TR2/3/3A Have I mounted my Yellow fan backwards?
DavidApp
Have I mounted the yellow fan backwards? I mounted it with the flat face towards the motor and the recess to the radiator. When I went to put the radiator on the car there was not enough room to get it in.
David
Geo Hahn
I believe you have it mounted as designed - but some have had to mount it backwards to get it to fit.
On my TR4 I had to mount it backwards and make a spacer (from a cutting board) to make it fit.
Mounting it backwards has (I think) only a small effect on performance (the blades have a slight airfoil). The fan, of course, blows the same way whichever way you mount it.
DavidApp
Hello Geo and Marvin
Thank you.
When I looked at The Roadster Factory page showing the fan I could see from the photo I had it the wrong way around. Reversed it and checked that I can get a belt on past the fan. You have to rotate the engine to get the belt past the cross tube but it fits Ok apart from that.
I need to align the crank hole with the radiator hole. I presume I use the shims that go between the mounting block and the engine mounting plate. The rectangular shim with a slot.
David
Geo Hahn
Yes, alignment is via the shims, this shim:
This image may (or may not) print in the correct size (if you choose to make your own):
DavidApp
Hello Geo
Thank you.
I have a stack of them. Not sure if the PO purchased some or if they came from the car when he stripped it down.
It looks like I will have to put more on one side to move the crank to the center of the radiator. May try centering it by moving the mounting blocks first.
The crank hole is low and off center to the radiator hole.
David
DavidApp
Got the crank handle centered on the radiator. It took 3 shims on one side and one on the other. Also I had to slot the 2 bolt holes in the rubber mounting blocks so that I could shift the motor sideways a fraction.
David
CJD
David
I think it’s well worth it. Even if you never hand crank, the crank comes in very handy when setting tappets, timing and the like. Much easier than bumping the engine with the starter or cutting your hand spinning the fan.
DavidApp
Also kind of neat being able to start the car the old school way along with all the other advantages.
On my TR2 the crank saver me on many occasions. Back in the late 1960s batteries seem to die slowly. Now they just drop dead with little warning.
David
Geo Hahn
Also kind of neat being able to start the car the old school way...
Always a crowd-pleaser at car shows. It used to be the young who enjoyed seeing that, now anyone under 50 has never seen such a thing.
It does require an engine that fires immediately - oddly, mine is easy to crank-start when cold, not as easy when warmed up and difficult when hot.
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
Lukens TR2/3/3A Anyone ever see a push/pull throttle mounted on the dash? Triumph 4
Jim_Gruber Looking for SU Fuel Pump mounted on RR Bulkhead pics Spridgets 2
JimTR4 TR4/4A Rear mounted Lucas WLR 576 lamps Triumph 3
Got_All_4 TR2/3/3A How is this id plate to be properly mounted Triumph 10
PATR8 Wedge TR8 four barrel intake mounted reverse Triumph 10
mrdibbles Balancing Wire Wheels - While mounted on the car Austin Healey 18
6 Anyone ever mounted or seen Borrani wire rims? Triumph 6
Hooper11772 Can tubeless tires be mounted on spoked rims???? Spridgets 9
Tinkerman Slave Cylinder bracket mounted where? Triumph 2
T TR6 Shelf mounted roll bar for TR6 Triumph 11
M Bugeye bonnet mounted on later sprite or midget? Spridgets 21
TimK Condenser [capacitor] mounted to firewall??? Austin Healey 4
MadRiver T-Series TC Firewall-mounted oil can MG 6
N Fastners for trunk mounted luggage rack? Triumph 8
Westfield_XI Solid mounted Spridget transmission Spridgets 0
hondo402000 TR6 Trunk mounted brake light for TR6 Triumph 28
M Non body mounted mirrors Austin Healey 17
D Rollbar mounted safety harnesses Racing 4
P How are the sun visor clips mounted on a Midget? Spridgets 3
M Camera Mounted Mini British Motor Corp 8
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 6
jfarris For Sale TR6 Yellow Fan - new Triumph Classifieds 0
K TR6 Need help with Mimosa Yellow Paint Triumph 1
1 For Sale 1980 Yellow MG MGB MG Classifieds 2
W New Yellow Bugeye Spridgets 12
Zitch For Sale 8 Blade yellow Fan for triumph Triumph Classifieds 2
K TR2/3/3A Yellow wire uprated condensor Triumph 1
Jim_Gruber Yellow BE on BAT Spridgets 0
jfarris For Sale New 8-Blade Yellow Fan and Mounting Kit Triumph Classifieds 0
2billydavies TR4/4A yellow blinker light stays on all the time the shuts off when blinkers are used Triumph 2
N TR4/4A yellow fan Triumph 5
AN5Sprite Yellow TR6 on Turnpike Spotted 0
DerekJ Primrose Yellow / Black with yellow upholstery Austin Healey 18
F Source for Touch Up Paint for Primrose Yellow? Triumph 3
Mickey Richaud Yellow Alpine Spotted 2
T TR2/3/3A Wisconsin Yellow TR3 Triumph 0
S Lemon yellow early Sprite Spotted 0
aeronca65t Yellow Sprite Spotted 0
tahoe healey Yellow bulbs Austin Healey 17
longbridgehealey Leaf green? Primrose yellow??? Spridgets 22
JamesWilson Yellow Turner Usk A472, Lotus Elite M5, & more.... Spotted 1
M Prim Rose Yellow Spridgets 14
DNK Yellow 6 Spotted 0
KVH TR4/4A The Yellow Fan on a TR4 Triumph 4
ekamm Primrose yellow? Triumph 28
apbos Silver or Yellow Wheels Triumph 10
wangdango TR6 TR6 paint/azteck yellow Triumph 2
T here comes a can-o-worms: yellow fog lights Triumph 19
