TR2/3/3A Temperature Gauge for 1954 TR-2 & Hand Crank
Redoakboo
I recently purchased a 1954 TR-2, which I plan to restore. It is missing the temperature gauge and none of the Parts Houses carry them. Does anybody have a old, workable temperaturegauge they would like to part with? I certainly will pay your asking price. Looking for a crank too.
Dick Vinal
TR4nut
Dick-
Sorry don't have a gauge for you- however one option is if you can get a broken one to use as a core and send it off to one of the gauge rebuilding services. I've used Mo-Ma several times and am happy with their work - I also watched their expert rebuild a capillary temperature gauge and can confirm they know what they are doing.
Randy
TR3driver
Great Pumpkin - R.I.P
Those things are fragile enough that there are very, very few of them just laying around. There is a vendor on eBay selling an approximate reproduction; fine for a driver but not for what I would call a "restoration". Most likely, you'll need to find a broken original and have it rebuilt.
However, as a temporary substitute, almost any 2" mechanical water temperature gauge will work.
I'm actually using the temp gauge from an early TR4, which is electric rather than mechanical. It looks very nearly identical to the original, but requires some other modifications like a voltage stabilizer, correct sender and a wire to the sender.
CJD
The last NOS temp gage sold on Ebay for $325, about a year ago. I watched for 4 years and finally got a trashed gage with a face that is in good shape to transfer to my working internals...and I paid $80 for that. Of all the gages, the temp is by far the rarest currently.
TomMull
I had mine restored last summer by Nisonger for around $200 as I recall. Old cores are fairly readily available if the TR2 units are the same as the TR3s and I think they are.
Tom
DavidApp
The guy on E bay that builds new look a like gauges do look good. At a casual glance or a fairly close look it will probable pass except for very knowledgeable people.
David
martx-5
One of these days I'll get around to repairing my original. In the meantime, I bought one of those replacements from ebay. It's a fairly good representation of the original. but there are some significant differences if you look closely. Also, it has it's own lighting which is different from the original. I've been using it for a few years now.
Here is the listing for the gauge on ebay...https://www.ebay.com/itm/Triumph-TR...ash=item239c5c95e9:g:JDEAAOSwqYBWmIGv&vxp=mtr
Geo Hahn
...Looking for a crank too...
Can't help you there other than to note that the cranks varied through the model changes and you, of course, want an early one. Many of the used ones on offer will be for the 3A which will not be suitable for you - the 'shoulder' that rides in the crank guide will be in the wrong spot.
I believe this is a photo of a TR3A crank...
This crank is quite different though I do not know if it is for a TR2 or TR3 or both...
Your best bet may be to get some measurements from a TR2 owner who is sure they have the right crank though you can get approximate info by measuring the distance from the crank guide to the dog bolt.
CJD
Art, I have been watching that Ebay "clone" add for many years. I am pleased to see it is actually a really well done repro. I think even an OCD Triumph guy would have to do a few takes to tell it's off.
Got_All_4
Ebay is probably the best to watch.. Lately there were 2 early hand cranks but are sold now. You got to act fast. I recently won one for my 3A after 2 years trying to be at the right place at the right time. My 3A looks like the ones above my post. The early ones have the boss "the raised part" closer to the crank.
TR3driver
Of course, the problem with eBay is that so many sellers don't actually know (or pretend not to know) what cars their product actually fits. I see stuff all the time advertised for the wrong car, or an impossible range of cars. So be sure that you can identify the part you need from the photo.
Also check that the rotating sleeve is present on the handle. They sometimes come off and get lost.
PS, my favorite is still the seller who was offering brake rotors to fit "TR2-TR4". Of course, TR2 never came with disc brakes; but the seller assured me they would fit.
TR3driver
No, can't say that I have done it. But I know how, and there is a lot more involved than just bolting on some rotors.
I've got a friend with a Ford 302 engine in his TR4, so I guess you could say that a V8 intake manifold fits a TR4 too.
