BN7 wiring diagram in color
Tompol
Guys,
My friend is asking me to install new harness on his 1961-62 BN7 and I only have diagram from service manual. Does anyone have color version of diagram in large file size or in print, I have access to nice color printer and would like to print one.
I have use one like that on my other car and this was tremendous help. If someone help me out I can print one for him.
Any help will be greatly appreciated.
T
Tompol
Toms Import Toys in Oregon sells them in color and laminated 11 x 17 inches. Google it. Dan
Thanks Dan,
I hope someone has a file, i can print it 14x20.
Plus, the one from Tom's is BN1 to BT7 in not sure if the was no changes thru that many models and years.
Regards
Tom
RAC68
Tompol,
Although I would suggest you acquire the wiring diagram for the BN7, installing new wiring harnesses could be a bear if you don't have the documents identifying the connectors and the harness routing. In most cases, a new harness will have the connectors labeled. However, I would see if you could acquire some pictures showing how each harness is routed through the Healey and present those connectors in close proximity to the component assignments. I have found that there is little difference in harness routing between 3000 models from BN and BT models. Keep in mind, there are a number of individual harnesses (I believe 4 harnesses), along with a number of separate extensions.
Take a look at https://www.healey6.com/technical.htm under the Electrical category and look to the documents at the end of that category list.
Good luck,
Ray(64BJ8P1)
T
Tompol
Tompol,
Good luck,
Ray(64BJ8P1)
Thanks Ray,
This is great source of information about harness replacement.
Tom
steveg
Highly recommend Tom's Imports color wiring diagrams. I recently used one to install a new harness in my BN6. I was intimidated by the project but the following process worked for me:
1) buy an inexpensive label maker, such as the Dymo 160 https://a.co/60WxiQs
2) in the comfort of your living room, refer to the above color wiring diagram and label every one of the wires in the harness. It takes a couple of evenings but minimizes the time you spend on your back under the dashboard.
FWIW, I made the labels long enough to wrap around the wire, with the verbiage repeated twice so you could read it from any angle. The label adhesive doesn't stick to itself very well, so it's helpful to staple the labels together after folding them over the wires.
T
Tompol
Thanks for GREAT suggestions.
andrea WIRING DIAGRAM for imprved BN4 100/6 and early BN7 Austin Healey 3
D Original BN6 / BN7 Battery Switch Wiring Question Austin Healey 15
J Wiring Question BN7 Austin Healey 2
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 0
H BN7 and BN2 Lengths Austin Healey 3
A BN7 Front Hub Stud Nuts Austin Healey 5
rgfrey 1959 BN7 Throttle Control Linkage Austin Healey 2
B Roof vent position on BN7 hardtop. Austin Healey 15
B Cold Start Problems BN7 Austin Healey 21
S For Sale Austin Healey 3000 and 3000 MK II Factory Parts Manual - BN7 & BT7 on CD/ROM Austin Healey Classifieds 0
G 1960 3000 BN7 Top Help Austin Healey 0
F Which Original Oil filter assembly for BN7 Austin Healey 19
lbcspinners 1962 Austin-Healey 3000 Mk II BN7 Tri-Carb 2-Seat Roadster: for sale on BaT Austin Healey 2
F BN7's left Austin Healey 9
F For Sale Disc Wheel Hub, From Bn7 Austin Healey Classifieds 5
jnew >>> Austin-Healey Parts Lists for BN4-BN6, BN7-BT7, & BJ7-BJ8 Available Online Austin Healey 17
Healey Nut BN7 Austin Healey 6
R BN7 Speedometer issues Austin Healey 1
F Throw away BN7 Gas tank Austin Healey 3
F For Sale BN7 gas tank, original. [I think]. Austin Healey Classifieds 0
HealeyRick Nasty BN7 Sells for $75k Austin Healey 6
busybrit Healey BN4/6 bell housing vs BN7/BT7 differences. Austin Healey 2
stretchit2 Question regarding BN7 Hardtop Austin Healey 7
rjc157 bn7 electronic choke Austin Healey 0
BN6_2197 Front Wheel Clearing of BN7 Austin Healey 35
David Townsend BN7/BT7 Limited Edition Fine Art Prints Austin Healey 6
F VIN Problem / Whats difference between BN6 and BN7, bare car. Austin Healey 21
J 1960 BN7 2 seater roll bar. Austin Healey 5
R BN7/BT7 Windscreen Installation Advice Austin Healey 5
Marvin Gruber BN7 on Craigslist, Nashville Austin Healey 0
J Wood dash for 60 BN7 Austin Healey 16
S Green/white BN7 Chequered Flag Austin Healey 7
R How to erect at BN7 hood [top]? Austin Healey 4
bighealeysource BN7 sells for crazy money Austin Healey 22
R Proper Timing Technique '60 BN7 Austin Healey 0
Healey Nut Red bn7 Austin Healey 7
B BN7 with BT7 VIN on eBay Austin Healey 11
R BN7 Windscreen removal Austin Healey 7
L 3000 BN7 insulation Austin Healey 11
R BN7 Coil Wires Austin Healey 3
R Need picture [s] of a BN7 or BT7 Servo installation Austin Healey 3
M Steering Wheel modification for a BN7 Austin Healey 15
R How to install a BN7 hood [top] Austin Healey 3
R BN7 / BJ7 Dash Top Removal Austin Healey 11
AH67 The size of battery for 62 BN7 Austin Healey 16
AH67 Spinning starter motor BN7 Austin Healey 13
AH67 exhaust & Battery kill switch- mkii bn7 Austin Healey 13
dougie 1960 BN7 For Sale Austin Healey 6
Jim_Newman Bn7 fan Austin Healey 6
R Headlight switch replacement on BN7 or BJ7 cars Austin Healey 3
