Trying to understand my cooling system
  • Thread starter Deleted member 21878
  • Start date
as some of you may have read, i have been a bit concerned about my engine temps. weather is cool and it is running hotter than i expected for the temp of the thermostat. (160*)
i have tried a few different things. the latest one was installing a sleeved thermostat. while i did notice what may be a little improvement, i did not see a big change. my gauge showed around 185 to 190 most of the time driving and a little hotter if sitting after a decent drive.
this morning i got to thinking about how the gauge reads. when i start the car the gauge will climb steadily at a pretty even rate up to about 190 and then drop back about 10*. then it will go up a litlle and back down a little. but stay right about the 180-190 mark. it has acted the same way with either thermostat.
So this morning when i started it, i let it run and just held on to the top radiator hose. as soon as i felt hot coolant coming thru it, i went and checked the gauge. yup it read 190. i know, a simple test i should have done in the beginning.
i am now going to assume either my gauge is off or there are some air pockets in the system. (from draining and refilling) probably the first option is more likely. if it is some air, the more i run it the better it should get.
the next test will be to see how it acts as the ambient temp rises.... if it ever does around here.
Bob_Spidell
Re: trying to understand my cooling system...
FWIW, 190degF or thereabouts is considered the ideal running temp for a car. Less than that and you may not get the oil hot enough to boil off water contamination. Of course, an oil temp gauge would be best, but not usually installed in road-only cars.
John Turney
The Healey cooling system isn't prone to trapping air pockets since the radiator cap it the high point of the system. So, the temperature gauge or thermostat are the most likely suspects. If you have an infrared thermometer, measure the temperature at the entrance to the radiator head tank next to the inlet. If not, and they aren't that expensive, you can use a small cooking thermometer in the top of the radiator fins. Next option is to remove the temperature gauge sensor and put it in boiling water.
Harbor Freight sells them for about $30 when not on sale(sometimes $20 when they are). I don't think 190 is out of the ordinary range.
Keoke
190 Degrees is a good running temp for the Healey sic cylinder engine,
However, if you want to upgrade the engine performance it will require the addition of :
1 a six bladed fan
2 a fan shroud
3 an upgraded serpentine radiator
All of these modifications are readily available for reasonable costs.
British_Recovery
Bronze
Are you routing the coolant through the heater core? Block valve open and dash lever to the right?
Lotuswins
Drone Dog,
Okay, so did you test the thermostat on the stove before you installed it?? Its pretty mandatory now days with all the Chinese parts available. I had purchased a sleeved thermostat also, tested it and found it sticking severely such that I sent it back. I since just put a gasket on the water pump that blocked the recirculating hole, and put a 3/16 hole in the more modern thermostat to bleed air/circulate a little when warming up.
Also, on the gage, anyone who has read gauges for a living knows that before you take a read, you tap the gauge lightly with your knuckle to take the internal friction out of the equation. If the gauge moves a little then you know that the gauge may need lubrication (or just simply tap it before you believe it).
As for the temp, assuming the gauge is right, can you give us some history on the radiator? and the engine? Overhauled last? problems? coolant used? etc.
Michael Oritt
DD--
The thermostat's rating determines the minimum operating temperature, not the maximum.
2liter4cyl
Bronze
the stat temp no, is the "start to open" temp. put it in heated water and check it out. LeT
BJ8Healeys
It is a common misperception that a 160 thermostat will maintain the coolant temp at 160. It doesn't work that way. The thermostat responds to the temperature of the coolant, it doesn't control it. Once a 160 thermostat is wide open, it has no ability to control the temperature, which is determined by several factors -- including the velocity of the air flow and the ability of the system to transfer heat from the engine to the coolant. If these factors mean the temp of the coolant is going to be 190, then a 160 thermostat is out of the loop once it is wide open because it can't open any further. I found that a 160 thermostat for my BJ8 was not the solution because it allowed the engine to run too cool in winter (I actually had to block part of the radiator to get the temp up above 160. The solution was a modern core with more tubes and fins combined with a sleeved 190 thermostat. My car now typically runs between 170 and 185 even in summer in the South. It normal for the temp gauge to go to 212 when the engine is thoroughly warmed up and then shut off. The cycling of the sleeved thermostat is also normal. This morning, I watched my temp gauge cycle from 180 to 190 and back several times until the temp stabilized at 180.
i will try to answer all above at one time. hope this does not get too long.
i really don't mind if it runs at 190 either. As long as it stays there in warmer weather and does not run hotter.