DavidApp
I bolted the front guide/support for the starting handle to frame to check the fit. It seems the front cowl must provide a lot of support to guide. Without the cowl on I would not like to put too much force on the handle as the guide moves a lot. Am I missing something?
In 1968 my old TR2 had a fiberglass TR3 cowl on it and I remember the guide was always a bit flimsy.
David
TR3driver
Nope, I don't think you're missing anything. The supports basically just complete triangles with the sheet metal of the front apron. Without the apron, the rods bend easily.
BierRunner TR6 Temperature Gauge Triumph 8
R Coolant temperature gauge Spridgets 8
B TR2/3/3A TR3 Temperature gauge Triumph 19
pkmh How hot can it [temperature gauge] get? Austin Healey 4
T Wanted WTB early TR 4 electric temperature gauge Triumph Classifieds 5
Jer is it posible to fit an electric temperature gauge ? Spridgets 4
BN6_2197 Question on Oil Temperature Gauge Austin Healey 1
6 Temperature/Pressure Gauge Spridgets 7
D TR2/3/3A Temperature gauge Triumph 13
K TR2/3/3A Replacement Temperature Gauge Triumph 5
M TR4/4A Temperature and Fuel Gauge Wiring...Help Wanted Please Triumph 6
G TR2/3/3A Routing of TR3 Temperature Gauge Triumph 2
BN6_2197 Oil Temperature Gauge for BN6 Austin Healey 6
K TR2/3/3A TR3 Temperature Gauge...cost to repair? Triumph 11
Tugboat TR2/3/3A Original T3A Temperature Gauge Triumph 13
Anthony_S temperature gauge....HELP Triumph 18
Russ Austin Temperature gauge bulb stuck in thermost houseing! Triumph 10
L TR2/3/3A TR3A - measuring operating temperature w/o gauge? Triumph 12
K Smiths Electric Temperature Gauge Triumph 7
Tinkerman TR2/3/3A TR3A Temperature gauge capilliary tube routing. Triumph 0
W TR2/3/3A Temperature Gauge Rebuild TR3 Triumph 19
MGTF1250Dave TR2/3/3A TR3 Temperature Gauge Face Markings Triumph 3
A TR2/3/3A NOS TR3 Temperature Gauge Triumph 8
RandallRK Temperature Gauge reading Austin Healey 2
regularman Temperature gauge Spridgets 13
beaulieu fixing a cut in half Temperature capillary gauge Restoration & Tools 13
H TR2/3/3A TR3 Temperature gauge Triumph 23
Brooklands TR2/3/3A TR3 Temperature Gauge Triumph 38
T TR2/3/3A Trouble shooting TR3a Temperature gauge Triumph 13
Russ Austin Temperature gauge went goofy!! Triumph 37
TR4 Temperature Gauge Issue Triumph 8
C Temperature Gauge MG 23
D TR4/4A tr4 temperature gauge/sensor reading Triumph 11
fmichaels temperature gauge question Spridgets 6
Trevor Jessie Driving without temperature gauge Spridgets 8
W Temperature Gauge calibration Triumph 4
Dugger Temperature gauge Triumph 4
R "wonkey" Temperature Gauge Austin Healey 6
S TR2/3/3A Tr3 temperature gauge route Triumph 12
Webb Sledge TR6 TR6 Temperature Gauge Triumph 19
G New member with temperature gauge question MG 5
MGTF1250Dave Water Temperature Gauge Triumph 2
C Engine Operating Temperature Austin Healey 21
PDIGIO_6x3 TR6 Temperature Compensators Triumph 3
Michael Oritt Powder Coating Temperature Limit Austin Healey 7
A MGB Stuck water temperature sensor MG 26
S TR2/3/3A What temperature of electric fan switch do you use in your radiator? Triumph 3
nevets Coolant Temperature Austin Healey 13
longbridgehealey Temperature sender Austin Healey 18
TRclassic3 TR2/3/3A Timing and temperature Triumph 13
