TR4/4A Cleaning Striker and Restraint Assemblies
TRMark
Bronze
So I am painting the doors this weekend. The striker and restraint assemblies are going to look really bad unless I clean them and get rid of the oxidation. Any suggestions?
M_Pied_Lourd
I glass bead blasted mine and then did the fake cadmium coat spray paint system from Eastwood on mine.
Cheers
Tush
TRMark
TRMark
Bronze
Thanks for the help, I was hoping there was an easier way of cleaning them up instead of blasting in the cold. You know, something truly lazy. So I got my pressure tank blaster going, already had glass in it. It took longer to set up then the job. Don't think I will use the cadmium though.
tr6nitjulius General TR Waterless, easy/peasy, engine cleaning Triumph 2
S TR2/3/3A Parts cleaning. Triumph 4
P TR2/3/3A Block treatment post cleaning Triumph 17
B Electrochemical cleaning of stainless steel welds Restoration & Tools 7
B Car care/cleaning? Lotus 5
Basil Cleaning fuel injectors Restoration & Tools 4
K TR2/3/3A Cleaning the Solenoid contacts? Does pressing the small chrome "button" release the bake light fixture to access the contacts for cleaning? Triumph 7
L TR2/3/3A Stupid Engine cleaning question Triumph 9
F Undercarriage Cleaning Austin Healey 13
S For Sale Big Barn Cleaning Triumph Classifieds 0
T TR2/3/3A Instructions for cleaning & re-lubricating speedometer? Triumph 5
H Machined Engine Block - Cleaning before assembly and paint. Not sure what to do? Spridgets 5
NutmegCT Fuel tank cleaning/restoration Restoration & Tools 47
H Third Member - Differential - Carrier Housing - Center Section - Gear Set Cleaning Spridgets 4
SASSAMON TR2/3/3A Help Wanted In Cleaning Corrosion Off SU Carbs Triumph 20
K TR2/3/3A Cleaning the gas tank...what have I done now? Triumph 19
B TR2/3/3A Control column turn signal cleaning Triumph 8
K TR2/3/3A Cleaning a gas tank with muriatic acid.... Triumph 7
PKPoole TR2/3/3A Spring Cleaning Done Triumph 2
E TR4/4A Cleaning of alloy parts Triumph 4
GTP1960 TR2/3/3A Cleaning/degreasing timing chain Triumph 11
S TR2/3/3A cleaning wire wheels Triumph 6
R TR4/4A Question about cleaning instrument faces Triumph 8
G What's Your Best Car Cleaning Tip? Restoration & Tools 0
K TR2/3/3A Speedometer cleaning ? Triumph 3
Gliderman8 General Tech Cleaning sludge/varnish from a gas tank Triumph 6
cologero_100 Cleaning the satin chrome grille on a 100/4 Austin Healey 2
M Cleaning up under the hood - just how much needs to be painted? Spridgets 2
drooartz Cleaning out the parts: gauges, lights, console Spridgets 4
drooartz Cleaning up wiring Spridgets 17
H TR4/4A 4A grille cleaning Triumph 10
simon1966 Parts cleaning? Austin Healey 6
D Finally done cleaning!!! Spridgets 2
Jim_Gruber Spring Cleaning Special - Lower Valance for Spridget off of a '68 Sprite Spridgets 10
M_and_P Spring Cleaning Spridgets 0
JPSmit Cleaning Tip Restoration & Tools 0
T Cleaning a White Interior Triumph 0
drambuie Strip cleaning frames engines and bodys Austin Healey 5
W What size taps and dies for thread cleaning ? Austin Healey 7
Tr3aguy Chemical dipping vs media cleaning? Triumph 4
K Cleaning up exterior surface of SU's? Triumph 8
M Cleaning regulator and cutout contacts Triumph 4
R Lens Cleaning/Polishing Triumph 5
dklawson Gauge Face Coating after Cleaning? Spridgets 1
dklawson Gauge Face Coating after Cleaning? Triumph 2
L Advice for cleaning/painting 1980 rubber bumpers MG 8
S cleaning old plastic Triumph 6
JPSmit Cleaning parts tonight Spridgets 6
regularman Spent the day yesterday cleaning and painting Spridgets 9
Darrell_Walker Head cleaning Triumph 16