but i wonder if i am even running at 190. i have put two brand new thermostats in this car and both have had the same result. i would figure if you start the car cold and it begins to heat up, as the temp reaches 160, or there about, the thermostat is going to open and hot coolant is going to come thru that top hose. it is easy to tell when it opens. if the car ran up to 160 and the coolant started coming thru the upper hose, the car leveled out and then started getting hotter to 190, then i would assume it is running 190. but this goes right up to 190. so i am thinking something must be off with the gauge.
i did test the gauge in boiling water before i installed it to see if it still had any ether in it. it seemed pretty close at that time. so i wondered if something else has affected it since i put it in the car. i also tested the thermostats to see they opened at the 160 temp. some of my drain downs. my wife thinks i bought stock in the gasket company....
i do have a thermal gun and have shot the engine in a number of places. while the thermostat housing/cap can go up to 190 or so. the engine block where the sensor goes in.... i don't believe i have ever seen it go higher than maybe 170-174. So i am not sure what i am running.
i do have a 6 bladed fan and my own fan shroud. never had the car running without it so i can't speak to how well it works or does not. this is rebuilt engine i just got back together. at this point, guessing maybe run all of 5 hours. the radiator is a stock with a new core in it by the previous owner. it was flushed and my radiator man said it had great flow. i bought the car in boxes so this is my first time having the car run. probably being too overly cautious.
i believe i have the block heater valve open. the handle is parallel to the block and i have slid the heater handle to the right. but i have also almost completely drained the coolant to change thermostats, fix leaks, different tests, etc. several times. so it has the chance to have some air in there almost each day i have started it in the last week or so. changes to my cooling system were most of the questions i have been chasing down.
you know i do not remember if this thermostat had a hole in it or not. i know the first non-sleeved one did not. but for some reason i think this one did.
i do realize the thermostat does not control the final temp in the engine. but it should open and let coolant thru the upper hose at the proper temp when the car is warming up. and that should happen before 190*. i would think anyway.
i have also noticed the cycling on some start ups. seemed a bit confusing to me but it does level out once i get to driving. i assumed most of that was air in the system working it's way out after coolant refills.
from all i have read here, it looks like i have checked all i can short of sending the gauge off to be checked; or maybe trying a different temp thermostat; or buying another mechanincal gauge and see what it reads. i think i will just drive it and keep an eye on it. as long as it stays close to that 190 number, i will not worry about it. if it starts running hotter then i will look for another gauge to try.
as always thanks for the suggestions and information.
DerekJ
The purpose of the thermostat is to allow the engine to heat up to operating temperature as quickly as possible. To do that it prevents coolant flow to the radiator until the thermostat control temp is reached. When cars were run all year round it was common practise to change thermostats. A 190 in winter and say a 160 in summer. As Michael said these do not affect the temperature that your engine will run at when it is at operating temperature.
Bob_Spidell
I'm still looking for an explanation as to why both my BJ8 and BN2 will run at below thermostat setpoint temps on cool/moderate days. Both have 180degF thermostats, but will run at 160 or so unless it's warm or the engine is really working. This with several thermostats and, yes, I have tested at least one of them on the stove.
Healey Nut
Why not just start the car cold with the rad cap off , allow the car to idle and heat up , once you see flow in the rad that means the thermostat has opened .
Drop in a five dollar meat thermometer and check the temperature . Compare to gauge reading ....Done .
Bob_Spidell
Good idea. I'll do that next chance I get. I do think the thermostat is opening, as on a warm day or with a load the temp will stabilize at 180, at least until I get stuck in traffic. I had a Ford Ranger that would usually barely move the gauge needle off the peg, then read somewhere that it was a common problem with their quality German-engineered thermostats. Put a Stant in and it behaves like it should.
steveg
I did a version of that: undid the housing, removed the thermostat, and rotated the radiator hose up so as to not lose coolant. Then inserted 2 meat thermometers adjacent to the gauge bulb and idled the car for a few minutes. My gauge showed 20+ degrees hotter than the thermometers. I moved the pin on the gauge to correspond to the thermometers.
A new, low-hour engine is bound to be tighter and run hotter than a well seasoned one (so much talk about meat thermometers, I'm thinking about cooking) and since you're nowhere near a critical temp yet, why not just let it work itself out ;)
In the good old days of daily driving these cars, we didn't have time to worry about such things; did it start? Yes, then onto work! Did the car get us home? Yes, then time to do chores around the house! Being retired allows too much time to worry about things that don't need worrying about (I wouldn't know about that yet, just speculation on my part ;) ).
