TR2/3/3A overdrive cable routing: and mounting the drive train
Dr_Mike
TR3 with TR4 gearbox and overdrive.
I know this has been discussed at length, but I am still puzzled how to get the speedometer cable past the frame. Either I can go under it, a bit exposed, or I can go through the same hole as the rear brake line, and worry about chafing ( though I thought I would try to immobilize the two things with silicone). I know the second method has been used by some of you: maybe it is the only way.
I stretched the holes at the rear mount, and the unit seems to sit square on the front mounts so i thought all was well. But when I added the crosspiece that supports the front panel the hood latch is (just) rubbing against the top hose. Goes this mean that I have to grind off a bit more at the back, even though the front mounts seem OK. Or could it be that the top cross member is out of whack: I have not had the chance to put on the hood/bonnet to see if the latch is out of place.
I will try for a photograph today. still lots to do!
TR4nut
I just routed the same cable on my 4 - Not sure it is correct but I went through the same grommet as the brake line. Not much if any movement there so I don’t think chafing will be a concern on the brake line.
Dr_Mike
Thank you. It seem logical!
The other issue may well be due to crooked mounts for the crosspiece. Piggots book shows half an inch of clearance for the hose and there is no way that another eighth inch of grinding away the rear holes is going to give me that: so i shall fit the front apron (or the rather heavier hood) and see if that will push it into place.
CJD
If you jack dead center under the front crossmember the frame will spread to fit the brace with room to spare. Is there another problem going on, though?
Dr_Mike
I have confused the issue!. I think you are referring to the tubular cross member with three bolts at each and. Wish I had known that jack trick when I fitted it.
My problem seems to be with the aluminum crosspiece which supports the apron and the closer mechanism and which is bolted to the top of the inner wings on the body shell. Although the body was reassembled meticulously there was a different crosspiece used and the aluminum one may not sit quite the same. Anyway that is what i am hoping today, and I can measure from the hinge bolts on the body and the bonnet and see if they are the same. Does that confuse even more? Off today to do just that,(measure, not confuse) and praying that all I have to do is readjust the crosspiece
TR4nut
Good luck. If you can post a picture or two we might be able to see if anything looks out of whack. I’m skeptical that the transmission mount is the problem, particularly since you could use the front engine mounts.
charleyf
l. The base pieces on the fenders are welded on. I would think that you could see evidence of any old welded position if they have been moved. You do have the cross piece located in between the two raised parts of the base pieces?
Out of curiosity --how much distance is there between the rear of the engine and the firewall? On my cars there is not much, just enough for the accelerator cross linkage plus maybe an inch. I would also think that the fan blades would be very close to the radiator if the engine is very far forward.
Dr_Mike
the only solid measurement I could get was between the back of the head and the bulkhead/firewall. that was 4 cm.; a bit less if you measure from the edge of the valve cover. How does tart compare?
no evidence that the mountings for the crosspiece have been moved: bent, twisted and abused, but not moved.
I really cannot judge the position of the crosspiece until I fit the apron. It is canted slightly forward at the moment which brings the striker and spring backward into contact with hose. I am going into a "wait and see" mode for now, but I have a couple of photos to share
CJD
Ah...that makes more sense...and that is a new one. Both my cars cleared the bypass hose by almost an inch. It would almost have to be the front mounts causing the lack of clearance??
Dr_Mike
No shims, as handcrank/starting handle goes neatly into place through the radiator.
I suppose one solution would be to shim up the body but it seems a bit late in the process to do that. Another is to move the engine back, or twitch the crosspiece. Can anyone measure the space between their head and the firewall to give me an idea of what that should be?
AS an aside I am regretting the decision to use a different frame. The original had been well straightened except for one front turret which needed be replaced. As it turned out it would have been cheaper and quicker to get a new turret from UK to replace the damaged one. The replacement frame seemed straight and the body sat on it quite neatly until this came up! I am paying through the nose for my covered space and I do not want to prolong the process by back tracking. But...
PS I have a nice straight frame which needs a new turret if any one is interested!
charleyf
Mike,
I am wondering if your problem may be that your engine is to "high" as opposed to to far forward. Could you have a TR4 front engine plate on your engine? A TR4 front engine plate will move the engine higher in the car by about what you are experiencing. I have heard that one can not mount such an engine plate on a TR3 frame. But I suspect that may not be true. It will mount but not everything fits correctly. I checked the two engine plates to see for myself the difference in how they fit.
Dr_Mike
There's a thought!
Can you describe the difference?. I am not sure about it being too high given that the crank lines up with the radiator but I am definitely in new territory. Well, i guess I am way out of my comfort zone!
Again, a measurement of your (car's) head to the bulkhead would be helpful.. Mine is 4 cm and it is the only firm measurement I can get for fore and aft position.
Michael
1964 Morris Minor convertible , our summer driver
1960 TR3A, a very long term project
ex 1933 Standard 6 cylinder touring Europe in 1954!
etc.
CJD
Before you come to any conclusions and impose drastic measures, it's about time to fit the bonnet and see how it fits into the opening between the scuttle and apron. The problem could just be that your apron is to far aft, which would also shorten the opening for the bonnet.
If the bonnet fits well into the opening, then perhaps attempting loosen all the body bolts and bump the entire body forward a half inch.
In response to the possibility of the engine maybe being high...both my TR3A and TR2 would clear the bypass hose to spring even if the engine were 3 inches higher. They have for and aft clearance.
TR3A:
TR2:
CJD
When I look at pic #3 in this post, it looks like your apron bow mounting tabs have been bent rearward...possibly accounting for the missing clearance. There is room to bend the mounts forward, or at least "straight".
charleyf
There's a thought!
Michael
etc.
