TR2/3/3A Running a little hot...
HighAltitudeTR3
Just got on the road for the season and I’m running a little hot... what can I do staying as stock as possible to cool ‘er down a bit? I wash running fast and hard today to push her a bit to prepare for an up and coming trip... if rather make the journey than have to pull over every 30 mins. Thanks
TR3driver
Great Pumpkin - R.I.P
Do you have the cardboard air deflector in front of the radiator?
Slots in the grille opened up?
Both centrifugal and vacuum advance working?
How much glycol in the radiator?
Geo Hahn
Flushed the cooling system in recent years?
Using a sleeved thermostat or else added a partial blockage to the bypass hose?
Verified that fuel mixture is not too lean? (how do the plugs look?)
mt10flyer
I also have a high altitude TR3. I live at 6000', work at 4500' and on the drive home I used to overheat no matter the time of the year. It seems that the car was designed for driving in jolly old England, where the highest point is Ben Nevis at 4400, and there isn't a road to the top of that. The cooling system just wasn't designed for Aspen or the Sierra Nevada. I tried adding an electric fan while keeping the original "fan", I replaced the water pump, cored the radiator, replaced the ugly card board thing in front, added an oil cooler and it just didn't help.
So I punted and replaced the radiator with this:
https://wizardcooling.com/1953-1965...with-11-fan/?gclid=CN2GydCa5tMCFY22wAod9AoHTg
Since then, no problem at all. The fan has only come on twice. I am one who is more interested in performance rather than stock so you may not want to go this way, but it sure worked.
charleyf
I am originally from Colorado and had a TR3A for a number of years while there. Then moved to Southern Calif. and drove the car to work daily both places. I never had a cooling problem with that car. Then I sold that car. Years later I bought a TR3B in northern Calif.. The only over heating problem I had with that stock cooling system was caused by a really messed up carb adjustment. Once the carbs were properly adjusted the problem was gone.
Back to the Colorado experience, during the last VTR convention I drove my TR4 to Colorado along with a friend in his TR3B. We toured Colorado and went over I believe 8 10,000 foot passes . Neither one of us had any cooling problems. But I am running a Wizard aluminum radiator in the TR4 . The TR3 was has the stock cooling system.
I think these cars can do well if properly set up.
karls59tr
Bronze
Run 35% glycol ....15% "water wetter"....50% distilled water. The rad has to be in top condition. I run an electric fan in front of the rad linked to a toggle switch that I flip on when I'm stuck in traffic on a hot day. I replaced the stock fan with a yellow TR6 fan. The stock fan dosn't move enough air. It might be OK for England's weather!
Hill Billy
Check your distributor and vacuum advance unit. Running with late timming will cause it to run hot. If the vacuum advance is not pulling vacuum and advancing the timming at road speed it can run hot. I replaced my vacuum advance unit on my MGA and it runs much cooler now.
Got_All_4
Sometimes the veins in the radiator get plugged. Flushing and back flushing may help a little but is better to get them cleaned out by a professional. I had to go around to a dozen radiator shops before I could find a shop to remove the tanks and clean the veins out. Everyone wanted to re-core it and I would loose the hole for the crank. Like you I wanted to keep the original look so with doing the clean out and swapping out the original fan with a GT6+ metal fan it has never over heated. The GT fan looks original and after I painted the blades silver no one has ever noticed it even in a LBC show.
TR3driver
They don't even have to be plugged all the way. Last time I went around this tree, I was using a radiator that had worked fine in the past but sat unused for a couple of years. The radiator shop said it flowed fine, there was no need to rod it out. After trying everything else, I finally insisted that they do rod it out. Surprise, surprise! Although none of the tubes were actually blocked, they had a terrible time forcing the rods through, and wound up with 5 or 6 leaks once they did. The inside of the tubes were coated with "mud" (highly technical term there, doctor) that was apparently mostly old stop-leak; and was blocking the transfer of heat from the coolant to the fins.
