TR6 Door installation
ichthos
Hello. I need some help with my doors. I had to remove the passenger side door as it needed a great deal of work. I thought the worst was over until I went to reinstall the door. I traced the hinges before I removed the door. Trying to line up the hinges with the floating bolt plates is frustrating. Does anyone have any tips for reinstalling the door? Any suggestions are appreciated.
TR3driver
Great Pumpkin - R.I.P
You might try the old trick of installing a couple of studs (longer bolts with the head cut off) first, to guide the hinge and hold the plate. After you've installed the other bolts, back the studs out and replace them with bolts.
I
ichthos
Thanks. I will try that idea. I saw a fairly inexpensive car jack that looks like a cradle on Amazon and ordered it. I plan on painting my car once I fix everything to my satisfaction, and this will be good practice.
ed_h
I use a floor jack with a soft pad under the door.
Ed
charleyf
What I do on a car that still has the doors on it and in proper position is to drill two 1/8 inch holes through each door hinge and car body before taking the door off of the car. Then when you go to reinstall the door you use either a nail or a pin to locate the hinge into the old position. The same thing works for the hood hinges on the TR4 and 6. Match your drill size to the pin that you will use for more accuracy.
Edit-- the pin I refer to is a roll pin. Just match your hole the size of the roll pin you use.
nichola TR6 Door handle and window crank installation Triumph 0
B BT7 Door Seal Installation Austin Healey 13
C Door adjustment after installation of new door panel? Austin Healey 9
Michael Oritt Door check installation Austin Healey 7
H General Tech Door Glass outer seals installation Triumph 6
TEM666666 Sprite MK1 Door liner rubber mat installation.. Need tips and recommendations. Spridgets 22
B '72 XJ6 Door Seal Installation Jaguar 2
W BE door installation sequence Spridgets 3
R BJ-7 Furflex door seal installation. Austin Healey 1
Paulus Door to window seal installation? Triumph 7
P BT7 door pillar cap installation Austin Healey 3
S BJ8 Door Moulding Installation Austin Healey 6
drooartz Spring service of the 4-door Sprite (Morris Minor) Spridgets 4
A 100/6 BN4 Door Lock Austin Healey 15
SpeedyG TR4/4A Door window regulator spring Triumph 5
SpeedyG TR4/4A Interior door handles and escutcheons Triumph 9
AngliaGT Wanted Two inside window handles & Regulator for Driver's Door - '67 GT MG Classifieds 6
AngliaGT MGB-GT WANTED: Driver's Door Regulator + Two (2) interior handles. MG 1
D Older door panel clips Restoration & Tools 4
BoyRacer Door Skin Removal Austin Healey 6
Southwarks TR2/3/3A TR2 door help! Triumph 2
M For Sale 2017 Jaguar F-TYPE Premium 2-Door Convertible for Sale mlbirk@aol.com Jaguar Classifieds 0
R MGB MGB Roadster Door Panel Speakers MG 9
D Top Door rubber and fuzzy seal Spridgets 5
J For Sale Triumph TR3 door, left, for sale Triumph Classifieds 0
Popeye TR4/4A Door seal channel near top of windscreen Triumph 6
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
D MGB Older style door pulls MG 0
V Door Seals Austin Healey 8
Bayless Door seal question Spridgets 3
Donald1107 TR2/3/3A Door hinges Triumph 14
algot1901 1950 Prefect E93A-946480 - door bottom rubber Other British Cars 14
D Door Seal Fit Austin Healey 18
D For Sale BT7 interior door cards - new ! Austin Healey Classifieds 0
E 3000 Healey Door Checks Austin Healey 1
A MGB MGB a glove box door MG 10
chicken BJ7 Door Fit Austin Healey 27
Patrick67BJ8 Glazing Door Window Glass in BJ8 Austin Healey 15
F Door Panel Hardware Austin Healey 3
LAW75 Door Latch Adjustment Austin Healey 22
BoyRacer Door Panel Measurements Austin Healey 3
LAW75 BJ8 Door Locks Austin Healey 2
Cappy Occasional Door Malfunction Austin Healey 1
J Door Draught Metal Clips Austin Healey 4
F Interior Door Handle Removal Austin Healey 2
F Wanted wanted new old stock driver side door latch Triumph Classifieds 2
