Steering Column Mounting
grimes6
I am currently fitting the steering column in my BJ7. I have the mounting bracket AHb9683 but I am not clear if the bracket 14b2549 is required for the BJ7 . It shows these brackets in the BMC service parts list but shows them for BJ8's. I have also found a metal bracket which purpose is to capture two set screws. Is this to hold the 14B2549 bracket? I can supply a pic. of this bracket when I get access to my digital camera.
Unfortunately I did not dismantle the car so this will be the first of a few queries. I have found this forum invaluable in the past.
Many thanks ,
Greg
G
grimes6
An update on my post. With the assistance of Greg Kilmartin (Kilmartin Automotive Sheetmetal) , I have been able to answer my own question!
C Mounting ignition switch to XKE series 2 steering column? Jaguar 4
M TR2/3/3A TR3 steering column mounting question???? Triumph 2
olarson TR2/3/3A Steering Column Bracket Triumph 2
M Midget steering column Spridgets 3
B Steering Column Wiring/Sealing Austin Healey 1
Walter74 Steering Column Felt Bushing Austin Healey 3
D Steering Column Adjustment Collet Austin Healey 8
Retired2020 TR250 steering column bushing Triumph 2
ActionJackson Spitfire Steering Column Lock Triumph 3
A Early 1967 AH Sprite - installing steering column and new directional switch? Spridgets 0
R TR2/3/3A Replace wiring harness in steering column Triumph 61
R TR2/3/3A Install new wiring harness in steering column Triumph 16
R TR2/3/3A Steering Column Wiring Triumph 18
M TR6 EZ EPAS Steering Column Fitment to TR4-6. Triumph 0
R TR2/3/3A Wiring from the steering column Triumph 7
M TR6 EZ Power Assisted Steering Column Fitment Triumph 3
Got_All_4 TR5/TR250 Need guidance for replacing steering column bushings Triumph 11
D TR6 Replacing Horn insert in steering column Triumph 11
L TR2/3/3A Upper steering column bushing Triumph 8
BoyRacer Steering Wheel Location with non-adjusable column Austin Healey 6
BoyRacer Wanted Steering Wheel Hub Adaptor for non adjustable column Austin Healey Classifieds 1
steveg Steering column steady brace and scuttle shake? Austin Healey 2
T TR2/3/3A Is there a Delrin bush available for the top of TR3 steering column instead of felt? Triumph 8
T TR2/3/3A Requesting help on removing TR3A steering column and box Triumph 21
T Steering Column Installation Spridgets 6
C Non-Adjustable steering column questions Austin Healey 14
BoyRacer Steering Column Height Adjustment on BN2 Austin Healey 1
SherpaPilot TR6 Steering Column Loose Triumph 8
John_Mc TR6 Steering column rubbler coupler Triumph 8
R TR2/3/3A Installing wiring harness in steering column Triumph 59
B Steering Column Bushing Austin Healey 2
S TR2/3/3A steering column through the body tub Triumph 5
S TR2/3/3A steering bracket that fits under the dash for the end of the column Triumph 2
KVH General TR Steering Shaft/Column Short Circuit?--Electrical Issue with Light Switch Triumph 3
60BN7 Adjustable Steering Column Won't Lock Austin Healey 9
B Outer steering column connection to the steering box Austin Healey 6
D TR2/3/3A steering column bushings Triumph 8
M TR4/4A Triumph TR4/4A Steering Column spline size Triumph 1
D BT7 adjustable steering column / steering wheel Austin Healey 1
G TR2/3/3A Steering Column Support for One-Piece Steering Column Triumph 3
adcronin For Sale MGB New Turn Signal Switches: 62-67 and 68-70 Also 70-73 MBB Steering column cover MG Classifieds 0
rjc157 TR6 steering column Triumph 0
S TR6 steering column bushings Triumph 5
Marvin Gruber BJ8 steering column blanking plate seal Austin Healey 1
J TR2/3/3A Split steering column rubber bushing installation. Triumph 4
T TR2/3/3A Steering Column Grommet Triumph 4
D Ajustable Steering Column Escutcheon Austin Healey 2
6 Steering Column Spridgets 6
B Lower Steering Column Bush - Where does it go and how? Austin Healey 14
S TR2/3/3A 37XXX and 27XXX the steering column was split Triumph 6