Rather than mess with the leaky core, I had a new core installed. My shop gave me the option of putting a hole in the new core, but said it would reduce cooling capacity by about 10%, so I elected no hole. All of my cooling problems vanished like magic!
sp53
Yes get the GT6 fanand re-core, if lucky- if not, get the re-core with the GT6 fan that is thebest way. If you cannot get the GT6 fan then get the Macy copycat fan.
Geo Hahn
... Like you I wanted to keep the original look so with doing the clean out and swapping out the original fan with a GT6+ metal fan it has never over heated. The GT fan looks original and after I painted the blades silver no one has ever noticed it even in a LBC show.
FYI - what it looks like:
I was able to have a local shop re-core my radiator with a core that had a crank-hole. He just ordered it out of a big book, possibly most shops use the same source.
R running a little hot? Other British Cars 7
K TR2/3/3A What are the running symptoms........ Triumph 21
T General Tech Running hot Triumph 8
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
shadowfever Running well, then no fire Spridgets 7
C Rough-Running 3000 Austin Healey 29
S MGB Running poorly MG 7
tr6web TR6 TR6 rough running - what can it be? Triumph 17
Hamish Racing TR2/3/3A Winter engine running in - icy Triumph 7
R running car on jack stands Spridgets 16
BierRunner TR6 TR6 Running Rough Triumph 5
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
B For Sale 57TR3 Small Mouth with OD Project. 12 yeqrs running. I'm not going to finish Triumph Classifieds 14
sparkydave Trouble running hot Spridgets 10
T TR2/3/3A rough running after 20 min shutdown Triumph 9
S TR2/3/3A Running rich SUs. Triumph 25
Y Wanted Looking for running 3.5L MK V engine Jaguar Classifieds 0
J Spitfire 1979 Spitfire Running rough [sputtering, exhaust poping] at start up Triumph 2
Gliderman8 Starter keeps running TVR 20
Rut MGB Running out of gas symptoms MG 21
K TR2/3/3A Anyone running NGK spark plugs? Triumph 26
T TR2/3/3A Anyone running tubeless radials on TR3 steel radials? Triumph 2
N Running Cold Austin Healey 12
bugedd Car running poorly Spridgets 7
Bob_Spidell Running hot/Overheating Austin Healey 44
Martinld123 SU carbs lose fuel prime when not running Austin Healey 3
mailbox For Sale 76 TR 7 project car [non running] Triumph Classifieds 0
N Stuck Needle Valve - Rough Running Austin Healey 15
J For Sale 1976 Sptifire with 1.8L Miata engine/5-speed [running like a boss!] Triumph Classifieds 0
BN6 Breaking In Running In a newly built Healey Engine Austin Healey 15
R TR2/3/3A TR 3A running hot at high rpm Triumph 12
M Proper running temp for 1275 Spridgets 28
D Lilly running #3 / since last we talked.... Austin Healey 7
D Lilly second time running... or trying Austin Healey 8
D Lilly first time running in 15 years.... Austin Healey 19
sd80mac7204 TR6 Interesting TR6 running issue Triumph 19
glemon TR5/TR250 Stumped TR250 Running Rough--Follow Up Triumph 3
glemon TR5/TR250 Stumped TR250 Running Rough Triumph 8
F TR2/3/3A SUs Running Rich Triumph 25
S TR2/3/3A Struggling to stay running during warmup? Triumph 0
vette Constant Engine Running RPM. Austin Healey 20
S TR2/3/3A Oil Leak Dripping from Front and Rear of Left Side Oil Pan---Only While Running Triumph 14
C T-Series MGTC Running Boards MG 1
gbtr6 TR6 TR6 no start after running amazingly well til now. Triumph 16
K TR4/4A Running the motor witout the gearbox installed? Triumph 3
D Rough running BT7 3 carb HELP Austin Healey 13
M TR5/TR250 problem getting engine running Triumph 15
D Nice to hear the old girl running again. Austin Healey 2
R MGB-GT Just purchased Tuned for sea level, but I live at 7500', running rich MG 7
cpbol Sharing story - Solving issue of starving for fuel after running for 10 minutes Austin Healey 67
