Results 1 to 11 of 11
Thread: Gearbox mounting crossmember
  1. #1
    Join Date
    May 2010
    Location
    Marco Island, FL. 34145
    Posts
    340
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    I posted in the classifieds but I thought I might post the question here as well. I am in need of the crossmember that bolts to the frame for the gearbox mount on a late Tr6. I believe it's 73-76.
  2. #2
    Yoda poolboy's Avatar
    Join Date
    Oct 2007
    Location
    S.W. Mississippi
    Posts
    3,651
    Thanks Thanks Given
    6
    8
    Thanked in
    Re: Gearbox mounting crossmember
    Do you need the components shown in the 'box' at the bottom, far right ?
    And notice that "101" is for non-overdrive gearboxes.
    I have mounts for 73-76 OD and non-OD boxes.
    PM me with your needs.
    https://mossmotors.com/external-engine-1503
    DRIVE 'EM IF YOU GOT 'EM
  3. #3
    Join Date
    May 2010
    Location
    Posts
    340
    Thanks Thanks Given
    Thanked in
    I need part 102 in that diagram. The crossmember that bolts to the frame.
  4. #4
    Join Date
    Oct 2007
    Location
    S.W. Mississippi
    Posts
    3,651
    Thanks Thanks Given
    6
    8
    Thanked in
    You don't need 100, then, just 102 ?
  5. #5
    Join Date
    May 2010
    Location
    Posts
    340
    Thanks Thanks Given
    Thanked in
    correct. the rest of the parts I have, only need that one piece
  6. #6
    Join Date
    Oct 2007
    Location
    S.W. Mississippi
    Posts
    3,651
    Thanks Thanks Given
    6
    8
    Thanked in
    If you don't mind, can we wait and see if Marvin Gruber or someone will supply you with just that solitary component (102).
    If not I'll break up the complete set.
  7. #7
    Join Date
    May 2010
    Location
    Posts
    340
    Thanks Thanks Given
    Thanked in
    Thats not a problem at all. Thanks
  8. #8
    Join Date
    Sep 2012
    Location
    Arroyo Grande Calif
    Posts
    77
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    I can help with your rear mount,Pm me your address and I will send you part 102
    Philstr6
    Phil
  9. #9
    Join Date
    May 2010
    Location
    Posts
    340
    Thanks Thanks Given
    Thanked in
    PM sent
  10. #10
    Join Date
    Sep 2012
    Location
    Arroyo Grande Calif
    Posts
    77
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    Package on its way,you should see it on monday
    Phil
  11. #11
    Join Date
    May 2010
    Location
    Posts
    340
    Thanks Thanks Given
    Thanked in
    Thanks so much Phil.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
