BJ8 Choke Cables
Patrick67BJ8
My cables from the firewall to the carbs were binding and lost their original smoothness so I ordered a new set and was sent cables that I believe are bicycle cables. They do operate very smooth but the outer cable is “skinny” compared to the original and I want to add a black sleeve over it like the originals had plus it would help the fitting connections at the firewall.
does anyone have a source for the black plastic material? I tried drip irrigation material but the ID was too narrow.
Keoke
Try Heat shrink tubing may work Patrick ??
steveg
7mm cable housing, sold by meter:
mgtf328
I've just replaced mine with bike brake cables. I know what you mean about the thickness of the outer cable but I don't mind that. My cables had ferules at the ends which fit into the housings on the car at each end of the cable. The ferules were a little large so I had to shave them down a bit to fit into the housings on the car. You could buy the ferules separately at the bike shop I went to.
AJ
steveg
I installed set screws at the brackets on both ends of the cables - this promotes positive return of the choke levers without add-on springs.
A piece of scrap tubing forced over the bracket stub forms a seat for the metal inner cable housing.
See:
https://www.pbase.com/stevegerow/healeychokes
S BJ8 Choke Cable- How to tighten the nut behind the dash? Austin Healey 6
B BJ8 choke cable Austin Healey 0
N BJ8 choke adjustment Austin Healey 4
6 BJ8 Choke Problem AGAIN Austin Healey 5
6 BJ8 Choke Impossible to Live With Austin Healey 17
Dave Richards Choke Return Springs BJ8 Austin Healey 13
B BJ8 Choke cable - wont move Austin Healey 19
6 BJ8 Choke Problem Austin Healey 3
WALTER BJ8 CHOKE ADJUSTMENT Austin Healey 14
1 BJ8 History Trace Austin Healey 7
D BJ8 Top Installation Detail Austin Healey 3
S Wanted WTB: 3.5 ratio diff/pumkin for '67 BJ8 Healey 3000 Austin Healey Classifieds 0
AUSMHLY BJ8 Trans Cover Carpet Austin Healey 7
AUSMHLY BJ8 Carpet and Snaps Austin Healey 2
Overdrive45 BJ8 Interior Trim Austin Healey 8
nitro BJ8 Production Year Austin Healey 6
B BJ8 Seat Sliders Austin Healey 4
BoyRacer For Sale BJ8 disk wheel hubs, spindles & calipers Austin Healey Classifieds 0
S SOLD!! For Sale 1964 AH 3000 MkIII BJ8 Phase 1 Austin Healey Classifieds 2
Patrick67BJ8 BJ8 Factory Hardtop Rear Window Austin Healey 6
AUSMHLY BJ8 Clutch Pressure Plate, Old vs New Austin Healey 4
AUSMHLY BJ8 Clutch Fork Bush Replacement Austin Healey 5
AUSMHLY BJ8 Cylinder Head Installation Austin Healey 6
LAW75 BJ8 Brake Lines Austin Healey 2
AUSMHLY BJ8 Clutch Pressure Plate Brand Preferences Austin Healey 3
BoyRacer For Sale BJ8 spindles & disc wheel hubs Austin Healey Classifieds 0
G Wanted BJ8 Tonneau Cover Austin Healey Classifieds 0
Cutrog1 For Sale Healey 3000 BJ8.... a restoration saga Austin Healey Classifieds 0
AUSMHLY BJ8 Overdrive Oil Passages Austin Healey 2
Scotsman Wiring Diagram for 1966 BJ8 Austin Healey 3
A For Sale 1966 3000 Healey Blue BJ8 Austin Healey Classifieds 3
B BJ8 Hood Bow and Seal Austin Healey 5
Mickey Richaud Wanted Wanted: BJ8 Seat Track Sets (Both Sides) Austin Healey Classifieds 5
Scotsman BJ8 Intake Manifold Differences Austin Healey 4
AUSMHLY Laygear End Float BN1-BJ8 Austin Healey 2
C For Sale BJ8 original dash Austin Healey Classifieds 3
LarryK BJ8 Parts or Project Car For Sale in St. Louis Austin Healey 3
Patrick67BJ8 BJ8 Intake manifold Booster & Vacuum Hookup threads sizes. Austin Healey 2
B BJ8 Centre Console Chrome Strips Austin Healey 5
B Wanted Chrome strips centre console BJ8 Austin Healey Classifieds 0
