Anybody Want to Play "Identify the Crud"? Triumph 2
DNK Anybody? Triumph 3
Banjo TR4/4A AAAAUG! anybody got an extra TR4A piston? Triumph 3
DNK Anybody have .. Lotus 1
jdubois Anybody tried these floats? Triumph 7
DNK Anybody need an Eclat Lotus 4
longbridgehealey Does anybody know this car?? Spridgets 0
DNK Anybody... Triumph 12
jdubois TR6 Anybody interested in a TR6 in boxes in MA? Triumph 16
Tr3aguy Anybody got 44k Triumph 16
L Anybody used.... Spridgets 9
S Anybody need a grocery gettery??! Other Cars 10
