T-Series Loose valve cover oil cap
NutmegCT
For the first time since November, I cranked up my '53 TD. Felt good! Temp in the garage was 50F, full choke, ignition on, pump purred along, I pulled the starter knob - and it came right to life. Yeehaa!
As it warmed, I slowly pushed in the choke. Engine slowed to normal idle, but I heard a kind of rattling tinkly sound. Turns out the oil cap on the valve cover rattles.
The grippers under the cover itself are tight in the hole. But the cover of the cap (with the oil company names) is loose and rattles.
Was there originally some felt or rubber between the puller knob and the cover, or between the cover and the "gripper" underneath?
My setup is similar to this:
Thanks.
Tom M.
PAUL161
Tom, There is a cork gasket under the gripper on mine, as seen in the photo. It appears it was installed before the gripper was installed, as it completely fills the cap inter surface. My cap is very tight when the center button is pushed down. Because of the chain, I have to re-do my valve cover, then put a clear plastic sleeve over the chain. PJ
NutmegCT
NutmegCT
Thanks Paul. Sorry 'bout the chain scratches!
I wondered about cork, but settled on sliding some felt into that area. Cut a circle to fit, then made a cut from edge to center, then carefully slid it into place. Works like a charm.
Somehow we always find a way to improve our cars. And they often do the same to us.
By the way, how was that "oil brand" cap supposed to be used? The cover with the names on it rotates pretty easily, so I can't see it holding a specific position for long.
Tom M.
Platinum
Tom, "stretch" the 'fingers' in the cap gently outward, then find a piece of synthetic material to replace what Paul's cork seal shows.
1/4" thick natural rubber will do the job.
PAUL161
Tom M.
Tom, it isn't supposed to turn once the button is pushed down. They are supposed to seal so no oil can work it's way out, reason for the cork. PJ
Eeffoc TR4/4A Out of the blue - started to loose power Triumph 17
M Loose Pilot Bushing Spridgets 1
steveg TR6 Loose wheel nuts after torquing Triumph 2
sparkydave Zenith auto choke coming loose Spridgets 2
RAC68 Loose Metal Knocking/Banging Sound during Rough Idle Austin Healey 32
SherpaPilot TR6 Steering Column Loose Triumph 8
jfarris TR2/3/3A Loose Lift the Dot Stud Triumph 7
B TR6 Boot lid thread plates loose in stiffener Triumph 1
Lin Post in float bowl came loose Austin Healey 6
sparkydave Zenith auto choke coming loose Spridgets 3
tinman58 General TR It was just a loose wire Triumph 15
D BJ 8 Float Bowl securing bolt loose Austin Healey 6
R water temp bulb loose Austin Healey 27
G Loose lugs on rear hub Austin Healey 7
S TR4/4A TR4A Water pump pulley loose Triumph 10
mgedit TR2/3/3A Rear Shocks Loose Triumph 16
KVH TR4/4A Loose Rear Shocks on my IRS Triumph 7
T General Tech How loose can a piston liner be? Triumph 2
rustbucket Loose spokes on wire wheels MG 8
angelfj1 TR2/3/3A TR3A - Dynamo Fan is loose! Triumph 3
G 6 steering column loose Triumph 3
J What tool to get the nut loose on the steering box Austin Healey 5
jjbunn E-Type Turn Switch - loose braid for horn? Jaguar 6
Jim_Gruber Bottom Starter Motor Bolt - How do I get it loose? Spridgets 7
davester Loose manifold to exhaust connection MG 3
Johnny Door handle on BN7 came loose. Austin Healey 8
D Sway bar - BT7 - loose captured nuts Austin Healey 18
M TR2/3/3A Loose wing beading TR3A Triumph 4
D TR6 Loose TR6 Sunvisors Triumph 11
T TR2/3/3A Tr3 Radiator fan loose Triumph 33
M Fuel Line Came Loose; Yikes! Spridgets 4
M TR2/3/3A 55 tr2 loose on I 70!! Triumph 3
CCURTISS T-Series MGTC Door Latch Backing Plate [screw loose] MG 0
Indnrdr Throttle pinch bolt came loose; how to get to it. Austin Healey 4
walshja winshield washer nozzle is loose Spridgets 20
71TR6 Loose rear view mirror Triumph 4
R Carburettor suction chamber cap loose - why? Austin Healey 23
charlie74 loose bonnet hinges Triumph 4
T Loose Nuts: Pedro-ized Triumph 19
A TR6 TR-6 Loose Handling Triumph 22
Woodie steering pinion loose Spridgets 18
P loose shift lever Triumph 7
simpzimmer wheel loose Triumph 4
R6MGS Ignition Switch loose.... Triumph 9
Thor Loose power at 3000 rpm's Spridgets 12
P Door Glass came loose... Spridgets 8
D TR4/4A tr4 steering - inner ball joints loose Triumph 14
77_MG_Midget I think I have a screw loose!!!!! Spridgets 15
George Zeck Loose Front End .... Spridgets 6
D It was a loose alternator bracket... Spridgets 2
