Results 1 to 7 of 7
Thread: Timer for pusher fan
  1. #1
    Senior Member warwick-steve's Avatar
    Join Date
    May 2016
    Location
    Warwick UK
    Posts
    100
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    Hi
    I have fitted an electric pusher/blower fan with a on/off switch for when I am in slow traffic and for when I turn the engine off. Is it possible to fit some kind of 12v timer into the circuit so that when I park up and walk away from the car the fan will switch off after a preset time? Any one know of a suitable timer?
    Thanks
    Steve
  2. #2
    Join Date
    Dec 2001
    Location
    Boardman,Ohio
    Posts
    5
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    Re: Timer for pusher fan
    Derale #16759 Adjustable Fan Controller. A good one. Available @ Amazon, Summit Racing etc. Works like a charm. I replaced 3 or 4 cheapos until this one.
  3. The Following User Says Thank You to Warren For This Useful Post:
    Editor_Reid  (05-16-2018)
  4. #3
    Join Date
    May 2016
    Location
    Warwick UK
    Posts
    100
    Thanks Thanks Given
    Thanked in
    Thanks Warren, I will check whether I can get that one here in the UK
    Steve
  5. #4
    Join Date
    Mar 2003
    Location
    Hampshire in the UK
    Posts
    1,620
    Thanks Thanks Given
    4
    Thanked in
    Steve
    Give Merlin Motor Sport a ring over at Castle Combe they seem to have a range of product that may suite.
  6. #5
    Join Date
    May 2016
    Location
    Warwick UK
    Posts
    100
    Thanks Thanks Given
    Thanked in
    Thanks Bob
    Will do
    Steve
  7. #6
    Luke Skywalker RAC68's Avatar
    Join Date
    May 2010
    Location
    NJ Shore
    Posts
    1,616
    Thanks Thanks Given
    5
    Thanked in
    Steve,
    My TR7 had Air Conditioning with a heave York compressor. Seeing little use for this old system, I removed all the air conditioning components as well as the puller engine-mounted fan from under the hood and left the 2 auxiliary fans. These auxiliary fans were mounted on an upward angle in front and below the radiator so as not to block air movement through the radiator when the car is moving forward. Additionally, and specific to your objective, these fans are thermostatically controlled (on and off) with a sensor on the upper tank of the radiator.
    As I remember, there is a plug on the bottom of the top tank of the Healey's radiator. If you can get an adjustible thermostatic switch that can be made to fit into that opening, you can adjust the control to start by a set temperature or manual switch and automatically turn off when the engine temperature drops to a set temperature.
    Just a thought,
    Ray(64BJ8P1)
  8. #7
    Join Date
    May 2016
    Location
    Warwick UK
    Posts
    100
    Thanks Thanks Given
    Thanked in
    Thanks Ray
    Yes, thats another option
    cheers
    Steve
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
