Results 1 to 8 of 8
Thread: TR3 Steel Wheels
  1. #1
    Join Date
    Feb 2016
    Location
    Macon Georgia
    Posts
    1,575
    Thanks Thanks Given
    2
    Thanks Thanks Received
    8
    Thanked in
    TR3 Steel Wheels
    I got a Rimmer Bros. TR2-TR6 Big Sale catalog in the mail.
    In it I noticed they list New Steel road wheels for the TR6 as either 5.5 J x 15 or 6 J x 15
    and Alloy wheels for TR2 to TR6 as 5.5 J x 15.
    Is there a difference between the TR3 to TR6 wheel stud pattern or would these steel wheels work for the TR3?
    I did manage to assemble a good set of 5 steel wheels.
    David
  2. #2
    Join Date
    Aug 2003
    Location
    Sunny So California
    Posts
    18,372
    Thanks Thanks Given
    2
    23
    Thanked in
    Re: TR3 Steel Wheels
    Stud pattern is the same, I have original TR6 wheels on my TR3.
    My only concern with the alloys is whether they would clear the calipers. The later brakes were slightly smaller; probably to give a bit more room for the wheels. I once had some Asian rim.that fit fine on the back, but hit the calipers up front.
  3. #3
    Join Date
    Feb 2016
    Location
    Macon Georgia
    Posts
    1,575
    Thanks Thanks Given
    2
    8
    Thanked in
    My thought was that it would have been nice to have new steel wheels. I had to acquire 2 and a bit cars worth of wheels before I had 5 good wheels.
    I presume the 5.5 J wheels and tire may be too thick to go in the spare compartement.
    David
  4. #4
    Join Date
    Jul 2010
    Location
    Annandale, NJ
    Posts
    796
    Thanks Thanks Given
    Thanked in
    I don't think you can run the TR3 hubcaps on TR6 wheels.
    If any wheel manufacturers(Moss?) are listening I would pay wire wheel or alloy replica prices for new Tr3 steel wheels.
    Tom
  5. #5
    Join Date
    Aug 2003
    Location
    Sunny So California
    Posts
    18,372
    Thanks Thanks Given
    2
    23
    Thanked in
    Quote Originally Posted by DavidApp View Post
    Mine sure are. I use a "compact spare" tire mounted on a stock TR3 rim for the spare. If I get a flat, the big wheel has to ride home behind the seats.
    Quote Originally Posted by TFB View Post
    Depends on how badly you want them
    Randall
  6. #6
    Yoda Marvin Gruber's Avatar
    Join Date
    Jan 2003
    Location
    Florence, Al
    Posts
    3,004
    Thanks Thanks Given
    Thanked in
    As recently posted in another thread. 69 TR6 wheels with the extended nipple will work with TR3 hubcaps.
    Marv
  7. #7
    Join Date
    May 2017
    Location
    Garrison, NY
    Posts
    195
    Thanks Thanks Given
    Thanked in
    Any chance of a better side view of those wheels?
  8. #8
    Join Date
    Aug 2003
    Location
    Sunny So California
    Posts
    18,372
    Thanks Thanks Given
    2
    23
    Thanked in
    Same setup, different car
    PS, note that they are later TR6 wheels, that I modified with studs for the TR3/4 hubcaps. Using 69 TR6 wheels won't look quite the same, as those studs stick out quite a bit and so hold the cap farther out.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
