Oil Leaks - What is normal/typical?
warwick-steve
I know all Healeys and other cars of this vintage leak but I am trying to get a grip of what is normal.
The engine on my BT7 is surprisingly oil tight. It doesn't seem to leak at all. I never have to top it up between oil changes. Similarly with the differential. The underside and chassis of the car from front to back is dry with no oil on wiring etc
However, the gear box does leak very slightly at the drain plugs and more elsewhere. There is more of a drip from the rear of the gearbox in the area above the stabiliser bar, exactly where it is leaking from I don't know. I estimate the amount lost from the gearbox/overdrive in 12 months is about 200-250cc. Is this normal/typical?
cheers
Steve
kozelding
Almost 30 years (and various engine and gearbox rebuilds) later, my spring garage clean-up is finally easy:
A long galvanized drip pan that, if I'm careful parking, runs almost the whole length of the engine compartment through the end of the overdrive. I then have a round houseplant tray under the differential.
Aside from the errant mouse mistaking the drip pan for a wading pool, all is well.... I'd say you're good.
... I estimate the amount lost from the gearbox/overdrive in 12 months is about 200-250cc. Is this normal/typical?
cheers
Steve
Depends more on miles driven. If you've only driven the car a few hundred miles, I'd say that is a bit excessive. If you've put a couple thousand on it, that isn't bad. At any rate, the only 'cure' is to go through the gearbox and OD and replace gaskets and O-rings. Your leak is probably from around the OD's brake ring--which doesn't usually have a gasket--or the rear seal on the OD. I haven't done it, but I think the rear seal could be replaced in situ.
warwick-steve
warwick-steve
Thanks Bob and kozelding
I think I will live with it for now. When it is up on the ramp for its 12 month test in May and I can get underneath I will have a closer look to see if I can identify where it is coming from
cheers
Steve
Michael Oritt
The most common Healey leak is engine oil getting past the oil slinger on the rear of the crank and out the bottom of the bell housing. If you do not have that count yourself lucky.
Transmission leaks are, as Bob says, the result of leaky gaskets/O-rings. Transmission oil is less of a mess than engine oil and while I could live with what you describe the solution is to go through the unit and renew all of the possible culprits.
K TR2/3/3A Oil leaks at two front cylinder head studs? Triumph 3
R TR2/3/3A Oil Leaks Triumph 24
Nelson Oil leaks again Spridgets 1
D Oil leaks Spridgets 22
lbcspinners A- H Frog E: no more Bugeye oil leaks! Austin Healey 4
M PCV and oil leaks Austin Healey 53
T external sealant for oil leaks Spridgets 6
M Can synthetic oil be cause of leaks? Spridgets 5
T Oil leaks under carb are - tappet inspection plate Spridgets 6
T sealing oil leaks in a horizontal joint Spridgets 6
rlich8 Introduction/Oil Leaks Triumph 14
K Oil Leaks! Triumph 10
RJS Crankcase Pressurization and Oil Leaks Triumph 11
T OIl Pan, no leaks Triumph 18
M new engine rebuild, new type oil seal and LEAKS ?? Triumph 15
T oil leaks Triumph 32
M Oil leaks continued Austin Healey 16
M Oil Leaks Again Austin Healey 7
M Oil Leaks Austin Healey 17
E T-Series Oil pipe leaks on '50 TD-help! MG 7
M Common engine oil leaks Austin Healey 16
chrisc Wedge TR8 Oil Leaks Triumph 2
Atrus Let's talk oil leaks ;-] Spridgets 16
G 1967 Midget rear end leaks oil Spridgets 12
Woodie starter works,, but now oil LEAKS !! Spridgets 13
S British cars and oil leaks explained!!! MG 2
G Carb oil leaks out MG 8
1 TR2/3/3A TR2/3 Oil Leak Where Oil Sending Pipe Connects to the Block Triumph 4
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
af3683 TR2/3/3A Recommended Oil Filter Cartridge for Purolator Triumph 8
R oil pressure Spridgets 2
RickPA Overdrive Oil Pressure Austin Healey 8
6 Valve Oil Seals Spridgets 10
RJS TR4/4A Smiths Oil Temp Gauge Triumph 11
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
Lotuswins Dry Spin-On Oil Filter Austin Healey 14
Todd78d Oil Spridgets 6
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
G Right-Side Shock Weeping Oil Austin Healey 1
scottkilpatrick TR4/4A Gear oil and choke question Triumph 4
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
G High Oil Pressure Austin Healey 2
T Spin-On Oil Filters for Cars with a Brake Servo Austin Healey 3
Bayless What oil for Datsun 5 speed? Spridgets 7
T Spin-On Oil Filters Anti-Drain Back Valves Austin Healey 0
T Spin-On Oil Filters Austin Healey 1
K TR2/3/3A Old school penetrating oil? Triumph 24
R TR6 question re: Engine Oil Triumph 3
nevets Spin-On Oil Filter Adaptor Austin Healey 12
D Overdrive Stops Working After Oil Change Austin Healey 26
