Differential oil for 100/4 1954
Walker sim
I have just purchased an early 100/4 (chassis 150913). It's been in storage for 30 odd years & I am replacing the liquids. 20.50 seems the choice for engine/box/OD, but I'm stuck with a diff oil. The manual mentions the early cars, pre engine 221536, had something other than hypoid. Any suggestions?
Michael Oritt
According to Clausinger your car has a spiral bevel gear diff versus hypoid in later cars. I don't know if the original differential oil spec was different between the two types but since they both involve some gear sliding I think you would be best off with a synthetic GL5 oil, either 75-90 or 75-140. Better diff oils, which stand up best to shearing forces, carry an Extreme Pressure description which costs a bit more but given how infrequently one changes diff oil I would treat your car to the best available--diffs are no place to cheap out. I use Amsoil Severe Gear (EP) in 75-90.
MikeAH100M
Michael - Do you find that the synthetics tend to leak more easily? Found that with lighter oils but not sure if that would be the case with 75/90?
Michael Oritt
Michael--
75/90 diff oil roughly corresponds in viscosity to 30 SAE.
That said, I don't know if synthetic diff oil leaks more because I have never used any non-syn diff oil, but I'll accept the common wisdom that it does.
I've run Redline 75W-90 gear oil in both my Healeys' diffs for several years. I didn't notice any more leaking than with dino diff oil. I'm now running Redline 75W-110 in the BJ8 to help quiet some diff whine.
gonzo
The shop that just rebuilt my 3000's rear diff recommended Lucas Synthetic Gear Oil 75W 90 which I had planned to use anyway. About 2.25 US qts. fills the diff from empty. Good stuff. GONZO.
Did they recommend synthetic for break-in? What were their break-in instructions?
gonzo
Yes. I know the internet has all sorts of ring and pinion "break-in" instruction, so I asked the builder. He replied: "bolt it in, add gear oil (synthetic), drive and enjoy." I liked the "enjoy' part since it implied "don't sweat it". GONZO
HealeyRick
Having read the ring and pinion break-in instructions it made me wonder why new cars never include such instructions. I don't imagine they are broken in on the line.
Michael Oritt
Gonzo--
Are we are talking about a freshly manufactured ring-and-pinion set such as was supplied by Mike Lempert or did your shop rebuild the differential by setting up the "lash" and perhaps putting in new bearings and/or a new pinion seal? If, as I suspect, it is the latter then the gears--the ring and pinion--were already broken in by previous use, which is why the instructions were what they were. OTOH with a brand new R&P set it would probably be wise to drain the diff oil after a couple of hundred miles to get out any little bits, then refill and carry on.
IIRC, the Lempert ring & pinion set we installed came with very specific instructions. The diff can get very hot--mine got almost 'pistol hot'--during break-in and the instruction called for short, then progressively longer runs with a cooling-off period in between, followed by a drain and fill after a few hundred miles. But, I used mineral gear oil for the break-in; apparently synthetic eliminates the need for such a procedure. My Mustang, new in 2008, had no specific break-in procedures so I followed my dad's advice: 'Break it in how you're going to drive it.'
gonzo
Shop rebuilt the diff with new R&P (Moss = AH Spares), bearings and seal and set up lash etc. I'm taking it easy on the diff. Last weekend I took the car out for two test runs of about 15 - 20 miles allowing a "cool down" in between. The Diff did not heat up any more than usual and did not make any unusual noises. Gear oil will be changed in about 500 miles. No leaks from axles, diff pinion seal or join to diff housing after complete cool down. Longer run cycles - 3 or 4 depending - planned this coming weekend. GONZO.
Michael Oritt
"Shop rebuilt the diff with new R&P"
Good going and by all means follow the advice given. Given what I am sure is a substantial investment the rear axle deserves the best care and feeding available!
vette
Also: [ QUOTE= GONZO; ] Yes. I know the internet has all sorts of ring and pinion "break-in" instruction, so I asked the builder. He replied: "bolt it in, add gear oil (synthetic), drive and enjoy." I liked the "enjoy' part since it implied "don't sweat it". GONZO].
:iagree: . I am also sure that any routine change of any lubricant can't do any harm to any running components.
HEALEYJAG 100 BN-1 differential oil plug Austin Healey 2
S TR2/3/3A Differential Gasket & Oil Leak Triumph 9
N Spitfire Changing Differential oil Triumph 14
K TR2/3/3A Correct oil level for differential? Triumph 5
R Differential Oil Capacity Austin Healey 10
Jim_Gruber Transmission Oil and Differential Spridgets 3
go_inbroke Differential Oil Triumph 20
T Differential Oil? Triumph 6
C Differential oil seal help Spridgets 8
J Rear Axle/Differential Gear Oil Spridgets 13
RickB What oil in differential for MK2 Sprite? Spridgets 5
H Differential Oil Recommendations Austin Healey 48
bigjones Brake drum leaking differential oil Spridgets 29
mountainman Tran and Differential Oil? Triumph 33
mountainman TR2/3/3A Replacing Differential Tail Oil Seal TR3 Triumph 9
T Oil Seal-Differential Triumph 21
NickMorgan Differential oil and seals Triumph 15
RandallRK Differential oil drain plug Austin Healey 13
S Differential oil seals Triumph 8
Wana Gearbox and differential oil change Austin Healey 8
hondo402000 Differential Oil Change question Triumph 11
T TR6 What year TR6 did NOT have a differential oil drai Triumph 11
C TR6 TR6 Differential Oil Seal ? Triumph 0
jaybird Differential fluid/oil MG 6
tahoe healey differential oil Austin Healey 2
Rick O. Differential Oil Triumph 3
S TR2/3/3A when rebuilding a differential Triumph 9
scottkilpatrick TR4/4A Difficulty Level Opinion - Differential Gasket Replacement 62 TR4 Triumph 10
B TR2/3/3A Possible differential problem Triumph 3
S TR2/3/3A Placing the differential on the frame Triumph 4
S Spitfire Differential clicking Triumph 6
CARSINC For Sale Sprite Differential Spridgets Classified 0
S TR2/3/3A old 4 bolt axle differential. Triumph 11
T Rear/Differential "Clunk" Austin Healey 2
W TR2/3/3A Differential cover torque Triumph 4
G Spitfire Spitfire 1500 differential whining Triumph 6
B Midget Differential Capacity Spridgets 5
R Changing BJ7 Differential Ratio Austin Healey 10
R For Sale TR6 REAR DIFFERENTIAL Triumph Classifieds 3
A TR6 Installing differential and transmission Triumph 10
Sarastro TR4/4A Differential setup question Triumph 12
Ripper01 Sold- TR6 Differential drive Triumph Classifieds 1
Ripper01 For Sale Sold-TR6 Differential Triumph Classifieds 0
Michael Oritt Wanted 4.22:1 spridget differential Spridgets Classified 1
J TR6 TR6 Differential Rebuild question Triumph 6
J TR6 Differential / Rear Axle Triumph 1
