Adjustable Steering Column Won't Lock
60BN7
A few years ago we pulled the trafficator out for a rebuild. Upon putting everything back together, we forgot to put the dust cover assembly back in place. So we left it for a few seasons. We also seemed to have put things back improperly, as the wheel would no longer lock. Time to get it right. Can someone please provide a step by step detailed description of how to put things back together from the back dust cover support forward? As obvious at it seems to us (at least to me), we aren't getting something right. Thanks
60BN7
60BN7
Yes I'm turning it the correct way. The wheel still floats freely in and out when the lock ring is fully tightened. I'm clearly missing something here.
Patrick67BJ8
A guy in our club said he used a shim to make the Wheel able to tighten.
bob hughes
Well my fix for tightening up the Adjustable steering wheel are two fold -
1) if the steering wheel can wobble when you grip it top and bottom and push and pull then you install a 22mm olive from your plumbing kit, it may need a little fettling to get it in over the splines and into the wheel, just push it down - works a treat. 2) Then if you need to tighten the big nut so it grips - Use PTFE tape over the base of the steering wheel and then tighten up - worked for me.
:cheers:
Keoke
I had this problem and as I remember all I did was use a hack saw blade to widen the gag between the fingers of the splined part and then it would grip the the steering rod when hand tightened,Just a memory??
60BN7
60BN7
Might try giving that a go. Will let you know where I net out. Stay tuned.
60BN7
60BN7
Turns out there was wear either on the inner locking ring and/or the splines - so they could no longer engage to tighten. Made an aluminum shim to sit between the locking ring and the tapered splines. Works perfectly. Will post some pictures of what we used and how we made it in the next little bit. Thanks for all the suggestions.
BoyRacer Wanted Steering Wheel Hub Adaptor for non adjustable column Austin Healey Classifieds 1
C Non-Adjustable steering column questions Austin Healey 14
D BT7 adjustable steering column / steering wheel Austin Healey 1
maxwedge5281 bj7 adjustable steering column Austin Healey 14
Crankshaft Adjustable steering column? Triumph 11
I another adjustable steering column question Austin Healey 8
M Adjustable Steering column Austin Healey 9
B Adjustable Column and steering box e-bay Austin Healey 1
RandallRK Moto Lita steering hub on non-adjustable column Austin Healey 4
P Adjustable Steering Column for Spifire ? Triumph 0
P Spitfire Adjustable Steering Column Spitfire Triumph 0
JAV For Sale non adjustable steering box Austin Healey Classifieds 3
BoyRacer Did BN2s have adjustable steering wheels? Austin Healey 5
J TR2/3/3A TR3A Adjustable Steering Triumph 5
J Wanted Adjustable steering wheel circlip Triumph Classifieds 4
E Wanted wanted Austin healey 3000 adjustable steering wheel & dash pad Austin Healey Classifieds 2
Walter74 Adjustable steering wheel removal Austin Healey 4
K TR2/3/3A Non Adjustable TR3 Steering Wheel Triumph 7
R TR2/3/3A Frozen Steering Wheel [Adjustable] Triumph 7
John_Koop TR2/3/3A Adjustable steering wheels Triumph 3
AUSMHLY Adjustable steering wheel removal Austin Healey 5
B Wanted Need '58 TR3 adjustable steering set up Triumph Classifieds 4
4tecdog Adjustable Steering how? Austin Healey 8
Lin Loosening adjustable steering wheel Austin Healey 3
Lbp TR2/3/3A Looking for info on adjustable steering wheel - Does a Healy wheel fit? Triumph 9
Lbp TR2/3/3A TR3A - Converting Adjustable Steering Wheel to Standard? Triumph 16
B Rocking movement in adjustable steering wheel Austin Healey 6
Lbp Looking for Adjustable Steering WHeel Triumph 5
F Replacing the horn push adjustable steering wheel Austin Healey 7
pkmh Removing BJ8 'Adjustable' Steering Wheel Hub Austin Healey 18
W Longbridge 100-6 and adjustable steering wheel Austin Healey 7
HealeyCopter Adjustable Steering Wheel Nut Stuck Austin Healey 10
G TR2/3/3A How does TR3A Adjustable Steering Work? Triumph 5
S Convert to adjustable steering Austin Healey 12
D Adjustable steering wheel stuck Austin Healey 6
bighealeysource Stator tube on adjustable steering 100-6 Austin Healey 5
JamesWilson Adjustable & Non-Adjustable Steering: Interchange? Austin Healey 2
K Adjustable steering wheel setup Triumph 2
longbridgehealey adjustable steering Austin Healey 6
tahoe healey Adjustable steering tightening Austin Healey 13
bt7tricarb Trafficator question [adjustable steering] Austin Healey 22
G Adjustable steering Triumph 4
B Non-adjustable steering wheel removal/adjustment Austin Healey 1
Johnny Non-adjustable steering wheel switch mounting. Austin Healey 2
C Identifying BN1 Adjustable Steering Wheel Austin Healey 7
P Non adjustable steering wheel removal Austin Healey 7
H Adjustable Steering Problem Austin Healey 4
P Adjustable Steering Triumph 2
GregW Adjustable steering wheel Austin Healey 13
WALTER adjustable steering Austin Healey 6