Jim 58 BN6
:encouragement: Yeah, as I've gotten older, I too have perfected the fine art of over-thinking just about any job! Back then when a British car was my only transportation, I carried water, oil, tools, the old ignition parts, gasket material and Permatex. The few times I did have a breakdown, it never seemed to be a problem to just fix it and get on to where I was going. Now, I seem to worry about everything...but once I actually start to work, it usually turns out just fine.
Back to the subject (if no one has already mentioned it): I bought an inexpensive IR thermometer for about $20. I can look at different areas on the engine, radiator and hoses. What I've found so far is the gauges in two cars read between 10 and 20 degrees too hot. I think it's a good sanity check, plus the engine can be run under pressure, and at full temperature.
EDIT: DD, I see you did use an IR gun. I would trust those readings more than the car's temp. gauge. From what you wrote, it LOOKS like the temperature is not a problem.
steveg
Being retired allows more time for "science projects". Ask me how I know. :cool:
JPSmit Thinking out loud and trying to understand. Restoration & Tools 31
JPSmit trying to understand camshafts Spridgets 22
B GT6 trying to ID my New Car. GT6 Triumph 6
Got_All_4 Wedge An issue with trying to start my TR7 Triumph 12
Got_All_4 TR5/TR250 Trying to figure out rear transmission mount with a J type tranny Triumph 9
G General TR Trying to reach Frank.... angelfi? Triumph 2
T Trying to identify a steel plate part Austin Healey 2
red57 Trying to identify this gear. Austin Healey 2
K TR2/3/3A Karl's ham handed adventures for your amusement in these trying times. Triumph 8
E Trying to ID some old classic car gauges Restoration & Tools 2
M MGB New member trying to help a friend with his 1980 MGB LE. MG 4
D Lilly second time running... or trying Austin Healey 8
D T-Series Trying to find out an interior dimension MG 7
T Trying to find an accurate tyre pressure gauge Spridgets 24
B MGB Trying to restore emissions controls on 79 MGB MG 0
D TR4/4A trying to identify bolts etc Triumph 5
M TR2/3/3A Grinding noise when trying to start sometimes? Triumph 10
J TR2/3/3A Trying to start engine for the first time! Triumph 11
F Frustration trying to adjust handbrake on Austin Healey BT7 Austin Healey 9
R TR2/3/3A Trying to trace some history on my TR3a Triumph 1
AngliaGT Trying to Rebuild the Brake M/C - Help! Spridgets 5
B New Colorado Red/Signal Red Thread - Trying to get it right Austin Healey 0
tomshobby I am trying to find the past history of my Midget. Spridgets 3
M MGB trying to change rotors - dumb question MG 7
KVH TR4/4A I'm Trying to Tune, Again Triumph 4
S Mk III Sprite cockpit surround - trying to recover Spridgets 9
Answerman Ghost of Lucas is trying to start my Jensen Healey Other British Cars 8
T someone is trying to sell my car Triumph 4
RickB Trying to sell the Sprite Spridgets 27
J Just trying to post pic of cool Jag! Jaguar 0
M Trying to locate William Holden Racing 2
H Trying to help a MG owner, any tips? MG 20
G Trying to reach Robert Triumph 1
H AH 3000 Trying to find the right look Austin Healey 23
M Trying to ID the Right Parts for Clutch Work. Spridgets 1
jlaird Miss Agatha was trying to tell me something Spridgets 4
G My "B" is trying to quit !! MG 7
M Car goes "click" when trying to start - the fix Spridgets 8
bigjones Trying to stay cool Spridgets 0
doughairfield Trying to get my motor started Triumph 8
MCNX_BFF Awakening the Beastie...trying to! Triumph 41
B TR2/3/3A Williams TR3 Book-Trying to find Triumph 4
OZ_BN1 Trying to identify a part. Other British Cars 21
UmmYeahOk GT6 Is he really trying to sell a GT6? Triumph 22
G Trying to Find T-Shirts Triumph 7
Trevor Jessie Trying out a camera mount... Spridgets 20
M Trying to Find a Family Heirloom Triumph 59
Mark_Barton TR4/4A Trying to replace TR4 transmission mount Triumph 13
mccalebr Trying to contact Jeff Dahn [Bugeye58] Spridgets 4
N In trying to check out the heater, I now need keys MG 7
