TR2/3/3A steering column bushings
Dr_Mike
II have read the thread started by “griff” in 2009 and seem to have a similar problem but I do not see the solution.
I presume that the circular indent in the outer tube is real, and the inside of the tube is otherwise clear. I can press a bushing in above the ridge, but it is then firmly located and prevents the outer tube from reaching the steering wheel. There is already a bushing at the bottom end of the tube .
So the only way I can insert the top bushing is to remove ( destroy) the bottom bushing with its location buttons and slide the top bushing up the shaft and hope it does not slide back down again. The bushing is a loose fit on the inner shaft once I had got it over the serrations on the bottom end, but will be a tight fit in the outer tube which will make it tough to push up. The new bottom bushing will then have to be forced over the serrated end. (wish it would come off but it seems well and truly stuck.) I suppose I could leave the bottom bushing off!
I hope that makes sense. I will post a photo or two later but I left them in the “garage” which is a distance away.
TR3driver
Great Pumpkin - R.I.P
If I'm reading this correctly, you have a TR3A with the 'split' steering column and are trying to install the felt bushing just below the steering wheel. Is that right? (It's helpful if you add your car's commission number to your signature, so we at least know which car you are asking about.)
The felt should go above the circular indent and IIRC protrude just slightly from the tube. But new felt is often supplied somewhat oversize and may need to be trimmed to fit. Mine was too thick, but rather than trying to thin it, I just turned a piece of Delrin to fit.
I don't understand about the "serrated end" "coming off" or forcing the bushing on. The bottom of the upper shaft has splines to fit into the coupler to the lower shaft; but the splines are an integral part of the shaft and are no larger than where the shaft rides in the lower bushing. It should slide easily through the bushing. The original lower bushing had layers of nylon, steel and rubber; but some aftermarket replacements don't have the steel.
The whole upper shaft should slide easily through both bushings, it's only located by the coupling to the lower shaft (which in turn is held by the ball bearings in the steering box). It should also turn easily. Any stiffness is going to contribute to making it harder to steer the car.
2liter4cyl
Bronze
To keep the felt from wearing out and/or giving the wheel freedom from being a sloppy fit, I soaked the felt in 3in1 oil . LeT
CJD
Yes...the upper felt bushing installs from the top, not the bottom. A pic would help us see what is causing the trouble...
Dr_Mike
Thank you all for replies..
chassis 60016
checked my !D 10 T factor and found I had not been so stupid as ignorant... and knowing it. ( I cannot get my photos in to the computer as another example.)
I do thInk the Moss catalogue top remains a felt bushing around the wider part of the shaft, and thus above the ring
The serrated connection looked like push-on that had not gone all the way ( see missing photo!) Happy to be wrong about that and the location of the upper bush.. Will look for lubricant next ? MSO2.
You spared me a lot of expensive anguish.
  • steering column.rtfd.zip
PatGalvin
Hi Randall
Are you happy with the Delrin bushing that you made for your steering column? Curious to know how that is working out for you. Do you just push fit the Delrin, grease the column, and install it? Thanks for any tips. I am considering the same mod as I need to remove the steering column soon. Thanks
Pat
TR3driver
Seems to work just fine. I already had the shaft in place (my TR3 has the one-piece steering column), so I just pushed the bushing down over it. I left the bushing dry, but the shaft probably still has some moly on it from before.
Got_All_4
Yep I made mine too and very happy with it. Put about 800 miles on it last year and no hint of any slop in the steering. I know I mad a couple extra too to have on hand.
Got_All_4 TR5/TR250 Need guidance for replacing steering column bushings Triumph 11
S TR6 steering column bushings Triumph 5
I TR6 Installation of Delrin steering column bushings Triumph 3
BobbyD Delrin Steering Column Bushings Triumph 2
I TR6 As the World turns -TR6 steering column bushings Triumph 6
J Steering column bushings Triumph 4
SCguy Steering column bushings? Triumph 1
G Steering column bushings MG 0
olarson TR2/3/3A Steering Column Bracket Triumph 2
M Midget steering column Spridgets 3
B Steering Column Wiring/Sealing Austin Healey 1
Walter74 Steering Column Felt Bushing Austin Healey 3
D Steering Column Adjustment Collet Austin Healey 8
Retired2020 TR250 steering column bushing Triumph 2
ActionJackson Spitfire Steering Column Lock Triumph 3
A Early 1967 AH Sprite - installing steering column and new directional switch? Spridgets 0
R TR2/3/3A Replace wiring harness in steering column Triumph 61
R TR2/3/3A Install new wiring harness in steering column Triumph 16
R TR2/3/3A Steering Column Wiring Triumph 18
M TR6 EZ EPAS Steering Column Fitment to TR4-6. Triumph 0
R TR2/3/3A Wiring from the steering column Triumph 7
M TR6 EZ Power Assisted Steering Column Fitment Triumph 3
D TR6 Replacing Horn insert in steering column Triumph 11
L TR2/3/3A Upper steering column bushing Triumph 8
BoyRacer Steering Wheel Location with non-adjusable column Austin Healey 6
BoyRacer Wanted Steering Wheel Hub Adaptor for non adjustable column Austin Healey Classifieds 1
steveg Steering column steady brace and scuttle shake? Austin Healey 2
T TR2/3/3A Is there a Delrin bush available for the top of TR3 steering column instead of felt? Triumph 8
T TR2/3/3A Requesting help on removing TR3A steering column and box Triumph 21
T Steering Column Installation Spridgets 6
C Non-Adjustable steering column questions Austin Healey 14
BoyRacer Steering Column Height Adjustment on BN2 Austin Healey 1
SherpaPilot TR6 Steering Column Loose Triumph 8
John_Mc TR6 Steering column rubbler coupler Triumph 8
R TR2/3/3A Installing wiring harness in steering column Triumph 59
B Steering Column Bushing Austin Healey 2
S TR2/3/3A steering column through the body tub Triumph 5
S TR2/3/3A steering bracket that fits under the dash for the end of the column Triumph 2
KVH General TR Steering Shaft/Column Short Circuit?--Electrical Issue with Light Switch Triumph 3
G Steering Column Mounting Austin Healey 1
60BN7 Adjustable Steering Column Won't Lock Austin Healey 9
B Outer steering column connection to the steering box Austin Healey 6
M TR4/4A Triumph TR4/4A Steering Column spline size Triumph 1
D BT7 adjustable steering column / steering wheel Austin Healey 1
G TR2/3/3A Steering Column Support for One-Piece Steering Column Triumph 3
adcronin For Sale MGB New Turn Signal Switches: 62-67 and 68-70 Also 70-73 MBB Steering column cover MG Classifieds 0
rjc157 TR6 steering column Triumph 0
Marvin Gruber BJ8 steering column blanking plate seal Austin Healey 1
J TR2/3/3A Split steering column rubber bushing installation. Triumph 4
C Mounting ignition switch to XKE series 2 steering column? Jaguar 4
