KVH
Is there any reason I need to reverse my driveshaft if I have the slip joint forward toward the transmission? I can't tell, but one picture in the manual seems to show it the opposite way.
Second, my rear brake cylinder fastening kit had three clips per side, but I can only get two on--the two big ones. The one called "distance piece" doesn't seem to fit; it's too tight already. Is that unusual?
Thanks all.
Thanks all.