Mike,I am no help on the present fit as the engine is not in the car. It looks like John has some good pictures to use for comparison.
sp53
sorry about the word spacing, I could not fix it
Now that is Art John, and I was thinking the tabs could also move forward also. If you do put the cross piece on the apron after you straighten the holders, I found temporally leaving the row of attaching bolts along the cross piece and apron loose, lets the apron have some wiggle room up and down for the fenders and hood clearance until you get a good idea of how everything will line up. The hood is usually tight and the vent lid can be tight also.
There is about a ½ clearance on mine between the hood spring and hose. I think a different hose will give you more room also. That hose is too perfect and too much of a 90 at the spring; the hose could come back more and the cross brace go forward some and then I think you will be good. Again the hood is usually tight so going down some might be what you want any. So fit the hood, apron and vent to give you the correct clearances.
The reason my car has a red hood rod is because I have been working on getting some of the body noises out from under the hood. That red hood rod is original, and I found the bent tip to be a ½ shorter than the aftermarket ones. Now when the rod is in the holder and hood closed that tip does not hit the hood and rattle. I just need to paint it.
John are those plug wires metal core? If so, where did you get them?
John one thing; those bolts on the battery holder J hooks should be brass wing nuts. Just thought you would like to know.
Peace out Steve
Dr_Mike
John:
It looks as though my engine is more forward than any one else's though there is (by now) a lot of variability. I will take your advice and fit the bonnet, and perhaps the apron too, before doing anything drastic.
If any passerby has an actual measurement behind the engine could you let me have it. It would be interesting, at least to me!
I looked at an alternate bypass hose ( from Moss) and it lied as though it would be worse. I don't know the source of the on in the picture, but I did lop off half an inch at the top.
I had hoped to start the engine this weekend, but I think i will call a time out to make sure things do fit.
Michael
sp53
I would think if you motor mounts are lined up engine andframe that part would be fixed. I measured and I have an inch and 1/8 ---itdoes sound like you modified something for the different trans. But maybe trythe rest of the body parts and see what you get. Just a bolt here and there.
CJD
Just wondering, Mike, is the bonnet spring straight or is there a chance it is bent rearward? I'm betting the problem is accumulation of little clearance variances due to our hand made cars.
Thanks Steve, now I have a reason to get back on ebay...wing nuts!! I think you are enabling me.
G `Request for Overdrive Speemometer Cable Routing Picture Triumph 0
T TR2/3/3A TR3 w/overdrive speedo cable routing??? Triumph 2
KVH TR4/4A Long Speedo Cable for Overdrive--where does it get tied down? Triumph 7
P Mysteries under the BJ8 transmission tunnel, speedometer cable, overdrive and gerabox Austin Healey 1
B Overdrive speedo cable question Triumph 6
2wrench TR6 '74 TR6 Route of speedometer cable from overdrive. Triumph 7
RickPA Overdrive Oil Pressure Austin Healey 8
bighealeysource Leaking Overdrive and Gearbox Drain Plugs Austin Healey 19
71TR6 TR6 Type-J Overdrive identification Triumph 4
T Wanted Working overdrive unit Austin Healey Classifieds 2
D Overdrive Stops Working After Oil Change Austin Healey 26
S TR2/3/3A overdrive does not function Triumph 45
T TR2/3/3A A type overdrive hard engagement Triumph 36
S Overdrive Throttle Switch Austin Healey 4
KVH General Tech Overdrive--Afraid it's Serious Triumph 45
M Overdrive Pressure Test Austin Healey 2
BN6_2197 Gearbox/Overdrive Removal Austin Healey 25
T For Sale MGB Black Label Overdrive For Sale Or Trade For New RB Parts MG Classifieds 2
Fanch00 Non-Overdrive Benefits? Austin Healey 10
AUSMHLY BJ8 Overdrive Oil Passages Austin Healey 2
R TR6 J-Type overdrive will not disengage when warm Triumph 8
S Overdrive Relays Austin Healey 2
AUSMHLY Overdrive Buffer Pad Austin Healey 3
L Stuck in Overdrive Austin Healey 10
AUSMHLY Flushing the Transmission/Overdrive Austin Healey 7
T Weight of BJ7 Transmission/Overdrive Austin Healey 10
P Overdrive Not Engaging Austin Healey 4
S BJ8 Overdrive Stays Engaged Austin Healey 35
AUSMHLY BJ8 Overdrive Accumulator Spring Tube Austin Healey 1
RonC TR2/3/3A J Type Overdrive in TR3A Triumph 4
AUSMHLY BJ8 Overdrive Pressure Loss Austin Healey 11
AUSMHLY BJ8 Overdrive Oil Pressure Austin Healey 14
John Turney Overdrive Pump Austin Healey 6
S Removing Overdrive Shaft Lever Pin Austin Healey 7
nevets Reversing With Overdrive "On" Austin Healey 8
Healey Nut Overdrive Relay Austin Healey 1
T Clutch or Overdrive Slip Austin Healey 8
G TR4/4A "Engine seized after engaging overdrive at low speed. Triumph 26
A TR4/4A TR4 Overdrive Solenoid Triumph 19
H TR4/4A A-type overdrive pump Triumph 4
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
Rob Glasgow New Fangled Electric Overdrive Austin Healey 9
Got_All_4 TR6 Refurbishing gearbox with A type overdrive Triumph 7
J Transmission and Overdrive Rebuild Austin Healey 6
C Overdrive Failure Austin Healey 18
D TR2/3/3A Overdrive question. Triumph 49
ckeithjordan TR2/3/3A Overdrive Wiring Triumph 5
D TR2/3/3A Type A overdrive not engaging Triumph 0
D TR2/3/3A Type A overdrive not engaging Triumph 16
